07-22-2007, 10:38 AM | #5 |
2146
Rep 10,176
It's a value that limits the flow of hydraulic fluid to the clutch, showing down it's open/close functions. It's supposedly put in place to make the clutch plate and throwout bearings last longer.
07-22-2007, 11:33 AM | #6 |
1587
Rep 2,410
Drives: E30 M3 Cecotto, F85, G05, G07,
I think it's to reduce abuse on the drivetrain during spirited manuevers. think of it like those hinges on cabniet doors. That have that soft open/close feature.
07-22-2007, 01:00 PM | #7 | |
33
Rep 390
and you're right guys, I don't see why they wouldnt put the CDV in the 135i |
07-23-2007, 09:41 AM | #8 |
Zoom Zoom
38
Rep 1,069
Awesome. Thanks. That adds another thing to my "learned something new" list.
07-25-2007, 07:13 PM | #10 |
7
Rep 68
Drives: '08 Mitsubishi Lancer EVO X MR
What are the downsides of the CDV? Does it effect driving or make driving more difficult? If all it does is prevent crap from breaking then what's the big deal? If the only downside is adding .1 second per shift then what is the problem?
07-25-2007, 07:18 PM | #11 |
Rep 131
Theory of Operation - What is a CDV? The Clutch Delay Valve (CDV) is a one-way restrictor installed by the factory between the clutch slave cylinder and clutch master cylinder, as shown in Figure 1. It "delays" the engagement of the clutch, much like old record players used a damped tone-arm to gently lower the needle onto the surface of a record. Because of this valve, no matter how quickly you lift your foot off the clutch pedal, the clutch engages the flywheel at a constant (slow) rate. In theory, it can save the driveline from shock, were an inexperienced (or immature) driver to dump the clutch at high RPM. But in practice, all it does is prematurely wear out the clutch and turn experienced drivers into people who, despite 20 years of practice, cannot shift gears smoothly. During parallel parking maneuvers, the delay can be infuriating, causing constant clutch slippage. And during hard acceleration, the large amount of clutch slippage can greatly shorten the life of your clutch. During normal, sedate driving, the shift from first into second gear is often jerky, leading passengers to question your skill. As the driver, you can see your passengers' heads bobbing back and forth during every shift! Yes, in their minds, they are laughing at you. taken from http://www.zeckhausen.com/CDV.htm |
07-25-2007, 09:06 PM | #13 | |
11
Rep 149
i think it would be better w ith out it |
07-25-2007, 09:40 PM | #14 |
2426
Rep 11,667
Yes, it absolutely is better w/o the CDV.
It was the first thing I did to my Z. It was a day/night type of experience
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
07-25-2007, 09:47 PM | #15 |
Rep 131
Taking CDV out, will be the first thing I'll do.. .(if I'll get 135i)
You guys should read what e46 M3 guys are saying about CDV, the feel of the clutch before and after. It seems significant... |
07-25-2007, 11:09 PM | #16 |
Bimmajockey
Rep 35
I just replaced my original clutch at 183k miles because the throwout bearing failed. The clutch wasn't even done yet. So, a CDV may cause more wear but it's nothing significant. I just installed a new clutch with a lightweight flywheel. With that said, my friend has the exact same set up with the CDV removed...it's sooo much better. The clutch just feels like it grabs better. I need to get mine out ASAP. And then in my future 135i
07-26-2007, 11:28 AM | #18 |
2426
Rep 11,667
07-26-2007, 11:39 AM | #20 |
2426
Rep 11,667
Yeah... if you're OK with bleeding the line after.
07-26-2007, 11:45 AM | #21 |
Unofficial Official "IN"
Rep 138
07-26-2007, 12:15 PM | #22 |
17
Rep 524
