      03-14-2008, 07:40 AM   #1
Sciacallo
Drives:
Western digital 160 Gb
My question is,the hard disk portable WD 160gb go with the sisteme on BMW 135i with navi professional??
caratteristics:USB 2.0 interface; 5400 rpm; 12 ms average seek time; WD Sync software; up to 480 Mbps data transfer rates
135 Driver..:w00t:
      03-14-2008, 12:56 PM   #2
john970
1er
73
Drives: 08 135
My feeling is most drives are going to require a power adapter. I am getting a 16 or 32gb flash stick, much easier to bring in and out of the house and update, and my DRM stuff is going on a 4GB ipod nano (1st gen).
You can get a 32GB stick for about $150, 16GB are around $50 (in the US).
      03-14-2008, 02:54 PM   #3
Stew
Drives:
There is a cut off regarding the power adapter, for example, if the hard drive pulls too many amps to spin and run the disc, you will need a power adapter that most likely will plug into the cigerette lighter. But, if the hard drive doesnt pull too much amperage, then the USB connection will be enough to power it. I am thinking those WD drives might be low enough to be powered by the USB port alone...you will need to find out how much power it draws, and how much power the stock BMW head unit puts out through USB...(I found this information on my Sony head unit I bought as an upgrade to my stock CD/radio, maybe BMW's stock radio has the same info, anyone know?)
If the HD works via USB only on your PC, will this mean it will work via USB only on y our car's radio head unit?
      03-14-2008, 03:04 PM   #4
john970
1er
73
Drives: 08 135
I think this is the 4th time I've posted this but here goes:
USB spec is 2.5 watts (5V @ .5 amps), which isn't enough to power 99% of the 2.5" laptop drives that are usually used in the USB travel drives. Some are 1.8", which will work. These usually top out at 100GB.
Some USB ports exceed the spec, and will work. We don't know how much power the usb port on the bimmer puts out yet and how it handles overdraw. Some drives just need a little extra juice to spin up and may be tolerated by the port.
I'll plan to post on this when I get my car.
      03-14-2008, 04:05 PM   #5
vivid
vivid's Avatar
England
40
Drives: 135i, 323i
I have been told the USB port on the BMW is only powerful enough for a 4200rpm HD... I am no expert but I wanted to pass this on...
Current: 135i, 323i wagon.
Sold:GTI
Sold: FX45
Sold: E36 M3
      03-14-2008, 04:25 PM   #6
Stew
Drives:
Are 1.8" HDs 4200 rpm and not 5400 rpm? I think 80-100 GB for a HD for music would be sufficient, especially comparing its cost to that of an ipod. I havent researched it much, but thanks for posting the info here again (and again, and again heh)
      03-14-2008, 05:59 PM   #7
john970
1er
73
Drives: 08 135
The platter speed is only one component of the power draw. There are plenty of 5400rpm drives that draw less power than 4200rpm drives.
Ergo - this isn't true.
      03-14-2008, 06:01 PM   #8
john970
1er
73
Drives: 08 135
The issue with 1.8" drives is cost, an 80GB 1.8" drive is about as much as a 250gb 2.5" drive or the new 320gb drives if you can find a deal on them. 5400rpm drives are typically faster depending upon the capacity, but this isn't a big deal unless you continually swap out your music collection on the drive. Newer 1.8" drives can usually write between 15-20MBps sequentially, which is pretty speedy.
The "classic" iPods have 1.8" hard drives in them. They usually draw under 2 watts.
      03-14-2008, 07:06 PM   #9
Stew
Drives:
Hmm I did a search online but could not find out what the wattage of the WD hard drivers is. from this link it suggests that the 120 GB portable HD is a notebook HD that uses 2 watts, which should work (dont know about the 160 GB HD). Can anyone confirm the wattage?
      03-14-2008, 07:29 PM   #10
Stew
Drives:
Ok did some more searching and found this WD Spec sheet (for 60-120 GB HDs). On the second page, it lists External Power (optional) as 5V 1.0 amp, which would be 5 Watts, so when we find out the power out put of the BMW USB connection well know if the WD drives will work.
      03-15-2008, 01:15 PM   #11
john970
1er
73
Drives: 08 135
The WD 160GB uses a WD1600BEVS, which pulls about 2.75 watts plus the enclosure.
      03-15-2008, 01:34 PM   #12
Stew
Drives:
Plus the enclosure? Does the BMW ipod set up have two usb ports? if so you can use the power cable WD sells which is a USB Y cable for the extra power
      03-15-2008, 04:35 PM   #13
john970
1er
73
Drives: 08 135
The Y cable is for a power adapter that you either plug into the wall or a cigarette adapter, it's not for two usb ports. They would share the same power bus in any event.
The bimmer has 1 usb port.
      03-15-2008, 07:07 PM   #14
fuhgetaboutit
10
Drives: 2006 330i
I'm really amazed at people needing 160 gb of music in there car. I have the ipod adapter on my E46, using a 8 gb ipod nano, and I still haven't filled it up after 2 years.
Granted, some of that is because I only put on individual tracks, not whole albums. And this is the first-gen adapter that only allows 6 playlists (as it pretends to be the six-disc changer).
I imagine having access to virtually unlimited playlists with the ipod adapter in the 1er will result in me putting more music on it.
But still, 160 gb is 20 times the capacity of my 8 gb nano that I'm challenged to fill up now.
