      04-02-2008, 09:14 AM   #1
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Tire Pressure tooo high - Check it
I decided to check my tire pressure since dealers sometimes forgot to check this when they deliver a car.
I was sitting at 38-39 psi all around.
I set the pressure to 36psi all around (stock), and you wouldn't believe the ride difference 2+psi makes on run flats. It's a much smother ride.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      04-02-2008, 09:16 AM   #2
Dave
formerly izzo/comeback
Dave's Avatar
Drives: 2016 RC 350 F Sport
2008 135i  [6.80]
ditto that i did that the first dday... my rears were at 40!
BMW CCA # 418268
      04-02-2008, 09:30 AM   #3
Bizall
Bizall's Avatar
Drives: 2019 Honda Accord Touring 2.0
Note to self. Thanks.
2018 BMW M3 - 12.1 @ 121mph
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph
2008 BMW 135i (Sold) 12.8 @ 106mph
      04-02-2008, 09:46 AM   #4
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Yikes!
The only reason I didn't the first day is my dealership always checks them at delivery time.
      04-02-2008, 10:25 AM   #5
jeremyc74
Drives: '08 135i Montego/Terra
I learned my lesson about this when I bought the GTO. The spec on them is 38/40 but for some reason they jack them up to around 50PIS for shipping. A lot of the cars were sitting on the dealer lots like that, including mine. A few PSI really makes a difference on modern low profile tires.
      04-02-2008, 11:40 AM   #6
PhAzE
28
Drives: AW 1m (soon)
What is the stock psi supposed to be at for the 1er's 18's? I've usually heard that 32-33 psi is the normal.
      04-02-2008, 11:47 AM   #7
plien69
20
Drives: 2014 M235i
The sticker on the door jamb lists 36psi all around.
      04-02-2008, 12:01 PM   #8
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Mine was a couple pounds high also, but I'm running 37 front, 36 rear now.
phaze, 32-33 is too low for low-aspect ratio 18s. Too easy to damage tires or wheels.
      04-02-2008, 12:03 PM   #9
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I set all 4 to 36psi.
      04-02-2008, 12:07 PM   #10
ulrichd
ulrichd's Avatar
Drives: 128i M-Sport
Just put new Toko S-rides on my Mini at Discount Tire. They set the pressure at 44 all around.
Ulrich
      04-02-2008, 12:33 PM   #11
NOLEimit
Drives:
I adjusted mine this past weekend. I did 32psi up front and 36 in back. Was trying to dial out a bit of understeer.
[SIGPIC][/SIGPIC]
135i -- Alpine White -- Coral Red -- ZSP
Previous --2004 VW R32--
      04-02-2008, 02:10 PM   #12
plien69
20
Drives: 2014 M235i
You want higher pressures up front and lower pressures in the rear to reduce understeer:
http://www.tirerack.com/tires/tirete....jsp?techid=58
Higher pressures = more grip (within nominal ranges, e.g. <45psi)
      04-02-2008, 02:18 PM   #13
Dave
Dave's Avatar
2008 135i  [6.80]
i have mine at about 36 in the front and 35 in the rear...
front always needs more.... it has all your weight and the engine too!
BMW CCA # 418268
      04-02-2008, 10:38 PM   #14
FreeBMW.net
27
Drives: 2008 BMW 135i
37.5 front & 36.2 rear is what I found to be good start point....45 deg air temp cold tires is how it was set.
      04-03-2008, 07:17 AM   #15
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Is anyone going to switch to Nitrogen in their tires? I want too, but I need to find some in the Chicago area.
      04-03-2008, 08:32 AM   #16
Lester
295
Drives:
I am going to switch to helium. This will make the car lighter by about 200 lbs.
      04-09-2008, 10:54 PM   #17
TazioNYC
37
Drives: BMW 135i
Mine were 40 all around...lowered them to 36 all and now my car pulls slightly to the left...sigh.
Search this Thread:
Advanced Search
