07-18-2007, 02:18 PM | #1 |
36
Rep 713
Drives: e46 330ci, e92 335i, 2008 128i
0 series
anyone else think that we need a sub-1 series car that truly does reincarnate the 2002(at least dimensionally) given that the e82 is closest to the e46 in overall size? i'm not considering the mini to be such a car as it's fwd etc.
07-18-2007, 02:39 PM | #2 |
Rep 65
It would just be too difficult in lieu of safety standards. Cars will never be the same as they used to be....
The Mini is actually really heavy considering its size. The smaller you make a car, the more safety precautions you have to cram in there....
A flute with no holes is not a flute; a donut without a hole is a danish....
[SIGPIC][/SIGPIC] |
07-18-2007, 02:47 PM | #3 |
37
Rep 1,680
it will _never_ happen again. as mentioned ... safety standards and general market expectations.
edit: i just mean i don't expect bmw to ever make cars as light as a 2002. i'm sure niche makers will fill the void or already have. |
07-18-2007, 04:18 PM | #4 |
Rep 98
07-18-2007, 04:43 PM | #5 |
57
Rep 1,396
Let's see,
1) small size like the 2002 2) small lightweight engine like the 2002 3) BMW design like the 2002 4) unable to pass modern crash tests like the 2002 I know just the car for you! The Zhonghua/Brilliance Coupe. http://www.chinacartimes.com/2006/11/18/40/ If it crash tests anything like it's big brother the BS6, it should fit the bill: http://www.chinacartimes.com/2007/06...test-pictures/ |
07-18-2007, 11:39 PM | #6 | |
414
Rep 6,968
I would get a lotus elise at that point. |
07-19-2007, 01:08 AM | #9 |
37
Rep 570
On the it-will-never-happen argument: sorry, Mazda has proven you wrong. Their MX-5 meets all modern safety requirements, is reasonably priced, and weighs hundreds of pounds less than 1er or a Mini... and convertibles are usually a few hundred pounds heavier than equivalent coupes! True, it does only carry 2. But the 1 is only a 2+2, not a true 4 seater.
07-19-2007, 01:44 AM | #10 |
Rep 65
Umm I fail to see where the Miata and 2002 parallel eachother. Of course 2-seaters don't count. Anyone could make a car with two seats and almost no storage space really light. I've never felt very safe in a Miata, anyway....
And how does 2+2 not make it a four-seater? I could swear 2+2=4. Or is it different in Canada? I clicked on one of the BS4 crash test picture links towards the bottom and it mentions the 97 3-series getting only one star in a crash test....??? I thought those things were safe.
[SIGPIC][/SIGPIC] |
07-19-2007, 07:07 AM | #11 |
Rep 78
Safe and modern cars don't have to get fatter, don't believe the hype!
We have the Toyota Aygo / Ciitroen C1 / Peugeot 107 in Europe. These 4 seater supermini's weigh under 800kg (1742 pounds!) and obviously meet all safety / emissions regs. The Citroen is 4* NCAP safety rated: http://www.euroncap.com/tests/citroen_c1_2005/218.aspx NB 800kg is about what a VW Golf (Rabbit) mk1, Peugeout 205 etc weighed in the late 70's / early 80's...so I think the above collaboration is a remarkable achievement over 25years later. IMHO these are a far cleverer car than the 1 series will ever be, if only BMW applied the same level of intelligence to a small car I'd be delighted. Edit: To be fair the low end, petrol 1 series are not too bad weight wise. The 118i is about 1220kg (2670 pounds) unladen - which is pretty similar to a 80's 3 series. It's the higher end / torque models where they loose the plot IMHO. Build me a 2.0 250bhp screamer BMW. |
07-19-2007, 07:09 AM | #12 |
36
Rep 713
oops, i actually meant to say that it was closest in size overall to an e36.
07-19-2007, 10:54 AM | #13 | ||
37
Rep 570
You obviously haven't got a clue about the effort it took Mazda to keep the weight down on the current model - like shaving grams off the rear-view mirror. Do a little research - other comparable 2 seat ragtops weigh hundreds of pounds more (S2000, Solstice/Sky). Quote:
07-19-2007, 12:38 PM | #14 | |
2725
Rep 6,750
The only modern BMW in the foreseable future that may have a surprisingly low weight is the upcoming Z2 roadster, designed to tackle the MX-5 on an even footing. It is reported to be a no-frills, back-to-basics, 4cyl only roadster. Even the M version of that is likely to have a 4 cyl engine. |
07-19-2007, 02:17 PM | #15 |
Rep 65
Did you read the OP? You didn't directly compare the two, but what he was asking was whether we could resurrect the 2002 at a closer size and weight to the original. The Miata is a completely different kind of car.
[SIGPIC][/SIGPIC] |
07-19-2007, 02:30 PM | #16 |
Rep 65
The only way the 1 is a 2+2 is if BMW is marketing it that way to give it a sportier image. I'm pretty sure the amount of room in the back seat has to be on par with my E36, and if so, the back seats are far from an afterthought.
[SIGPIC][/SIGPIC] |
07-20-2007, 12:23 PM | #17 |
22
Rep 661
It's really hard to do light and small these days. I'll be interested to see if Mazda comes out with the Kabura. It could be a 2+2, smaller and lighter than an RX8 which is almost 3,000lbs.
There is rumor that BMW may come out with something to combat the Audi A1 but again that s rumor. they are listing the 135 as the 2002 successor. |
07-20-2007, 01:10 PM | #18 | |
37
Rep 570
07-20-2007, 01:19 PM | #19 | |
37
Rep 570
Yes the Miata is a different kind of car, but some of the same weight-saving technologies could be applied to the 1 series with attendant reductions in mass. The current Miata was only about 22kg heavier than the last version despite being bigger in all dimensions, and having increased safety features, more options, and a more powerful engine. Shows it can be done. See also the new aluminum front subframe on the 08 TTs - Audi actually dropped weight between versions with this innovation. The fact that the 335i is only 50 or so kg more than the 135i clearly shows that BMW just didn't spend enough on weight reduction for the latter. |
07-20-2007, 03:01 PM | #20 |
Rep 65
I think if BMW put a serious investment into reducing the weight of the 135i without compromising it, we would be looking at a $50k car. I don't want that....
I wonder how much room there actually is in the back seat. The car is about the same length as an E36, yet taller, and even though it's a coupe, it has a steep rear window much like a sedan. I know if you compare the E36 to modern cars, it has little room in the back seat, but it still got by rather well IMO....
[SIGPIC][/SIGPIC] |
07-20-2007, 03:59 PM | #21 |
246
Rep 223
Drives: 2022 M3 Comp, 2021 X7
0 series???
Are you sleeping ok?
--2024 X5 M60i XDrive - Frozen Black Metallic
--2007 Porsche 911 GT3 - Black/Black 6MT |
07-21-2007, 01:24 AM | #22 | |
37
Rep 570
