      09-25-2007, 10:24 AM   #1
imported_emos325
Drives:
will i need new cv joints if my wheels are big?
if i want to put on a wide bodykit or roll the fenders and add 17-18 with 20mm(rear) and 10mm(front) wheel spacers will i have to strengthen my cv joint or my half shaft or something because my wheels are to far out from under my car? also plan on lowering it so how is this going to affect it and what can i do to fix/correct the problems?
      10-15-2007, 05:08 PM   #2
94urS4
Drives:
lowering it shoudlnt affect anything, except it will give you a bunch of new neagtive camber so get it aligned after, and ive never had to worry about strengthing my cv or halfshaft on wheelspacing apps.
      10-22-2007, 12:42 PM   #3
imported_emos325
Drives:
cool thx
      10-23-2007, 01:20 AM   #4
emm3tt
Out Driving
emm3tt's Avatar
29
Drives:
You'll definitely need new cv joints, make sure they are filled with gold grease. Titanium axles as well.
Emmett
01 E46 M3
      10-24-2007, 09:45 PM   #5
imported_emos325
Drives:
Talking
no no no don;t get cheap on me. magnesium axles and platinum grease cause i am a baller!!!!!:roundel:
      11-03-2007, 11:51 AM   #6
Ryephile
Not a Newbie
Drives:
Running lower offset may put more stress on wheel bearings, however that would be something to the tune of needing to replace them every 80k miles instead of every 100k miles, for example. The most important thing IMO is watching you don't rub your tires on the body and wheel-well when turning and under suspension compression.
[SIGPIC][/SIGPIC]
      11-05-2007, 07:14 AM   #7
imported_emos325
Drives:
thank you every little bit helps when i am still learning. thx.
Search this Thread:
Advanced Search
