      03-29-2008, 10:35 PM   #1
white911
white911's Avatar
16
Drives: 135I - white/coral red - sport
steering arm to rim clearance
I followed the thread about putting 255s on the front. Where does the extra 37mm go? I put the car on the lift again today to measure the sway bar sizes. When I moved the steering to full lock I noticed very little clearance (3mm) between the steering arm and the standard wheel and tire combination. The picture is shot looking up toward the steering arm and the wheel showing the relationship at full lock.
It seems clear that one must limit the steering lock in order to use wheels with more inboard offset.
Alan
08 135I (AW/Coral Red - delivered 3/15/08 --
13 Audi S4, 83 SC (trackster), 90 C2 (Sally's Carrera), 04 Avalanche Blingmobile
      03-30-2008, 12:56 AM   #2
gizmo
16
Drives: 135i
Thanks for posting the picture.
What size & offset wheels were you using?
2008 135i Premium/Sport/Cold CA/HiFi
      03-30-2008, 06:30 AM   #3
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Thank you , Alan, for showing so succintly what I was trying to describe. Those were the OE wheels and tires, right?
      03-30-2008, 07:18 AM   #4
white911
white911's Avatar
16
Correct, OE wheels and tires, 215/40-18
Alan
      03-30-2008, 07:20 AM   #5
larryn
I did turn the wheels, and did rub at full lock. I would never run that setup on the street, but for autocross or track events, you're in serous trouble if your needing to get to the steering lock. Most cars that I know of in more prepared classes rub while at lock.
I'm about to go out into the garage for a day of fun under a couple of the cars, and I'll see if I can mount those wheels back on and take a spin. I have a lot to do out there, and it's at the end of the list though.
      03-30-2008, 07:20 AM   #6
Lester
295
Drives:
This would preclude using cabe chains on the front, I suppose?
      03-30-2008, 10:21 AM   #7
gizmo
16
Drives: 135i
Oh, I misunderstood your post -- though the steering clearance with with 255 on it. This makes aftermarket wheels/tires a bit difficult.
      03-31-2008, 04:44 PM   #8
ersatzS2
16
Drives: 135i
Alan, was the wheel at full droop here, or was it supported somehow? In other words is the clearance issue as tight when the suspension is loaded? Does the relationship of tire to that AL member change under load?
135i built 2/14/08 SGM w/Black and AL, 6 forward gears
      03-31-2008, 04:54 PM   #9
mikeo
Santa Fe Concorso
mikeo's Avatar
Originally Posted by ersatzS2 View Post
... In other words is the clearance issue as tight when the suspension is loaded? Does the relationship of tire to that AL member change under load?
I'd like to know that answer also.
      03-31-2008, 05:57 PM   #10
white911
white911's Avatar
16
Good point, the relationship does change; probably an inch of clearance at normal ride height. I could not verify that with someone holding the wheel at full lock, the steering backed away from full lock on its own.
Alan
