      04-12-2008, 10:43 PM   #1
0002s
Mein Führer! I can walk!
0002s's Avatar
45
Drives: Not a BMW
SSTT Dyno GRAPHS POSTED
      04-12-2008, 10:47 PM   #2
vivid
vivid's Avatar
England
39
Drives: 135i, 323i
thanks for posting, can;t wait to see the graphs in the morning.
Current: 135i, 323i wagon.
Sold:GTI
Sold: FX45
Sold: E36 M3
      04-12-2008, 10:56 PM   #3
coco_m3
coco_m3's Avatar
Drives: Supercharged E90 M3
2008 BMW M3  [0.00]
2010 BMW E90 335i  [0.00]
DIY! please!
      04-12-2008, 11:13 PM   #4
jtsherri
jtsherri's Avatar
Drives: TBD
2008 135i  [10.00]
The graph is ridiculous. I'm sure many/most have seen Clayton's run already; however the torque plateau that these cars produce is just astounding. It's almost hard to believe it's a FI car.
Originally Posted by silverbullet135i View Post
DIY! please!
Not sure if Shawn took pictures of the work we did today or not; however, we had to do it twice, as Clayton gave it a try on his own car and I'm confident that I could remove the airbox, install the SSTT and throw the airbox back in the car in less than 30 minutes. It's truly is THAT easy.
Oh and the car is even more ridiculous after this mod... Clayton can correct me if I'm wrong, but I would say that Shawn's car was pulling around 3/4 car lengths per gear during a cat and mouse chase we did. It was pretty impressive.
      04-13-2008, 01:20 AM   #5
GT3
Track addict
Drives:
Awesome work guys. Can't wait to hear more feedback. Looks like excellent gains!
Subscribed.
      04-13-2008, 01:20 AM   #6
hellrotm
4143
Drives: F80
Did you disconnect the battery?
I read many threads on the E90 forum recommending disconnecting the battery for 1 hour. This resets the ECU and allows the ECU to adapt more quickly/completely.
Many have also felt more power as a result.
      04-13-2008, 08:38 AM   #7
0002s
0002s's Avatar
45
Drives: Not a BMW
      04-13-2008, 08:40 AM   #8
0002s
0002s's Avatar
45
Drives: Not a BMW
      04-13-2008, 08:49 AM   #9
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
Shawn, any issues with the battery disconnect? Such as settings reverting to default for ancillary items (beyond losing radio presets)? Any re-programming of anti-theft codes, etc?
Also thanks for sharing this - looks like a good alternative for some of us not wanting to re-wire the ECU. ; -)
      04-13-2008, 09:03 AM   #10
0002s
0002s's Avatar
45
Drives: Not a BMW
      04-13-2008, 09:40 AM   #11
vivid
vivid's Avatar
England
39
Drives: 135i, 323i
nice graphs... an identical lines just with more power.
Sold:GTI
Sold: FX45
Sold: E36 M3
      04-13-2008, 09:59 AM   #12
0002s
0002s's Avatar
45
Drives: Not a BMW
      04-13-2008, 10:00 AM   #13
0002s
0002s's Avatar
45
Drives: Not a BMW
      04-13-2008, 11:30 AM   #14
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
0002s, Do you feel that it maintained its stock driveability after the upgrade?
      04-13-2008, 12:23 PM   #15
Numb3rs
13
Drives: Looking
Glad your having fun. Though, I am somewhat confused by the first dyno posted above. Something is not right, the torque and HP don't converge where they should.
:iono:
Anyways.. If you ever head downtown for a Red Wing game or Tigers, let me know I will meet up with you. Want to check the 135i out more. I get jeleous when I read threads like this, but I have to stick to my home improvement plans this summer. I'll be joining the 135i club soon enough.
      04-13-2008, 12:40 PM   #16
0002s
0002s's Avatar
45
Drives: Not a BMW
      04-13-2008, 01:02 PM   #17
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
I have been going back and forth between the JB2 and the SSTT and after I read your review I thought that SSTT is the way for me to go as well. Then I came across a post on N54Tech stating the downside of the SSTT is that with < 93 octane and high ambient temps you get timing retard. Since I live in AZ where all the gas that I have seen is less than 93 and the temps are always high, this would likely be an issue for me.
      04-13-2008, 01:06 PM   #18
0002s
0002s's Avatar
45
Drives: Not a BMW
      04-13-2008, 01:06 PM   #19
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
^^^:thumbup:
      04-13-2008, 01:08 PM   #20
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
Maybe if the 'phantom' Stage2 SSTT ever reveals itself, it will help me make a choice.
      04-13-2008, 01:30 PM   #21
curtdragon
Car'a'carn
472
Drives: Audi S4
2015 Audi S4  [0.00]
Originally Posted by 0002s View Post
We are having an issue with Comfort Access. It quit working. We are trying to figure out if it was fuse related or battery related.
To answer your question. You will loose your custom settings when you disconnect the battery. Have fun "stalk" or iDrive fishing after this.
It's a great alternative to the ECU mods. The limitation is you only get 11-12 psi, so if you want more power you have to move up. The benefit is real usable power you feel and the ECU not operating outside it's normal ranges. Because it will not log any data that could cause a CEL, it's about as safe as you can get.
It's underneath the air box and COMPLETELY out of sight. I am not going to remove this when I go to get an oil change. they won't be able to see this unless they start to remove parts that don't need to be removed in the 1st place. You really have to be looking for this to want to find it.
easy way to get around this is to get a 9volt battery, a 9 volt battery connecter pigtail and a cigarette lighter pigtail. connect the two pigtails so one end plugs into the lighter output and the other plugs in a 9 volt battery... enough juice to retain the settings but not enough for the ecu
      04-13-2008, 03:38 PM   #22
0002s
0002s's Avatar
45
Drives: Not a BMW
Search this Thread:
Advanced Search
