04-07-2008, 07:36 AM | #1 |
86
Rep 631
Dinan Flash Questions
1) If Dinan issues an update to the flash, can you get your car updated free of charge?
2) Does anyone have any Dyno numbers / charts for the current flash? 3) What are the major concerns of the new flash? The current torque curve allows for max torque thru a wide range of RPM's...does the Dinan do the same? Lag issues? Thanks! |
04-08-2008, 05:09 PM | #2 | |
46
Rep 519
2.) attached (for 335i, but should be exactly the same - Dinan is source for the numbers, but no one has attacked their accuracy). 3.) Only issue some Dinan drivers have is slightly reduced initial throttle-pedal sensitivity at low RPM. Dinan is fixing this with the reflash, due out in next weeks. WOT is cure for any and all such issues. |
04-08-2008, 06:51 PM | #3 |
Car'a'carn
472
Rep 751
