      08-04-2007, 01:32 AM   #1
Powerman
Drives:
Car and Driver 1er write up.
Sure you guys saw this
http://www.caranddriver.com/carnews/...-and-info.html
What I was interested about was the tire comment at the beginning of the 2nd page. I wonder if "high performance rubber" on the 135i means no run flats, or if that was just a generic choice of words.
      08-04-2007, 06:42 AM   #2
atr_hugo
No longer moderate
atr_hugo's Avatar
325
Drives: '13 135i
The press photos we've seen show Bridgestone RE-050A's and I believe somewhere in a press release, or an AutoWeek blurb they mentioned run flats.
      08-04-2007, 07:43 AM   #3
ChrisK
ChrisK's Avatar
Drives: '19 M2C
This BMW is going to scream
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      08-04-2007, 08:43 AM   #4
128er
89
Drives:
I kinda hope they do put runflats on the 128i...cuz i'm not much of a tire changer:roundel:
      08-04-2007, 10:33 AM   #5
InsaneSkippy
InsaneSkippy's Avatar
79
Drives: 135i
If they put run flats on the 135i, just gives me an excuse to burn them up...Once I have the money for new wheels/tires.
      08-04-2007, 12:51 PM   #6
Powerman
Drives:
Well the review of the 08 M3 in the same issue says they come with Michelin Pilot Sport PS2. That would be nice if they put them on the 135i too.
Can you believe the M3 weighs 3650 lbs. with a CF roof
      08-04-2007, 02:34 PM   #7
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Originally Posted by Powerman View Post
... Can you believe the M3 weighs 3650 lbs. with a CF roof
Give me the 135, a Quaife LSD, and software tweak and I'll give that $70K, 400 lb. heavier, M3 V8 a run for the money.
      08-04-2007, 04:15 PM   #8
Powerman
Drives:
Same thing I'm thinking. It isn't that a 135i will be better than the M3. Let's be honest here, that V8 is pure sex. It is just that I can be in the same performance ball park with half the money. That is cool by me. Not to mention that with software, I will be putting out more than the M3 at 6K feet.
      08-04-2007, 05:33 PM   #9
brfbmw128i
9
Drives:
Once again 128er i agree
      08-04-2007, 07:53 PM   #10
grant
grant's Avatar
Drives: 1973 Porsche 911
You need to change the tire on a run-flat too when you get a puncture, but you can limp home or to a shop...
      08-04-2007, 07:58 PM   #11
grant
grant's Avatar
Yeah, at 6,000 ft and with the software you will be putting out WAY MORE power and torque than an M3.
If you assume 400hp and 400TQ for tuned 135i at altitude (no loss from altitude with turbo) and 415hp and 340 ft-lbs of torque from M3 at sea level, the M3 will only make around 320hp and 262 ft-lbs of torque at 6,000 ft. Not even close. Then remember that the M3 weighs several hundred pounds more.
It is no contest (even a stock 135i will be significantly faster than an M3 at 6,000ft). Even a stock 335i will be faster than an M3 at altitude - tough to move the M3's off the dealers' lots in the mountain states...
      08-04-2007, 08:00 PM   #12
crawfoj
Drives: E90 335i
"performance rubber"
Can only hope for a set of PS2's as standard equipment as part of the M sport package. :thumbup:
      08-04-2007, 10:01 PM   #13
brfbmw128i
9
Drives:
True, but i'd rather limp home then have a complete flat on the side of the road in the middle of nowhere....there are bad people out there:tongue:
