      10-17-2007, 02:54 PM   #1
jasper
21
Drives: 2002 325i
Brakes and Weight Distribution
2 questions...
wondering, other than the giant 135i brakes that may or may not make it to North America, what are the brake disc sizes?
also
will weight distribution be close to 50/50 like 3-series? I don't remember hearing this "officially"?
      10-17-2007, 02:59 PM   #2
AwesomeBMW
Freude am Fahren
17
Drives:
don't know about the brake disc size, but the weight distibution should be 50/50
Check bmw's microsite
http://content.bmwusa.com/microsite/...e=1SERIESFVVIS
"Oversteer is best because you don't see the tree that kills you" -- Richard Hammond
      10-17-2007, 03:47 PM   #3
jasper
21
Drives: 2002 325i
your right; has 50/50 weight distribution per the microsite - thanks
I'm curious if the brakes will be similar to the 3-series, I'm guessing they probably will. So the 128i will probably have equal size rotors. My preference would be bigger brakes in the front.
      10-17-2007, 04:27 PM   #4
grant
grant's Avatar
Drives: 1973 Porsche 911
If they screw us out of the Brembo multi-piston brakes after touting them all these months, I am going to be pissed off!:mad:
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
      10-17-2007, 04:55 PM   #5
semaj
9
Drives: 135i N54
2010 BMW 135i  [0.00]
Same here! :mad:
      10-17-2007, 05:14 PM   #6
AwesomeBMW
Freude am Fahren
17
Drives:
Originally Posted by semaj View Post
Same here! :mad:
who wouldn't be?:iono:
      10-17-2007, 05:40 PM   #7
1ster
Large Member
1ster's Avatar
164
Drives:
I will be more than pissed. I will cancel my deposit and not buy the car. :bs:
      10-17-2007, 08:32 PM   #8
Garrett
23
Drives: 2004 330ci
I think I'm going to get upset and start complaining about nothing... and of you guys care to join me..?
Oh, nm!
Who start this sh!t..? Is there any indication from any source that says the 1 seies coupe won't have 6-piston Brembos up front..?
When in fact BMW engineers have publicly said so on numerous occasions..?
-Garrett
      10-17-2007, 08:50 PM   #9
R32
7
Drives:
the brakes will be excellent... no worries there.
would it be too much to ask that the bleeding nipples be on the outer half of the caliper (like on many bbk's)? bleeding brakes without having to remove the wheel FTW!
      10-17-2007, 08:53 PM   #10
heeltoer
Drives:
6 pistons is official, check the microsite, they have a blurb on the brakes
"And for the first time ever, the 135i 6-piston performance powerhouse front disc calipers are painted and feature BMW badging."
No idea if they are brembos but ill take it.
      10-18-2007, 01:39 PM   #11
321
Stay a while and listen...
21
Drives: vr4
Fronts - 6 Piston - 338mm x 26mm = 13.31 inches
Rears - 2 Piston - 324mm x 22mm = 12.75 inches
Me.. If you guys want brembo's so much why don't you put them on yourselves?
Frankly i think the stock calipers will do just fine for my purposes(DD,autox, mild road course)
Some proper cooling ducts
Slotted cryo disks
Proper pads
Motul fluid
and SS lines...
Yup just fine for me...
      10-19-2007, 03:07 PM   #12
grant
grant's Avatar
I'd be perfectly happy to do so if they didn't cost $7k as a front & rear upgrade, making the car 20% more expensive. I would say that having them included at $35k makes the purchase much more attractive.
If you've never had Brembos, you might not miss them. But, you can put the best brake fluid and steel lines you like and you will still not approach the excellent feel and modulation of Brembos.'
I've had Brembos on 5 cars and 1-piston sliding calipers do not come close,a s much as you may like to think it doesn't matter.
      10-19-2007, 03:16 PM   #13
bradford
28
Drives: 2008 SGM 135i
While this is certainly correct, it applies to any well-designed monoblock caliper. Certainly Alcon and Stoptech make brakes that are as good or better than Brembo's offerings.
      10-19-2007, 04:08 PM   #14
grant
grant's Avatar
Agreed (though Brembo makes some KILLER racing brakes that are not seen on street cars)! AP makes a fine system too...
      10-19-2007, 04:15 PM   #15
BMWeber
36
Drives: 08 135i
unfortunately they're on the inside
      10-19-2007, 04:41 PM   #16
Icecold135i
I Fly Icecold No Mistakes
Icecold135i's Avatar
Drives:
Perhaps this is a really dumb question and although I dont have a hi post count I promise I am no a noob and have read on this board for some time now. But if we do end up getting the 6 pot brakes (im keeping my fingers crossed) are they being manufacutered through Brembo? I was unaware that BMW was outsourcing this job to Brembo, that makes this car that much better! Is this true?!?!
      10-19-2007, 04:52 PM   #17
1ster
Large Member
1ster's Avatar
164
Drives:
Inside sources seem to indicate that the brakes are are indeed a Brembo set-up. Pretty damn sweet, no?
      10-19-2007, 04:54 PM   #18
BMWeber
36
Drives: 08 135i
yes brembo and yes we're getting them
      10-19-2007, 04:56 PM   #19
Icecold135i
Drives:
Wow thats awesome to hear. This car gets better and bettereveryday!!! I love it!
      10-19-2007, 06:30 PM   #20
bradford
28
Yup, with a lift it's much easier to do from the inside because you don't have to worry about the spokes.
BMWs are not designed to have owner-serviceable parts anymore. :frown:
      10-19-2007, 06:31 PM   #21
bradford
28
I haven't heard confirmation of this. What are the "inside sources"?
      10-22-2007, 11:58 AM   #22
321
21
Drives: vr4
I would think if Brembo had any part in making the brakes it would only be in the front.
It sounds like you would be getting Brembos anyway if the 135i didn't come with them. No?
I didn't say anything about how much it matters.
I am sorry for the miscommunication but I am not talking about 1-piston sliding calipers either.. I am talking about fixed 6 pot BMW and 6 pot Brembos. To me Brembo is just a brand of brakes(not king of brakes). If it ever gets to the point where the 135i becomes a dedicated track mule then maybe I would do a little more research...(ie: Get in cars with different BBK's)
