02-25-2008, 11:00 AM | #1 |
Helping thru Design
9
Rep 162
A little tid-bit on the ZF box.
Second-generation 6HP 6-speed automatic transmission: faster than human perception
The second-generation 6-speed automatic transmission is undoubtedly a fast transmission and is designed for torques of up to 850 Newton meters. At the heart of the transmission are the turbine-based torsional dampers for gasoline engines and a dual damper converter for diesel engines. They are able to bridge the converter slip period much quicker and therefore result in more direct engine integration for greater responsiveness and optimized fuel consumption. In contrast to the predecessors, the gasoline engine reduces fuel consumption by three percent while the diesel engine saves six percent. A hydraulics system and control software now make it possible to downshift multiple times without any loss of time and also reduce reaction times by 50 percent to below the threshold of human perception. Here is a good link also. http://www.just-auto.com/article.aspx?ID=90340 Cheers, M |
02-25-2008, 12:15 PM | #4 |
Rep 122
Yes, but they said that one might never be produced. It was unclear exactly which one was going to be in the N54 equiped 3 and 1 series. The 28 is good to 700 nm 515 ft/lbs. Still good for mods, but not bulletproof. I will have to drive one though now to be sure. I had my mind made up on manual, but this is good info.
02-25-2008, 01:16 PM | #5 |
PCA, BMWCCA
102
Rep 2,058
I'm assuming each paddle (L and R) can shift both up and down the gears? If so, that's a real shame...
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
02-26-2008, 07:39 AM | #7 |
386
Rep 1,660
02-26-2008, 08:05 AM | #8 |
Helping thru Design
9
Rep 162
Actually I did see somewhere someone did it. In other reads by searching the net i came across that the same box is in the Maserati Quattroporte and many other cars.
I find it good news because this will be my first automatic. When I read that you could downshift skipping gears, in neutral at stop and was very very fast at shifting(faster then a human) i was relieved very very relieved. I still would like a manual but i cannot justify it as my daily driver in traffic and with a child in the backseat. sigh* M |
02-29-2008, 12:22 PM | #10 |
Traveler
8
Rep 173
This is a link to a press release from ZF describing the transmission.
http://www.1addicts.com/forums/showthread.php?t=3145 |
