      04-20-2008, 02:23 AM   #1
driftdriven
53
Drives: BMW 135i
found a better intake but it's more expensive
For all you who did not like the bms because it was so close to the engine and worry about the heat issues. This has a bit more distance from the engine
http://www.jlevistreetwerks.com/p1708/Logic-Motorsports-HVI-Intake-System-335i,-135i-%26-535i/product_info.html?osCsid=6028b961dc28442e6dbbc5125 a8e0294
if you have already seen this then, sorry!
      04-20-2008, 09:01 AM   #2
curtdragon
Car'a'carn
472
Drives: Audi S4
2015 Audi S4  [0.00]
Uh but now it really is just sucking in hot air. At least the filter options are still hitting the incoming air from the kidney vents
      04-20-2008, 11:14 AM   #3
JohnnyTT
JohnnyTT's Avatar
29
Drives: 2011 X3 3.5
The cone on that one looks really small compared to other choices. Any flow restrictions?
      04-20-2008, 12:06 PM   #4
aus
Drives: Odysse
It should have a heat shield at that price. Though, many would say it's not needed in a turbo car, but it's not going to hurt either.
      04-20-2008, 12:25 PM   #5
curtdragon
Car'a'carn
472
Drives: Audi S4
2015 Audi S4  [0.00]
yeah some people think cause you have an intercooler it doesnt matter... but colder air makes more power period.. an intercooler is not an a/c it deosnt lower the temp to x* it lowers its by x*
I still prefer a nice CAI or the BMS filter as it still gets air from the front air ducts
      04-20-2008, 12:36 PM   #6
Matt60158
///M
13
Drives:
Seems like factory air box is still the way to go as long as hot air intakes are the only option.
"She blows more than my mind" - RHCP
*Aerodynamics are for people who can't build engines.
      04-20-2008, 12:43 PM   #7
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
I am going to try the factory box with a Streamline panel filter and see how it works.
      04-20-2008, 07:52 PM   #8
TunedM2C
TunedM2C's Avatar
826
Drives: 2016 LBB M2
^ Same here.
      04-20-2008, 10:53 PM   #9
WhiteOne
Drives: 2008 AW 135i
RICE!
      04-20-2008, 11:09 PM   #10
morscode
Got Boost?
morscode's Avatar
Drives: 19 x3 m40i
Seems like a horrible design. I just can't really see how any other intake system will improve on the OEM design, it's a dual kidney ram air intake. You can replace the filter with a K&N panel filter
      04-21-2008, 01:17 PM   #11
aus
Drives: Odysse
The counter argument is that the turbo's get the intake temp so high that not matter what the intake temp is, it's still going to get to the same temp after the tubo.
I figure it doesn't hurt to have a heat shield.
      04-21-2008, 01:20 PM   #12
Berduderunner
drk one
Berduderunner's Avatar
Drives: 2008 135i
2008 e90 335i  [0.00]
2008 135i  [0.00]
ugh... still gonna have to stick with filter drop in.
      04-21-2008, 01:21 PM   #13
Crowley
54
Drives:
It will be interesting to see if there are any gains found with the BMW performance filter kit ....
Crowley
The last words on the powerplant should go to a clearly overwhelmed Hormazd Sorabjee, editor and publisher of Autocar India: “There is something simply magical about BMW’s in-line six. It has a creamy smoothness that makes velvet feel like sandpaper.”
      04-21-2008, 01:36 PM   #14
curtdragon
Car'a'carn
472
Drives: Audi S4
2015 Audi S4  [0.00]
its never going to be the same temperature:
The formula to figure the ideal outlet temperature is:
T2 = T1 (P2 ÷ P1)0.283
Where:
T2 = Outlet Temperature °R
T1 = Inlet Temperature °R
°R = °F + 460
P1 = Inlet Pressure Absolute
P2 = Outlet Pressure Absolute
      04-21-2008, 01:51 PM   #15
dim135
Drives: bmw 135
check this
http://www.e90post.com/forums/showthread.php?t=133554
      04-21-2008, 07:15 PM   #16
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
Most tuners have said the factory box is a limitation as the power goes up.
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      04-22-2008, 12:41 AM   #17
F0Bman
Drives:
Factory for sure.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
www.TheTunerSource.com
      04-24-2008, 11:30 PM   #18
Orb
111
Drives: 335
That is true but they omit a few facts. The gains on pressure drop reduction with CAI or filter are more or less because compressor efficiency is on big downwards slide at around 14 PSI….the compressor is starting to choke. It is all good but not really the truth. You do the same with an intercooler which is big bang for the buck.
Orb
      04-25-2008, 12:13 AM   #19
professor
Drives: Z4 M40i
orb does this imply that a better filter would automatically require a bov for optimization?
      04-25-2008, 03:12 AM   #20
Alext
138
Drives: B M W
That kit is a rip off...just a bit of plastic drain pipe+ a K&N haha. What you really need to do is locate the filter in the front bumper somehow totally out of the engine bay. I have done this on other cars and it means that intake air is same as ambient. Means longer intake pipe length though. I do not know if this is achievable on the 135i.
      04-25-2008, 06:36 AM   #21
MastaMind
I like beer
32
Drives: AW 135
Someone needs to develop an intake like the J's racing or Mugen intakes for the S2K. They have a "snorkel" to direct cool air from the front of the vehicle to the filter. The snorkel actually encompasses the filter, so it's not sucking in air from the engine bay.
This shouldn't be hard to do with the 1. Just make a piece that connects to the existing ducts and houses the high flow filter.
      04-25-2008, 07:17 AM   #22
natedog_1959
Drives: 2004 SVT Focus
There is a 335i intake that locates the filter in the drivers side wheel well area. It looks to be a great design. Nate
Search this Thread:
Advanced Search
