Is Menzerna IP neccessary
05-26-2006, 11:51 AM | #1 |
Rep 29
I will be detailing the hell out of my car this afternoon and was wondering if you guys think the first stage of Menzerna IP is neccessary to remove swirl marks. I have a jet black e90 and I wouldn't say the swirl marks are out of control but are definately noticeable. Here is what I was thinking for my procedure. I would rather spend more time with the Menzerna if it improves the shine considerably. Don't want to take any shortcuts to sacrifice shine.
Claybar Menzerna IP Zaino ZPC Zaino Z5 Thanks. Dankoristic |
05-26-2006, 11:58 AM | #2 |
24
Rep 472
I would try Menzerna FP first. I have never used Z-PC so I am not sure how agressive it is.
Are you using the Porter Cable or by hand?
2006 330xi
BMW, please get rid of the RFT's and give us a spare tire! |
05-26-2006, 12:00 PM | #3 |
Rep 29
Using the PC.....Also, I'm guessing I use the PC for the Menzerna IP and Zaino ZPC......should I switch to hand application for the Z5 or stick with the PC for the final coat?
05-26-2006, 12:11 PM | #4 |
24
Rep 472
When using Z5 and Z2, do it by hand. You are not supposed to use too much of these products to begin with. I think you will waste more of it trying to get the pad wet.
2006 330xi
05-26-2006, 02:41 PM | #5 |
28
Rep 581
First try Zaino ZPC with your PC and a foam polishing pad. If that does not do the trick, try ZPC with a cutting pad, then followup with ZPC on a polishing pad. If that still does not cut it for you, then try IP with a cutting pad, followup with ZPC on a polishing pad.
As for Z5, I apply it by hand with no difficulty. Out of curiousity, did you buy your Z5 recently? If so, what colour is the cap? White or blue? |
