08-17-2023, 06:22 AM | #1 |
51
Rep 59
Track Prep Thread for G87
Creating this thread for those of us that will track the car. Can we get some links for the following stuff, anyone with experience
And anything else I may have missed here. |
08-17-2023, 04:31 PM | #2 |
447
Rep 267
Regarding the harness option for Carbon buckets:
I have been in contact with Schroth and they are not intending to do system for the G8x platform. They do not see the demand. Feel free to email them and ask and perhaps if enough of us do then they will change their mind. The only option is to do a roll cage and attach a harness to that or do a harness bar. I could not find a harness bar for the G87. Brey-Krause makes one for the F87 but I got some key measurements from one of their distributers and compared it to my car and unfortunately, it will not fit. I am thinking about making my own this winter when it is not so damn hot. I will post it if I do. |
08-17-2023, 04:37 PM | #3 | |
447
Rep 267
19x10.5 et18 Apex VS-5RS Nankang 295/30/19 tires Millway Camber plates EBC bluestuff trackday pads Xpel ppf on the front After I get a few track days in I will see if I need Motul brake fluid or a lower suspension. Aero mods is pretty far down the list for me. |
08-18-2023, 02:17 PM | #4 | |
425
Rep 344
The G cars are heavier and more powerful than the already heavy F cars and you're adding grip—higher speeds on the straight from exit traction and then putting more energy into the brakes (compounded by a more aggressive pad). Might as well cover your bases and not find yourself with a soft pedal due to cooked fluid. I fully expect these cars to rip so enjoy it and maybe we'll see each other at the track. |
gcmak135.50 |
08-20-2023, 12:22 AM | #5 | |
136
Rep 88
19x10 et12 Apex VS-5RS (will run 12mm future classic spacers in the rear - I currently have them on all 4 corners with OEM wheels). undecided 275/35/19 tires Millway Camber plates CSG CP Pads SRF Brake fluid Considering the IND Fender liners so I can run 285 square instead. I'll be honest after following Jackie Ding, I'm not sure pads and fluids are needed at all at least not for the first set of OE pads to wear through...yes the car is heavy, powerful and if adding sticky tires on a heavy braking track it is a risk, but you also cannot compare it to F87 because there's a ton of heat capacity in this new braking system too... One thing I question though, with this car having brake by wire, how will it behave with pad fade or boiling brake fluid? Some manufacturers have warnings and other safeguards. Do we still feel a mushy pedal? Alignment I'll target -3 and -2 to start but open to recommendations. I ran this similar setup in a GR Supra and found it to do pretty OK, but wouldn't be surprised if I ended up wanting more negative camber up front. Last edited by gcmak; 08-20-2023 at 12:31 AM.. |
08-20-2023, 12:55 AM | #6 |
Car Geek
3706
Rep 3,620
“Brake by wire” is more accurately described as “brake boost by wire”. There is still a hydraulic path from the brake pedal to the calipers, but variable electronically controlled electric/hydraulic assistance is provided instead of vacuum assistance. There is still some hydraulic feedback, although variable assistance could mask that if the control algorithms are designed that way, but it is still fundamentally a hydraulic system end-to-end.
08-20-2023, 10:54 AM | #7 | |
136
Rep 88
Ojala6.00 |
08-20-2023, 12:00 PM | #8 |
278
Rep 185
No one in the history of track driving has ever said "using high temp brake fluid was a real waste of money."
2024 G87 M2 | 6MT | Carbon Package | ///M Performance Suspension
2023 8Y RS3 | Mrs. Sculpin's car 2011 E90 M3 (Retired) 1995 E36 M3 (Retired) |
08-20-2023, 12:57 PM | #9 | |
425
Rep 344
The other thing I'll just point out is @ZPD lists their location in Texas so I'm assuming, or just hoping that they'll come out to COTA at some point. COTA's back straight is twice as long as Autobahn's (where Jackie did his initial video) and ends going into turn 12—having faith in your brakes when slowing the car down to ~40mph from 150+ is nice. Ultimately SRF is just cheap insurance—it also has such a high wet boiling point that a lot of people do bleed it once a year. You're already spending much more on other things and there is literally no downside to good fluid. This is a very efficient way to summarize what I just typed. |
gcmak135.50 |
08-20-2023, 02:11 PM | #10 | |
447
Rep 267
08-20-2023, 05:30 PM | #11 |
136
Rep 88
Thanks for the clarification and am aligned with recommendations. Years of hitting up the track has told me not to skimp on brakes (among a few other key items).
09-07-2023, 03:10 PM | #12 | |
177
Rep 150
FWIW 295/35/18 here 0 rubbing YET with 5mm front spacer. -GT3M2 |
gcmak135.50 |
11-29-2023, 09:43 AM | #13 |
1096
Rep 823
Can you provide details and specs on wheels and which tires, please?
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
11-29-2023, 12:27 PM | #14 | |
177
Rep 150
Wheel: Apex VS 5RS 18x10.5 Tire: Nankang CR-S 295/35/18 Stock Supension, 0 rubbing, 0 issues. Ride is far more compliant than stock, tons of turn in, more supple over big bumps and sharp edges, but front end will tramline a bit just do to the rack width up front. TONS of room to lower it. https://apexwheels.com/gallery/bmw/m...port-gold-1583 -GT3M2 |
gcmak135.50 |
11-29-2023, 12:52 PM | #15 | |
1096
Rep 823
11-29-2023, 01:20 PM | #16 | |
136
Rep 88
Visually by going down in overall diameter, it creates a larger all-around gap in the wheel wells; especially in the rear. Here's the generic size comparison of the OEM front vs. your new tire size. In the rear, as mentioned, the difference is more pronounced from OEM vs. your new tire size. |
11-29-2023, 01:23 PM | #17 | |
177
Rep 150
Car would look 200% better dropped on 20's but, for the track, I think this is " the way". 19's are not much of a compromise but having so much space is nice. -GT3M2 |
11-29-2023, 01:37 PM | #19 | |
136
Rep 88
Was just sharing data for others to review as they consider options. Contact patch shape and top speeds in each gear are considerations too; splitting hairs IMO but factors nonetheless. |
GT3M2177.00 Sherlock997220.00 |
11-30-2023, 12:40 PM | #20 |
Got Track!!!!!!
40
Rep 385
Hey guys this is my “Blu Pig”
19x10 apex on MCS coils Anyone with 18x10.5 can you post a picture of the caliper clearance? Was going to do RA this weekend but it’s going to cold and raining, haven’t driven the car on track with the new msc coils. This is a dedicated track car I don’t drive it on the street because #raceseats
7
apez652.00 gcmak135.50 BackOnBlack727.50 bmwimsafan23.50 Sherlock997220.00 Bumpinjeep5572.50 MovingChicane109.50 |
11-30-2023, 06:20 PM | #21 | |
447
Rep 267
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43 |
11-30-2023, 08:47 PM | #22 | |
Got Track!!!!!!
40
Rep 385
Im starting out with 800 and 700 also and will go from there. Ill have to check but you basically have to put them where I put mine so they clear, but plenty of room.
