02-22-2024, 12:38 PM | #1 |
Rep 23
Drives: BMW 430d Coupe 2014
Normal rear lights into clears??
Hey guys, I’ve currently got a set of GTS Style rear lights and im wondering if it’s possible to change them to clears? Rather than buying another set. Is it even possible by dismantling and applying a clear front? I don’t know, I’m no good with this sort of thing🤣
I’d love to have a set of clears!! TIA |
02-23-2024, 08:16 AM | #2 |
295
Rep 484
This is inline of what you are asking about:
https://f30.bimmerpost.com/forums/sh....php?t=2035131 Short answer - buy the clear lens ones if readily available.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
02-23-2024, 05:02 PM | #3 |
648
Rep 1,386
Lenses are readily available but the rears are plastic welded on using friction/vibration.
Don't attack the job with a dremel or vibrating saw, you want an ultrasonic knife cutter.. a super thin blade that won't remove too much material. I took my GTS foleds off to modify full well knowing they most likely get damaged, sure enough they did so I switched back to my blackline lci's.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
02-23-2024, 10:28 PM | #4 |
295
Rep 484
I can't seem to find clear lenses as was asked by op. Red ones - sure, all over the place for F30/31 and for F32/33/36, even for F34 GT are also available. ...and they priced so high, simpler to buy a new complete set of lights with clear covers for approx $450 usd + shipping.
02-24-2024, 12:51 PM | #5 | |
648
Rep 1,386
Admittedly they tail light lenses only became available to the public in the past few months, so like the headlight lenses they'll be priced a little higher until competition drives them down. If you do end up buying a new set and want truly clear ones try the V2's, not only are these actually clear lenses (not grey smoked ones like the V1's) but they use a proper replica design with individual led panels, these are the closest we will get to "cheap" GTS lights.. https://streamable.com/ncmgfp Also for anyone considering front/rear lenses buy from aliexpress/alibaba. No matter who you deal with they're all importing them from the factories on there selling them. I waited 3 months for some to come from Europe which claimed to be "better than Chinese copies" and they were horrific, tabs didn't fit and the lenses had a mottled/orange peel finish on the front which made the light appear hazy. I went direct to the factory sellers on aliexpress in the end and bought an oem grade pair for 70% less.
2015 435i - 401whp
Oksamit78294.50 |
