03-22-2024, 07:57 PM | #1 |
52
Rep 194
Drives: 2024 X3 M40i, AW
2024X3 M40i w/ M Sport differential
Hi All,
Swapping my 2020 x3 m40i for 2024 one with m sport diff, however, I have a question about winter setup. I currently drove four years worth of winters on 19" rims w/ scorpion 235/55r19 square setup and it worked great, however, i know that this winter tire spec is slightly off of size of the original BMW 19" winter spec tires and I'm wondering whether I'll be damaging m sport differential with this kind of winter setup and should change my winter tires? Car will come with 699M 20" summers. Any input? Thanks! Last edited by bde; 03-22-2024 at 09:24 PM.. |
03-22-2024, 09:10 PM | #2 |
143
Rep 416
Well, this post got my interest when you mentioned ruining the m sport differential. I have never heard of this, but it certainly doesn't mean it's not a thing.
Using Tirerack, I entered your particular tire into their configurator and got two winter tire results. They didn't warn about any potential problems this tire setup would have on the differential. Tirerack is usually good at pointing out things that might adversely affect your vehicle if it has certain options. |
internalaudit19.00 |
03-23-2024, 03:04 PM | #3 |
24
Rep 43
bde ,
I have a 2023 M40 with the M Sport Differential. I am also running the same size winter tire as you, but mine are Michelin X-Ice SUV tires. I have not had any issues this past winter. The differential is basically a limited slip as I understand. The tire size doesn't matter so long as its the same size on both right and left. I also have the factory spare, which is way smaller in diameter....if used in the rear, the car must figure out how not to blow itself up....at least I can only hope Regards, George |
03-23-2024, 06:09 PM | #4 |
339
Rep 734
I've always been curious about this, am I correct in assuming M Sport Diff is BMW marketing speak for a common LSD?
2018 BMW 530e Alpine White | Black Napa Leather | Bone Stock
03-23-2024, 07:15 PM | #5 |
DINAN SELLER
189
Rep 576
yes standard on all M models.
2024 X3M COMP, 2019 X3 M40i DINAN, 2015 335xi DINAN stage 4, 2014 BMW i8, 2010 M5 V10 DINAN S2
03-23-2024, 07:37 PM | #6 |
Internet Weasel
781
Rep 768
Drives: 2023 X3 M40i
Or, if you're running square, you could move the front tire to the rear and the spare tire to the front.
03-23-2024, 07:40 PM | #7 |
588
Rep 1,092
03-23-2024, 10:16 PM | #8 |
339
Rep 734
M model as in the real M cars or the M Performance ones like our M40i? I had assumed I had an open diff, since I didn't remember seeing any mention of a diff in my build sheet.
03-24-2024, 08:48 AM | #9 |
52
Rep 194
Thanks all for replies!
I also talk to my tire shop and they said - no known problems in 4-5 prior years with any x3 m40's with respect to this so I think I'm good) With respect to M diff option it doesn't come standard in North America I think and you have to option it- Europe is different I believe. Also, I think the M diff in the M40 is electronic vs mechanical differential in the real M model. Correct me if I'm wrong |
03-24-2024, 08:51 AM | #10 |
1298
Rep 974
Could be wrong, but don’t believe it’s standard on M-lite vehicles (I.e. M40i), just an option. I’m sure it’s probably standard on actual M cars tho. It was one of the only options I didn’t care about when I was building, but I ended up buying a dealer spec that was 97% of what I wanted (and the M Diff was already on their spec, so I ended up with it).
I too read about the mismatch issue… and also their mention of using incorrect TIRES as well. But I concluded that stock sized 19 inch option with All-Season tires would be acceptable since I knew there were plenty of forum members running this setup. I haven’t looked in a long time, but I want to say the owners manual actually even says the M Diff is only supposed to be used with summer tires, or something like that. It’s really weird. |
03-24-2024, 09:40 AM | #11 | |
2775
Rep 4,347
The BMW HAG215 as optionally fitted (standard in some markets) to the G01 M40 is an active electromechanical regulated locking GHAS limited slip diff, so more advanced than common basic mechanical LSD. The HAG215 M Sport diff design is based on the HAG225 diff used in a true M F97, but it is not the same part, although both employ the same active electromechanical approach. Look for option code 2T4 M Sport Differential on the VIN to check the type of diff fitted. Last edited by avi66; 03-24-2024 at 10:56 AM.. |
03-24-2024, 09:43 AM | #12 |
2775
Rep 4,347
The BMW M Sport diff option code 2T4 is standard on the G01 M40 in the UK, but afaik it’s not an option on other G01 models here.
It’s an option in the US market on M40 afaik. Last edited by avi66; 03-24-2024 at 10:07 AM.. |
03-24-2024, 01:52 PM | #13 | |
462
Rep 399
03-24-2024, 07:29 PM | #15 |
588
Rep 1,092
Definitely. $1400. In my build, I didn't get it as I'm not driving it hard and the fact it would have delayed things 3 weeks because BMW Spartansburg was out of stock
03-24-2024, 07:33 PM | #17 | |
10210
Rep 8,644
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
03-24-2024, 07:39 PM | #18 | |
588
Rep 1,092
ASAP10210.00 |
03-25-2024, 04:48 AM | #19 | |
2775
Rep 4,347
I have no desire to drift an SUV lol. |
03-25-2024, 04:52 AM | #20 | |
2775
Rep 4,347
Here’s what BMW claims, and notice how there’s no mention of F97 X3 M like performance or drifting, shock…. Last edited by avi66; 03-25-2024 at 05:09 AM.. |
03-25-2024, 08:25 AM | #21 | |
10210
Rep 8,644
In the X3M it's a performance setup... in the M40i, its a safety / traction setup. Also - many people are looking to slide / drift their suv... have you driven an X3M? It bends physics... https://youtube.com/shorts/gjleTZbX0...Qtu2n1YOqB7Yjr
03-25-2024, 09:05 AM | #22 | |
2775
Rep 4,347
Yes, I’ve driven an X3 M Comp, and owned plenty of very fast sports cars, but the F97 or M40 isn’t a very fast sports car, it’s a capable family SUV. As for drifting, buy a car designed for that if it’s your thing. I can’t say my what do a I want from an SUV list has ever had drifting on it, but something that improves traction performance and offers better handling would be. |
