04-20-2008, 09:02 PM | #1 |
22
Rep 143
Arai Helmet question!
I was looking into getting an Arai full face pretty soon.
But was confused as to why the GP-5 is so much more expensive compared to its other models the GP-5k and GP-5W. As far as I know the GP-5k has less ventilation and is slightly heavier than the GP-5. GP-5W has about the same amount of ventilation as GP-5 and even has a larger eyeport. It uses different shields than GP-5 because of the larger eyeport. This is about $800. GP-5 is about $1000. What the hell? Also...was wondering if SA2005 helmets could be used in Karting applications? I know karting has its own standards Snell K-05..and Karting helmets can't be used for auto racing.
AlpineWhite (deciding)
Black Leatherette (for sure) Glaciersilver or Highglossblack trim Sport Package Active Steering Manual Transmission :roundel: |
04-20-2008, 09:27 PM | #3 |
22
Rep 143
I believe their impact rating is all the same. They use the same material for all 3 helmets. Only difference is that GP-5K uses slightly cheaper material, so its heavier, but they say the impact rating is the same.
04-20-2008, 09:32 PM | #4 |
No longer moderate
325
Rep 4,401
I also belive that the SA has to have a fire rating whereas the M (Motorcycle) does not. That adds to the cost of an SA helmet. If you're autocrossing, check to see if they'll accept an M rated helmet.
Some of you racing types chime in please. |
04-20-2008, 09:33 PM | #5 |
22
Rep 143
I don't just autocross but I also will be Karting...and on the track..I rent a helmet.
04-25-2008, 12:24 PM | #6 |
22
Rep 143
bump ...i need answers!
04-29-2008, 08:23 AM | #7 |
45
Rep 355
You are correct, the GP-5 is both lighter and has better ventilation then the GP-5K. I've had the GP-5K and now i have a GP5 and I much prefer the GP5 although the difference is not huge. I'm using it for formula car racing (Skip Barber) and DE's
