02-02-2008, 04:40 AM | #6 | |
23
Rep 1,356
Thats not true.. PROcede has been known to be boosting (uncontrolled) into the 15s...! I'd be more apt to get an ECU flash, than a piggyback. Dinan or the soon-to-be-released Shark Injector! That way your factory warranty stays intact. -Garrett |
02-02-2008, 07:22 AM | #7 |
59
Rep 765
True uncontrolled boost spikes have been recorded by some! Though I know Shivam has been working towards stopping that. I haven't really followed PROceed in a while. I need to see if I can get him over here see what going on with it.
02-02-2008, 08:09 AM | #8 |
157
Rep 2,231
A few users with boost spikes out of a thousand users is not a big deal. No motors have exploded as a result of this. All the more reason to get a boost gauge with boost peak play back / boost peak warning. Procede also allows you to monitor boost levels on your laptop. Users with spikes can easily set the TQ settings lower. An ecu flash cannot be sold or cannot be adjusted to the users liking. If you are worried about the warranty then this is not the game for you. If anything happens pull out the Procede and take it to the shop. It takes 30 minutes. No biggie.
02-02-2008, 08:40 AM | #9 | |
23
Rep 1,356
The older PRocede 1.47 map seemed pretty reliable and after close to a year he finally got that refined, but the whole move to V2 has been somewhat shaky. Are you saying YOUR having a problem with YOUR PROcede, I'm confused with your last sentence... "..get him over here see what going on with it." ...?????? eunosracr, a boost guage will only tell what PSI you were running when your engine blows. If someone overboost, they have no control over what to do in that millisecond after he notices the alarm. The dmg is done before any human can react. Boost guages are a novelty...! Secondly, none of that mambe-jambe you mentioned (ie: monitoring boost levels on your laptop, boost guages, TQ settings, removing before the a dealer visit, etc) are neccessary with an ECU flash. You certainly didn't do all of that nonsense when your car was stock, so why bother with it once you've had a professional tune...? With an ECU flash, you flash and forget! Their rock solid and should be, their actually a "tune" of a chip. For this level of engineering, you do have to pay more. But, then again you get more! |
02-02-2008, 10:05 AM | #10 | |
157
Rep 2,231
02-02-2008, 12:06 PM | #11 | |
23
Rep 1,356
Wait... you know how to tune a car..? Because, your whole post implies you need to take the lead when it comes to customization and tell a tuner exactly how you want it to work...? Are you kidding us..? What do you mean by this..? Do you realize it would cost uypwards of $4-6k to have a professional tuner, fly in and do custom work. How is it that your so special and need custom work done..? Managmenet thats so precise and elaborate the the engine's ECU just wouldn't do..? There is only one outcome coveted from a tune, which is nearly identical for everyone; the most efficient burn possible under the safest valuables allowed, without harming the engine. -j. Brōōch So, what professional tuner hase done custom work for you..? Did you bore the engine out, thus needing a custom tune..? Hunh? eunosracr, Do you honestly think that hooking a laptop to a piggyback and adjusting a torque setting is tuning your car? LOL....! Here is something so simple to prove your ignorant of what you speak. Do you realize that a Dinan Flash, or a Conforti Shark will know what Octane gas is in your car and adjust accordingly With a piggyback, you have to manually download a map for such a feat! Wow... does that make you feal special... or closer to your tune? Like you somehow have done something "tuner like" ..? You still have to download the right map for your octane.. and some piggies have a neat trick where if you hold down a button and press another... it loads whatever map you had in that bank. Neat trick and sounds all dark and secretive.... Sorry just not needed for Dinan/Conforti..! Matter-of-fact, when your pounding on your car out on the streets or at the track you don't have to think about anything related to tuning. Like anything proffesionally installed, you just don't have to worry about it. ECUs control of over 2,000 engine functions. A piggyback is a harness that can only fool up to 11 - 12 of those...! Piggybacks are not "tune", because they havn't tuned anything... they piggyback on top of the tune, thus their name! Now that we've established how little you are actually involved with the actual tuning of your car..... we get to hear with how a GUAGE can save your BMW engine..? Because a boost guage does nothing... it just indicates what the engine is doing. You have no control over it... and if it does squak at you, your already too late. These engine are 10.2 to 1 compression, 5psi over and your engine might not recover. But it's a good thing that the ECU can see this and clamp down on it in milliseconds, before a human being could actually register it in his mind, let alone react to it...! So if your overboosting, you have a bad piggy design. And a boost guage will do nothing to fix or stop it. Though, they are kewl to look at and makes you feel more "in-tune" with your car. Ebay says people who buy this usually go with a BOV too. But all the pozers like to be noticed... and heard! |
