Classifieds Sponsors Classifieds    Brake Disc Upgrade Options : Steel and CCB
      01-30-2024, 03:23 PM   #1
TritonMotorsports
9
Drives: N/A
For those looking for aftermarket brake disc options, we have the perfect upgrade options : Steel and CCB/CCM discs.
Our steel brake discs are true two-piece floating design as opposed to the quasi two-piece design of the OE discs. The weight savings aren't huge on any of our BMW specific discs since BMW OE discs use aluminum hats as well (unlike other OE brands that use iron hats in their two-piece discs). However, being true two-piece discs, there is more room to expand and hence less chances of premature failures due to heat cycles.
What really sets us apart is the R&D as well as the manufacturing process. When we design the hats and the rings for a new platform, we run them through at least 125 heat cycles to make sure that everything stays within tolerance. During the manufacturing process, the rings are put through extreme heat treatment which weeds out any rings that might warp. If a ring warps, it is moved to the recycle line and a new ring is manufactured. Additionally, our discs have directional ventilation vanes which help cool them fairly quickly.
Lastly, so people understand our confidence in our products- we test and run our brakes on our personal cars as well at Triton Motorsports. We have some heavy SUVs and some FI V8s as well that can hold their own against supercars.
Fitment is the same as factory and you won't need to modify anything.
Various machining patterns are available to meet your needs- relaxed daily drive, aggressive daily driver, track duty etc.
For those interested in the CCB/CCM options: Triton's Gen 3 Carbon Ceramic Brake Discs represent a remarkable leap forward in automotive braking technology. With their innovative 3D bonding of long carbon fibers, these brake discs achieve unparalleled strength and lightness, making them one of the best options available in the market. The OE CCB discs contain chopped carbon fiber which makes them more brittle and they cannot be refinished (aka serviced). The Gen 3 discs, due to their long continuous fibers, are stronger and can be serviced up to 3 times. What that means is that they will basically outlive your car once installed.
Our CCB/CCM discs are available as 2 options- direct replacement for factory CCBs and direct replacement for factory steel discs where you will utilize your existing brake calipers with the appropriate brake pads.
If you have any questions, please feel free to reach out to us.
Here's our website:
www.tritonmotorsportsusa.com
Here's our email:
info@tritonmotorsportsusa.com
Tags
bmw brakes, bmw m3, bmw m4, bmw m5, brake discs, brake pads, brake rotors, ccb, triton motorsports
