M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Misfire high rpm limp mode bm3 stage 2+
      01-18-2024, 05:32 PM   #1
Shawqi90210
22
Drives: E92 M3
Hey guys I have a 2017 m2 it’s currently full fbo and I just put a b58 tu pump in I decided to try the the bm3 stage 2+ e30 map and it was running perfectly for 2 days I took it to 160mph no problem or hiccup. Today on the way back from work I was racing a mustang and I went 3rd gear and took off after I passed him my car started misfiring high rpm and went into limp mode. This use to happen on stage 2+ 93 I assumed it was the fuel pump at the time… but I just upgraded it. I have colder plugs and also percion race work coils I’ve heard they can cause a problem but I don’t see why.
Unfortunately I didn’t get a log of it happening
If anyone can help diagnose or if anyone had a similar problem
Mods:
Eventuri intake
Charge pipe (vrsf)
M performance exhaust
Catless arm downpipe
Arm gold intercooler
Turbo to intercooler inlet
Precision race work coils
Step1 colder plugs
3.5 map sensor
B58 tu pump
      01-18-2024, 06:35 PM   #2
-Eidos
@lbb_kev
496
Drives: 2018 BMW M2 (LBB)
Mods:
Eventuri intake
Charge pipe (vrsf)
Step1 colder plugs
3.5 map sensor
B58 tu pump
Is the car still doing it? If not, then try logging a pull with all of the nannies turned off.
Without any data you'll be just throwing darts in the dark and start randomly replacing items.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      01-18-2024, 06:43 PM   #3
Shawqi90210
22
Drives: E92 M3
Yea I’m going to try to get it to come back again and get a log tomorrow. Everyone is having complaints about ots maps to be honest I might just switch to custom map soon
      01-19-2024, 01:13 PM   #4
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
It's not OTS's problem. You only gonna run more aggressive with custom map. Can't diagnose anything from these misfire codes since they are so common. like @Eidos said, it could be caused by a lot of things. Logs would help a lot.
m2
