10-04-2023, 12:21 PM | #1 |
Rep 17
2016 428i Convertible (F33)Rear Window Wont Work
Hi,
I have a 2016 428i Conv (F33). The passenger rear window is not going up at all (nothing happens when I pull the switch to open it/no noise either). It used to work fine, but it suddenly stopped working. This is also keeping the roof from retracting. I don't know why the roof wont retract; the window is all the way down. Please let me know if you guys think this could be a fuse problem or a bad switch. Thanks! Lou Last edited by diver94; 10-04-2023 at 12:34 PM.. |
10-04-2023, 01:16 PM | #2 |
83
Rep 67
Had similar issue. If you are lucky it may just be a fuse. I needed a new assembly You can also try enet ista it should show an error and you can have ista do a reset on the regulator and motor.
See my thread on the issue for resolution https://f30.bimmerpost.com/forums/sh....php?t=2043953 |
10-04-2023, 02:10 PM | #3 | |
Rep 17
Thanks!
Did yours make any noise? Mine doesn't make any noise at all. I don't have the scan tool. Do each window regulator need/could use a reset? Thanks! |
10-04-2023, 09:45 PM | #5 |
Rep 17
05-03-2024, 06:57 AM | #6 |
Rep 1
Did you ever find this problem? Mine stopped working and now works intermittently. Stops my convertible top from moving when it’s acting up. Sounds fine when it works properly. No sound at all when not functioning.
I checked for drain plug issues, but drain plug had been removed by previous owner. Maybe that’s a clue. |
