05-07-2024, 10:03 AM | #1 |
Rep 8
Differences between a 2019 and a 2020 X3 M40i?
Hey everyone, Im looking at some used X3 M40i's and I am new to these.
What are the differences between say a 2019 X3 M40i and a 2020 X3 M40i? I thought they were all the same HP/TQ but on finding a post on here someone had said a 2018 X3 M40i with a stage 1 tune is basically at where a stock 2020 M40i is at stock. Is that true? Also it looks like the cluster changed between the years too, not sure if its technically any better? Anything else change for the better or worse? These seem to be pretty reliable even well above stock power levels no matter what the year from what I can tell. That is awesome to hear and one of the main reasons I am seriously looking at these. If I'm wrong on that please let me know lol I'm shopping around for one of these (or a X3 M if the price is right) and want to make the best decision possible without breaking the bank. I do care about performance and would probably throw some goodies at it either way (I generally cant help myself there), and just want to make the best decision possible in my budget. Last edited by sdamike; 05-07-2024 at 10:40 AM.. |
05-07-2024, 06:16 PM | #3 | |
Your Average B58'er
296
Rep 245
Incorrect. B58B30C has the 2 port exhaust manifolds. The x3 m40i uses the B58B0M0 for gen 1(2018-2019) and B58B30O1 for gen 2(2020+). All 6 port exhaust manifolds. 2020+ uses higher flowing hpfp and has a few intake manifold and valve cover differences as far as the outside of the engine goes.
2019 X3 M40i - MHD STG2 HPFP E40ish | MHD FlexFuel Kit | TU HPFP | xHP stg 3 | VRSF catless downpipe | MST intake | BMS occ | Verus turbo heat shield | P3 V3 gauge w/ P3 ESVA | FTP Charge Pipe | RossRacing PCV v1 VTA | MSS Springs | RES Exhaust w/o valves | Vossen HF-5 21x9.5/10.5 265/295 PS4S | Yellow DRLs | Paragon Rotors w/P3 pads |
05-07-2024, 06:20 PM | #4 |
51
Rep 184
True, but the date is important. Oct. 2019 is 2020....
Gr8ZongB58296.00 |
05-07-2024, 06:23 PM | #5 |
Your Average B58'er
296
Rep 245
Yes.
One quick look at the intake manifold and/or hpfp and you'll know.
05-07-2024, 07:43 PM | #6 | |
Rep 8
Thats the main difference Im concerned about TBH. Also what is HPFP? |
05-07-2024, 08:12 PM | #7 |
628
Rep 1,097
Drives: 2021 X3 M40i
Either M-sport steering wheel or iDrive 7 was new in MY2020 I think - trying to recall.
Most likely the mSport steering wheel came in midway in '19 (https://x3.xbimmers.com/forums/showthread.php?t=1570485) Live cockpit pro in '20 |
05-07-2024, 08:17 PM | #8 |
628
Rep 1,097
Honestly MY20 is the safest bet.
05-07-2024, 08:31 PM | #9 |
800
Rep 1,961
2019 will still have the burbles and pops if you're into that kind of thing. Only in select, higher modes.
This might help. Almost reads like marketing material, but good info. Realistically, they're about the same stock, but the TU will have more headroom to tune thanks to the higher pressure fuel pump. |
mailman_fin362.00 |
05-07-2024, 09:16 PM | #10 | |
Your Average B58'er
296
Rep 245
High pressure fuel pump (hpfp): gen1 has the indent on top. gen2 is round. gen1 rated at 355hp. gen2 rated at 382hp.
X3_Alaska161.50 |
05-08-2024, 02:01 AM | #11 |
51
Rep 184
I think it is not that easy. I think there are 3 different engines produced in period 2018-2020. Mine (oct.2019, US made, DE market) is clearly an TU engine, with stronger hpfp, but with GPF and without MH. And it has 360 hp.
So there should be B58, B58TU and B58TU2 Last edited by Jolbex; 05-08-2024 at 02:08 AM.. |
05-08-2024, 11:27 AM | #12 | |
165
Rep 443
Drives: 2021 X3 M40i (times 2)
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights, 50th anniv badges
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake Sold - 2009 328i - Stock, 195,000 running strong. |
05-08-2024, 07:50 PM | #14 | |
Rep 8
I'm assuming to check either one of those the engine cover needs to come off? |
05-08-2024, 07:53 PM | #15 | |
Rep 8
Alias1431799.50 |
05-08-2024, 07:53 PM | #16 |
Your Average B58'er
296
Rep 245
Yes. Plastic cover pops right off.
05-09-2024, 03:23 AM | #17 |
51
Rep 184
05-09-2024, 06:34 AM | #18 |
165
Rep 443
It's not a TU then. The pump can be upgraded after the fact by an individual or dealer. TU all have increased HP - You can tell the difference based on the engine cover also, it's on the b58 wiki and I think marketing material describing the difference.
05-09-2024, 08:54 AM | #20 |
165
Rep 443
But not on the X3/X4.....
B58B30O1 (TU): 285 kW (382 HP) edit Applications: 2018–present G29 Z4 M40i (in countries not subject to EU emissions standards) 2019–present G20/G21 M340i 2020–present G01 X3 M40i 2019–present G02 X4 M40i B58B30M2 (TU2): 280 kW (375 HP) edit 2022–present G07 X7 xDrive40i 2023–present G70 740i 2024–present G05 X5 xDrive40i 2024–present G06 X6 xDrive40i 2024–present G60 540i xDrive
05-09-2024, 12:16 PM | #21 |
51
Rep 184
Not true. TU was presented in 2018 and there were various outputs between 32x hp and 37x hp. TU2 is something else. So the fact is that there is at least 1 (mine) TU which is 360hp, no hybrid, with particle filter. Produced 10/2019 for german market. TU 382hp was mild hybrid
05-09-2024, 12:30 PM | #22 |
Rep 18
B58B30O1 (TU) has a standard rating of 382 HP in the M40i. However, in European countries requiring particulate filter, it was rated at 360 HP. Same engine, different rating.
I'm not sure what you mean when you say the TU was mild hybrid. There are various systems implemented depending on production year and model, some hybrid some not. |
