02-17-2008, 11:03 PM | #1 |
Donkey Kong King
89
Rep 1,129
Where's the 12volt plug(lighter plug)??
Where is the lighter plug (12 volt plug) in the 135i?? Just wondering where I will put my radar detector power adapter....
thanks |
02-17-2008, 11:54 PM | #2 |
TwistedHouse
Rep 55
It depends if you'll be adding the storage compartment package i think.
Otherwise there should be one underneath the armrest (in between the 2 seats) and one in the ashtray in front of the gearstick. |
02-18-2008, 10:27 AM | #3 |
Santa Fe Concorso
103
Rep 2,984
You're not considering hardwiring it?
02-18-2008, 09:29 PM | #4 |
32
Rep 573
2008 128 - retired
2010 X5 - retired 2013 535 - retired 2015 X1 - retired 2020 X5 M50i - On Order |
02-18-2008, 10:36 PM | #5 |
Santa Fe Concorso
103
Rep 2,984
I can pretty much guarantee there will be Do-It-Yourself instructions on 1Addicts within a matter of days after the 1-Sereis is released. Or, take the DIY info to an car audio shop, they'll hardwire it for you.
02-19-2008, 09:51 PM | #6 |
Rep 55
Hardwire is the way to go, but make sure it's a switchable circuit so it turns on and off with the ignition. On my MINI I tapped into the heated seat fuse. Hope to do same with 135.
02-20-2008, 09:14 AM | #8 |
Rep 295
Well, some places sell connectors that you can plug in to another connector under the dash that allows power to be taken off at that point. Those are completely removable. In some cars, ther eare also unused connectors that you can get power from just by installign a fuse, depending on the options you got.
Like someone else said, I'm sure people will figure this stuff out pretty quickly after the cars are available. |
02-20-2008, 09:53 AM | #9 |
2146
Rep 10,176
02-20-2008, 05:27 PM | #12 |
50
Rep 1,474
Drives: 135i MT, LMB, ProNav
Yes I was pondering the same question as well. With the lighter plug located under the arm rest instead of the dash like most cars, the lighter cord has a long way to stretch to the detector on the windscreen. Looks like hardwiring is the way to go.
Fun Car: 135i Manual LeMans Blue / Beige Leather / Grey Poplar / pro nav / euro plates. Delivered 24 June 08 Family Car: Land Rover Discovery 4 SDV6 Spare Car: Volvo V70 Sydney Car: MB 420SEL |
02-20-2008, 06:28 PM | #13 |
2146
Rep 10,176
Is it different for you 'others' down under? :wink: Here we get one under the armrest, and one in the ashtray, right at the dash.
03-09-2008, 01:14 PM | #14 |
Rep 66
Can u remove the radar if it is hardwired? Don't want some punk smashing my window for a radar detector.
03-09-2008, 01:55 PM | #15 |
2146
Rep 10,176
03-18-2008, 01:47 PM | #17 |
388
Rep 1,660
Guys. Hardwiring in BMW's is really easy. Using a voltmeter locate an unused spot in the fuse box, turn on the ACC and determine which one is on. Use a standard spade lug on the power wire in question and slide onto the unused fuse location. For the ground any metal surface will do. Just find a screw and put the ground wire on it. That's it.
Takes all of ten minutes maybe. |
