03-13-2024, 10:53 AM | #1 |
81
Rep 321
Bimmercode - disable startup warnings on idrive
Seems like on older BMW's I had way more options to change.
I was just looking for a way to disable the startup warning message on idrive6. (2020 X3M) Didn't even see it in there. Just wondering what else you guys usually code off in there? |
03-13-2024, 12:28 PM | #2 |
Rep 23
Headunit (HU_NBT_EVO) > Warning at start-up > Not active (off). It's toward the bottom of the list.
You can also turn off the camera warning right next to that. |
03-13-2024, 12:36 PM | #3 |
554
Rep 542
Drives: 2022 X3MC
You can also disable the DSC popup when turning it off...
HEADUNIT - > Advance (3008 FES STABILITY_CONTROL_POPUP) -> not activ
'00 328i // Sold
'04 Z4 3.0i // Sold '22 X3MC LCI |
joebie3334.00 |
03-13-2024, 01:06 PM | #4 |
81
Rep 321
03-13-2024, 01:48 PM | #5 |
81
Rep 321
Well, it looks like bimmercode wont allow me to access the headunit section. it says its not in the correct format.
This error seems to stem from the coding I had done remotely to update the nav system and then code full screen apple car play... I'll try my diagnostic tool and see if that gets me in (Launch X431) |
03-13-2024, 03:38 PM | #6 |
554
Rep 542
Drives: 2022 X3MC
No, you still need to double press to confirm. Just gets rid of the popup on the head unit screen that says it's off. This way your passengers won't know what's coming
'00 328i // Sold
03-15-2024, 09:28 AM | #7 | |
Rep 16
03-15-2024, 06:24 PM | #8 | |
81
Rep 321
Bimmercode will do any other module I have except the headunit. |
03-15-2024, 11:06 PM | #9 | |
Rep 16
05-08-2024, 07:56 PM | #10 |
81
Rep 321
So I decided to spend the $80 for a Protools coding license only to find that there is no section in there to disable to startup chimes in the Headunit area...
That's not cool at all... |
05-08-2024, 09:07 PM | #11 |
986
Rep 1,709
Drives: 22 X3MC MBB - C-17 Globemaster
What are you trying to code off? I have seat belts and all warning messages X 3 turned off. The only one I have is drive assist Plus and MDM mode on, which I'll probably figure out how to code off this weekend as it interrupts my youtube...
