11-30-2023, 09:09 PM | #1 |
Rep 14
Seized Brakes. Any opinions appreciated
Car:2015 BMW M235i 6spd (70K miles)
Background: I was driving down the highway and about 25 mins into my drive I noticed a vibration coming from the rear of the car. No warning lights were on and nothing other than the small vibration seemed out of place. I drove a couple more mins when the vibration got to a point where I figured I better pull off. When I got off the highway and came to a stop I got out and saw both rear rotors glowing orange. Shortly after that I heard a hissing noise (What I believe to be the brake line failing) and a bunch of smoke from the rear wheel wells. Once I got back in the car to move it somewhere safe I noticed the brake pedal had lost pressure and all the brake fluid was out of the reservoir. Had car towed to a shop where I was quoted $4K for new rotors, brakes, calipers. The cause they said was a failed brake line causing brakes to seize up. This is the opposite of the order of events and I had pressure till after the line broke. Any suggestions to the cause of the problem would be helpful as I was not given a reason for failure just parts to replace without resolving the cause of the failure. New to this platform. Appreciate any insight! |
11-30-2023, 10:56 PM | #3 |
115
Rep 282
When is the last time you had a brake flush and a full brake inspection?
2019 M240i, Melbourne Red, Black Interior. 3M Tint, Premium Package, Harman Kardon, Adaptive LED Head Lights, M Performance Exhaust and Diffuser, Chrome Exhaust Tips, 719M Bi Color Wheels, Black Kidney Grille, Burger Tuning JB+.
12-01-2023, 08:30 AM | #4 |
447
Rep 1,272
$4k! Find another shop. Try www.bimrs.org.
dradernh4485.00 |
12-01-2023, 08:44 AM | #5 |
Rep 14
So you are saying the parking brake could have been stuck and there was no warning on the dash? Would that get both rotors hot enough to make them be completely orange?
12-01-2023, 08:45 AM | #6 |
Rep 14
12-01-2023, 09:29 AM | #7 | |
3078
Rep 1,827
Calipers can definitely seize but it's rare for both at the same time in a short period like that... I'm thinking it's more along the lines of brake line, fluid or maybe even ABS pump? Last edited by freakystyly; 12-01-2023 at 09:36 AM.. |
12-01-2023, 10:12 AM | #8 | |
Rep 22
12-01-2023, 11:51 AM | #9 | |
347
Rep 1,021
Here is a recent related thread; https://www.2addicts.com/forums/show....php?t=1692014 The system is completely mechanical, so more prone to problems than the hydraulics. ABS pump would be my second guess though. |
12-01-2023, 12:41 PM | #10 |
5593
Rep 5,389
Seems odd that a parking brake pad that engages the inside of the rotor hub would make the main rotor body glow. The parking brake pads are tiny and would die a quick death if they weren't released.
Both rear rotors to get stuck at the same time is really strange and I can't say I've ever read of such a thing happening on a F series car in my 8 years of being on the F2x and F3x forums. I don't see how a failed brake line would impact both rotors. It sounds serious and replacing the brake lines, calipers, rotors, and pads likely isn't going to address the underlying issue. If it were me, I'd replace all those parts myself for WAY cheaper than $4k with a set of used calipers ($400-500) and new OEM rotors ($380), main pads ($120), parking brake pads ($60), two new brake hoses ($120), and a fluid flush ($100). Then I'd drive or tow the car to a shop or BMW to run a dialogistic on the ABS system. The hardest part of this entire job is the brake flush but even that is easy if you have a Motive power bleeder.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
12-01-2023, 12:45 PM | #11 | |
Rep 14
Also I have thought about the hill assist and master cylinder being a potential cause? What are your thoughts there? |
12-01-2023, 03:07 PM | #12 |
347
Rep 1,021
Drum brakes will get glowing hot faster than disc brakes. They are not designed to dissipate the heat as well.
12-05-2023, 02:00 PM | #13 |
244
Rep 528
My guess is that the rear brakes were dragging due to brake fluid pressure in just the rear circuit. That points to the master cylinder or ABS. The hiss was the brake fluid boiling after the main damage was done.
$4,000 seems a little high but if it gets done right you'll be able to forget the sting. But you may need to fix something upstream also. |
12-05-2023, 02:15 PM | #14 |
639
Rep 715
$4k for a Brake Replacement...
Welcome to BMW! Bring My Wallet!!! As noted though, brakes are easy, it's just parts. And seeing as your system completely emptied, you'll need to have it filled correctly, tested, etc. I would change all the hard parts as noted, new flex lines as well being as the system is empty, Stainless Steel all around! Then tow it to the local dealer and let them fill and test it. Cheapest way out. Unless you have more tools or a friend who does. But you can do what you can do and soften the impact of the failure! Good Luck |
Mike F.104.50 |
12-05-2023, 05:32 PM | #15 |
4485
Rep 3,506
Have 2 Series' $2K brake jobs (already an outrageous price) really doubled to $4K? I doubt it.
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
