11-24-2023, 08:47 PM | #1 |
Rep 13
Blind spot detection is not reliable
Mine is 50e, and I noticed several times that the blind spot detection seems not reliable. Recently I got a chance to take this photo. (The camera angle is a little bit lower than my viewing angle) You can see a car in my blind spot mirror but the warning light is not on.
This is not always happening, actually it is good in 99% of time, but I believe the 1% failure worth enough to investigate $15 to buy a pair of those small mirrors. I always trust in simple things more, they are just more reliable. |
11-24-2023, 09:43 PM | #2 |
13558
Rep 20,201
Could be an issue or could be operating as designed. The system uses an algorithm taking into account the speed differential between the two vehicles. So for example if you were passing the vehicle on the right then it may not light up. Assuming you weren't, and your mirrors are fairy accurate, then it looks like it should have as long as you were going above the minimum speed.
You shouldn't be trusting the blind spot to tell you if it is clear. If it is lit then you know it is not clear, if it isn't lit then you need to check for yourself before making a late change.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
11-25-2023, 01:53 AM | #3 | |
1159
Rep 1,364
Rob |
11-25-2023, 07:51 AM | #5 |
285
Rep 755
I believe it works fine in my car, but I do not rely on it. I use my mirrors as intended.
thereef5101169.00 |
11-25-2023, 10:19 AM | #6 |
4503
Rep 7,545
There’s a blind spot area & also the lane change area. Many BMW drivers that don’t use their turn indicator can miss their lane change warning. If the light isn’t illuminated…but there’s a car in our blind spot (like in the pic above)…if you were to initiate your turn indicator to move into that lane…and there’s a car in the blind spot or lane change area…then the steering wheel will vibrate and the light probably would have illuminated.
Can the OP verify that when the pic was taken….were you passing the car that was in the blind spot…or was the car in the blind spot approaching you? I would assume that you were passing or moving faster than the car in the blind spot.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-25-2023, 11:52 AM | #7 |
Rep 13
Alright, here are more details about the situation: I was not changing lane, not over speed limit, that car was approaching from behind.
So far, I couldn't find a pattern for when the warning light doesn't lit, but every time I observed that I believe it shall lit. Some times when I pass a car (not change lane) it doesn't lit, but when I pass second car, it lit. Same happens when cars passing me. So I really don't believe it's because of my speed or if I am using indicator. And if the warning light is not on, I guess that means the car didn't detect the object in blind spot, I hence won't trust that the steering wheel will vibrate if I change lane. |
11-25-2023, 11:56 AM | #8 |
13558
Rep 20,201
You can approach it that way if you want but that is not how the system is designed to work (ie. just because it is not lit doesn't mean the system is not aware of the vehicle). Always checking your mirrors will be the safest way.
11-25-2023, 01:27 PM | #9 |
791
Rep 874
TB explained this a while back too and mine appears to function as he says. I do still think it's kind of odd that BMW chose to make its system work differently than virtually every other BLIS feature on the market--on every other car I own the light is an indication that someone is next to you or in the blind spot and it doesn't make any assumptions beyond that.
M3 - X5 - 911 - Miata - Raptor - Edge
11-25-2023, 02:49 PM | #11 |
Rep 18
Hi,
I have been also trying to understand BLISS and the Lane Departure Warning with active return functions. There are multiple settings like "Expanded" and "in dangerous situations" as well as a number of settings in BLIS section. I am wondering if there is a combo of settings that give us the "traditional" BLIS indication.
2024 X5 eDrive E50
(and a truck) |
11-25-2023, 04:29 PM | #12 |
Rep 13
Yes, I am not sure how many other people would have the same thought as I assumed that the blind spot indicator could take the place of the the small blind spot mirrors. Luckily I fond this before got into any trouble and bought those mirrors.
11-26-2023, 08:29 AM | #13 | |
4722
Rep 8,797
Drives: eVeRyOnE mAD!
11-26-2023, 09:35 AM | #14 |
791
Rep 874
I don’t think anyone is saying otherwise but what’s the point of paying for and including the feature if many owners don’t find that it works reliably—whether that’s how it’s designed or not?
11-27-2023, 12:35 PM | #15 |
2784
Rep 4,415
FYI.. .. Just got back from an interstate drive and found my blind spot detection to be quite good/accurate. 2021 running 03/2022.52
I have my mirrors set as follows: - Drivers side: put head against drivers window, adjust the side view mirror so you just see the side of your car - Passenger side: put head over the middle of the center console, adjust the side view mirror so you just see the side of your car I observed this many times today, at the point the drivers side blind spot detect light illuminated in my sideview mirror, I could see the passing car both in my rearview and sideview mirrors at the same time. The blind spot detection light stayed illuminated to the point where the passing car's rear bumper was about even with my front bumper and then it turned off. I have mine set for early detection. Couldn't really ask for anything better. |
11-27-2023, 04:52 PM | #16 |
Rep 18
hi,
Well, I went in to the menu settings and enabled BLIS and LANE departure warning settings to the most aggressive settings. On my drive, mostly on freeways, of 160 miles, the yellow lights seemed to work as I would want them to...they light up when I can still them approaching in the side mirror and stay until I see them through my side window. As a side note, if you use the driver assist screen, you can see the cars on that screen approaching, passing, and in front of you. It can even tell you the difference between a car and a big "Boxie" truck- in that there is an image of a big boxie truck. I thought that was cool, maybe not useful...but cool.
2024 X5 eDrive E50
(and a truck) |
11-27-2023, 11:01 PM | #17 | |
1002
Rep 832
Two is One and One is None
11-28-2023, 12:45 PM | #18 |
Rep 11
This happens to me as well. I have only had mine for two months but twice now I have gone to change lanes and the indicator was not lit up to show that someone was beside me. I could not see them in the mirror. The only way I was aware of their presence was because I looked over my shoulder. I will check my BLIS and lane departure settings as suggested.
