E90 N55 Crank no start
09-30-2023, 03:19 PM | #1 |
Rep 29
A little history into this issue, I removed my valve cover to inspect my intake cam and bearing caps for unusual wear due to an unrelated p112f error. After reassembly the car started fine and ran drove for approx 30 min before the car went into limp mode / flashing check engine with rough idle and inevitably stalling. I pulled the codes and noticed random misfires on cylinders 4/5/6. Changing the coils to other plugs made no difference to the misfire code and the only way I could get the car to idle was to unplug the VVT connector. It started and ran normally almost the whole way home before it just suddenly stalled quietly. Since then the car just cranks with no start. Ista reveals no unusual error codes. I started to see some other posts here related to electrical issues causing the no start so I began to test for power to the DME. I started with investigating power to A4010 Junction box fuses F16,F37,F38 and F11 all see battery voltage 12V with ignition on. Valvetronic /Dme relay seem to operate correctly and F01-F03 fuses all have 12v. Wish I had some more codes to work with... Any help with steps to take would be appreciated.
I've attached some ista screenshot ignition on & during cranking. video of start. https://www.youtube.com/shorts/1YeQTHqdnjk |
10-02-2023, 03:28 PM | #6 |
112
Rep 347
10-02-2023, 09:19 PM | #7 |
Rep 29
Okay, hopefully someone can chime in here because I'm kinda desperate! I did a compression check and to my shock I have zero compression in all cylinder except cylinder 4 which has 75psi. What the hell does that mean, can't be good.
10-03-2023, 08:24 AM | #8 | |
293
Rep 707
If compression turns out to be okay, I second comments that it seems like a bad connection somewhere from the valve cover job. Can you share more detail about what made you suspect problems under the valve cover in the first place? |
10-03-2023, 10:27 AM | #9 |
112
Rep 347
that usually means you did the compression test incorrectly lol. Theres no way you put a hole in 5 pistons simutaneously. Did you reset the timing?
10-03-2023, 10:31 AM | #10 |
112
Rep 347
Check your spark plugs, are they covered in fuel or oil?
10-03-2023, 10:46 AM | #11 |
Rep 29
Spark plugs are wet from fuel from continuous cranking yes. I'll try the compression test again but I did it twice and both times I recorded zero compression in all but cylinder 4 which was getting 75psi. Unless for some reason the cheap ass tester I bought is not making an adequate seal, I'll check the rubber o-ring. I did not make any changes to the timing. The valve cover removal was to check the intake camshaft I had replaced it months back due to scoring over lobes and bearing caps. I was checking for additional scoring of which there was none. Maybe I should pull the valve cover and inspect the timing chain maybe something broke..
10-03-2023, 01:15 PM | #12 | |
112
Rep 347
10-03-2023, 07:38 PM | #13 |
Rep 29
No mis shifts at all, whats strange is I did get misfire codes and rough idle during the original incident and disconnecting the VVT connector smoothed everything to the point the car felt completely normal for at least 20min of driving before stalling out for good which has led me to this point. Just doesn't make a lot of sense to me how the car was driving fine stalled out of the blue and now no compression.... I'll open the valve cover tonight and see what I see I guess!..
10-04-2023, 12:06 PM | #14 |
Rep 29
Okay, update I have removed the valve cover and made some observations; manual rotating engine I see everything is moving both camshafts, crank pistons, intake and exhaust valves. There is good tension in the timing chain, only thing I found odd was the exhaust vanos seems a bit funky, like its not aligned correctly and the spring seems loose. I inspected the vanos bolts on both the intake and exhaust and they all seem to be correctly seated. I have ordered the timing kit but under initial observation at TDC the barcode on the exhaust cam seems correct however the intake cam is way off. |
10-04-2023, 03:26 PM | #15 | |
112
Rep 347
10-04-2023, 03:37 PM | #16 | |
112
Rep 347
10-04-2023, 06:07 PM | #17 |
Rep 29
I didn't order timing chain, just the kit to set up the timing brackets and such. Yes things moving is nice question is if the intake cam is off did I make contact with any valves and cause internal damage. I have not checked the vanos solenoids, I;ll pull them out and take a look, I have replaced them within the year however. I'm familiar with setting up the timing as I had to do this entire procedure last year when I replaced the intake camshaft..
10-05-2023, 03:17 PM | #18 | |
112
Rep 347
10-05-2023, 03:50 PM | #19 |
293
Rep 707
Is it common for timing to be off if nothing is broken? It seems weird that exhaust cam is off, but intake cam isn't? I'm not to versed in the timing assemblies, so I'm not challenging, just curious to learn how this can happen.
Edit: I mixed it up, OP said exhaust cam is in, and intake cam is out. Last edited by wheela; 10-05-2023 at 07:16 PM.. |
10-05-2023, 04:56 PM | #20 |
112
Rep 347
I think when he unplugged the vvt connection (Vanos) and drove the car without it plugged in, it threw the timing off since the vanos controls the valves via cam phasing. It wont break anything mechanically since when the vanos is removed the cam moves to the default position. I think changing out the vanos solenoid will probably fix the p112f code, or MAF.
10-05-2023, 05:55 PM | #21 |
293
Rep 707
I believe vvt is the bmw acronym for valvetronic though, so unplugging the valvetronic motor shouldn't have any impact on vanos function?
But yeah, hopefully it's something simple with the vanos system making a cam appear to be out of time? |
10-06-2023, 01:06 PM | #22 |
112
Rep 347
VVT is also an acronym for Variable Valve Timing Solenoid, which is a fancier way of saying vanos. Don't know which one he was mentioning though i was just assuming.
