The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Rear shock rattle
      03-27-2024, 02:56 PM   #1
Stemmonsethan
Drives: 2007 Bmw 335i
2007 BMW 335i  [9.50]
Rear shock rattle
After installing some medium priced coil overs I realized a rattle when I go over bumps and such and am wondering if anyone else has had this issue and how to fix it
      03-28-2024, 08:02 PM   #2
vester86
97
Drives: BMW 330D '08
tighten up whatever is loose. probably the upper mounts (inside the car)
      03-29-2024, 07:51 AM   #3
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
Did you replace the mounting hardware? It is essential on a 100k car or you’re cheap.
      04-03-2024, 11:39 AM   #4
whyzee125
1704
Drives: Dinan stage 2 335i
What coilover set did you go with? Did you replace the mounting hardware? Any other mods to the suspension? Did you torque everything to spec at ride height?
tcphoto3558.00
      04-04-2024, 09:14 AM   #5
tcphoto
tcphoto's Avatar
This is the final and I suspect the most overlooked step, I imagine a lot of bushings have been torn from torquing while lifted or noises afterwards.
