10-11-2023, 01:18 PM | #1 |
197
Rep 32
Exhaust Leak ?
Hello all,
this is my first post on here but I’ve been a long time viewer. I have a stock 2015 M235 that got a muffler delete done on it a couple months ago. I decieded to take a look under the car and noticed a small amount of water dripping from one of the welds in the pipes done by the shop. I read that a little bit of leakage is normal and that pipes expand when hot so it should close up once up to temp (I had just started the car prior to looking). Sometimes I smell gas under heavy acceleration too, is this a exhaust leak or something I should be worried about ? |
10-11-2023, 01:37 PM | #2 |
E4 Mafia
329
Rep 418
I'd have that done again. It's probably going to get worse.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k) | '04 E46 330xi MT (198k) | '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
F22Cam197.00 |
10-11-2023, 01:38 PM | #3 |
14
Rep 47
Drives: 2019 G20 330xi, 2015 F22 M235i
Exhaust leaks are *always* something to worry about. I've experienced CO poisoning and it is not to be messed with. CO is odorless and the symptoms creep up slowly - there may or not be a headache, eventually disorientation and worse. Slow to recover from.
I wouldn't drive it with a suspected leak unless you have a CO monitor in the car. In aircraft we use chemical ones that change color on exposure, or electronic ones. The electronic kind can plug into the 12V socket. |
F22Cam197.00 |
10-11-2023, 01:50 PM | #4 | |
197
Rep 32
10-11-2023, 07:36 PM | #5 |
E4 Mafia
329
Rep 418
In the mean time, how does the delete sound?
F22Cam197.00 |
10-11-2023, 07:55 PM | #6 |
197
Rep 32
https://youtube.com/shorts/yXzQh71gZ...ziz0jgRIirxa2w
Sounds good, maybe 30-40% louder than stock. Still a little tame for my taste so I plan on going Catless after I get my inspection |
10-11-2023, 08:12 PM | #7 |
E4 Mafia
329
Rep 418
F22Cam197.00 |
10-12-2023, 12:47 PM | #8 | |
5593
Rep 5,386
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
F22Cam197.00 fiveightandten111.00 |
10-13-2023, 02:18 PM | #10 |
197
Rep 32
UPDATE:
I got the welds fixed at the shop this morning for no cost, so I was happy about that. Then I proceeded to blow my charge pipe on the way home. Just great! Literally planned on getting it done next month. Car will be down until the VRSF one comes in and I can install it. |
10-15-2023, 12:16 PM | #11 |
14
Rep 47
reference material on CO from exhaust leaks
CO risk depends on where the leak is, where the cabin air intakes are, etc.
https://www.abe.iastate.edu/extensio...icles-aen-208/ Why are defective exhaust systems so dangerous? Internal combustion gasoline engines produce extremely high carbon monoxide concentrations. Even a properly tuned gasoline engine, will produce more than 30,000 parts per million (ppm) of CO in the exhaust stream before the catalytic converter. An exhaust leak can allow escape of CO before it is converted to non-toxic CO2 in the catalytic converter. The CO leaking from the exhaust system can enter the vehicle through holes in the body or open windows or doors. Exhaust systems must be gas tight from the engine to the end of the tailpipe. How does the catalytic converter reduce the risks of CO poisoning? The typical catalytic converter found on most newer cars and trucks combines oxygen with carbon monoxide to form non-poisonous carbon dioxide (CO2) reducing the high concentrations in the exhaust manifold (typically 30,000 ppm or more) to low concentrations (typically below 1,000 ppm after the catalytic converter). Tailpipe concentrations of carbon monoxide in gasoline engines without catalytic converters are typically from 30,000 to over 100,000 ppm, depending on the condition of the engine. How can CO poisoning occur if the engine has a catalytic converter? Exhaust gas that leaks out before the catalytic converter has high CO concentrations. Out-of-tune or misfiring engines produce elevated concentrations of carbon monoxide and unburned fuel that can destroy the catalytic converter. During cold starts the catalytic converter is ineffective. And if there is insufficient oxygen (caused by operation in a closed building or with a defective oxygen system), there will not be enough oxygen for oxidizing the CO to CO2. |
10-18-2023, 07:27 AM | #12 |
1001
Rep 2,217
To the OP - you should go back & edit/correct the spelling of exhaust in the subject line so others with this issue will be able to find this thread.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
F22Cam197.00 |
10-18-2023, 11:35 AM | #13 | |
5593
Rep 5,386
Unless you're running a car inside an enclosed space, you're not going to suffocate yourself from CO poisoning. FYI, exhaust systems are not air tight either. They leak slightly at the seams/connection points after the cat.
F22Cam197.00 |
