07-14-2007, 10:56 PM | #1 |
37
Rep 570
Photo that gives good sense of size
There's a shot at M3post that gives a good sense of the coupe's size, as it's a close-up and there are several folk clustered around it: photo thread.
(I'd paste the photo but not sure about who has rights etc.) It looks to be nice and snug - I checked the dimensions and it's 18 cm (7 inches) shorter than a Mazda 3 sedan. (I fear I'm getting a little obsessive here.... ) |
07-15-2007, 02:12 AM | #3 |
Rep 19
The only thing I can compare it to is my wife's TSX. The 135 is approx 1 ft shorter overall but the interior dimensions are literally within mm's of each other.
'Los |
07-15-2007, 03:34 AM | #4 |
Rep 19
Hi
due to the amount of safety features built into cars today they have obviously grown in all directions ,and got heavier. I saw a merc 190 parked next to an audi TT (mk2) and the TT was larger than the 4 seater merc! The new VW polo is the same size as a Mk 1 golf. So a smaller bmw coupe might end up looking just right. |
07-15-2007, 07:29 AM | #6 |
Future N54 Owner...
Rep 140
Hmmm, more pictures, I knew he'd post them sometime...
This shot here, was the only one I'd ever seen on the car that makes it look like it has massive fender flares in the rear, perhaps of sign of wide wheels possible?? And then you go back to this one, and you can hardly tell it's there... |
07-15-2007, 07:42 AM | #8 |
No longer moderate
325
Rep 4,401
It's bigger than a bread box, but not by much ; -)
This car is small - I stumbled on something last night that perked me up. I was reading about Daewoo of all things and ran across the dimensions of the Chevy Aveo. It's almost the same size as the 1er. The 1er will fit inside a shell of a Mazda3 (tight fit of course).
Then I remembered a ride in a V8 powered Ford Focus I got at SEMA a couple of years ago. That was a little over 300 HP and 300 lb ft of torque in a rear wheel drive Focus. (Ford Racing actually sold (or sells) a kit to do that.) And then it hit me like a hammer - they had to make the wheelbase 104" in the 1er in order to keep us from wrapping ourselves around light poles!! I'm getting a lot more enthused about this car. :biggrin: |
07-15-2007, 08:03 AM | #9 |
12
Rep 89
I was lucky enough to see this car in the flesh at the spring model update in march in the UK. we wernt allowed any cameras or phones which was a shame. The car in the flesh looks no bigger than the 5door version of the 1. It has a lower roofline, naturally, but other than that it looks pretty similar.
I liked it a lot, but it looks a lot better in the flesh than it does in the pics.
HaHaHa! 4 a minute it sounded like you wanted 30Grand for it!!!
07-15-2007, 08:49 AM | #10 | |
244
Rep 1,136
If that's the case then it'll be incredible! A more accurate representation of human scale. This pic was taken with a state-of-the-art professional grade camera and you can see the car looks longer and lower than the other photos. |
07-15-2007, 09:08 AM | #11 | |
Rep 3
I know what you're thinking, I'm not trying to do a "Fast and the furious" here, a side on photo will show there's just to much gap between metal and wheel. What do you guys think? :iono: |
07-15-2007, 09:53 AM | #12 | |
Future N54 Owner...
Rep 140
You will see that the 135i is actually significantly wider than the 335i, even though the wheel base width is similiar. You'll also notice that the car is much, much shorter in height... Place this car next to a 335i, and I expect it too appear low, and wide, giving the appearance you are looking for... |
07-15-2007, 10:35 AM | #13 | |
37
Rep 570
On the height, the 135 is lower than the 128 (1403 vs 1428) but both are taller than the 335 (1395 from the spec diagram , 1375 from the spec text (huh?-way to go BMW)). These numbers go a good way to explaining the 1 coupe's boxier appearance - taller, narrower, and some 200 mm shorter than the 335. I'm happy with the latter two but we really didn't need the greater height. |
07-15-2007, 10:54 AM | #14 | |
37
Rep 570
07-15-2007, 11:51 AM | #15 | |
Future N54 Owner...
Rep 140
If you look at the diagram listed above... the 335i is clearly 1782 from MIRROR TO MIRROR, while the 135i is also clearly 1934 from MIRROR TO MIRROR. You can not compare the width of the rear fenders because the 335i's specs aren't listed. But, I think it's faily obvious, from mirror to mirror, the 135i is 152MM wider. On the height, i am clearly blind, the 335i is obviously about 33mm shorter than the 135i. Luckily this is only 1.299 inches, meaning it will be mostly unseen... |
07-15-2007, 12:16 PM | #16 |
37
Rep 570
On my monitor that diagram is so tiny it's hard to tell for the 335. I think there must be some error here, I very much doubt the 1 is wider than the 3, that just does not make any sense, nor does it jibe with the photos seen in the 335 vs 135 thread. More research needed. There may be errors in the BMW info other than the one I have already pointed out.
07-15-2007, 01:34 PM | #17 |
14
Rep 808
Regarding width:
BMWUSA website shows that measured from the middle of a tire to the middle of the other one, a 335i coupe has a width of 1514mm. This is a comparable measurement to the one posted by Wiggum, so a 335i is 30mm wider than a 135i. |
07-15-2007, 01:49 PM | #18 | |
Future N54 Owner...
Rep 140
Middle of the tire on the 335i is listed as 1513mm.... (close) This is blatantly obvious that the 135i is slightly, VERY slighly wider... |
07-15-2007, 04:25 PM | #19 | |
14
Rep 808
Widre is Bettre, eh? |
07-15-2007, 08:05 PM | #20 |
50
Rep 249
The 1er coupe is exactly 10 inches shorter than the E92, but only slightly smaller all other dimensions considered. At the same time you lose big on rear seat interior room, which doesn't matter much since I always have to put the driver seat all the way back in practically ever car I sit in bar a full size sedan(we're talking S-class size here, not even a Chrysler 300), so whatever the seating capacity is, automatically -1.
07-15-2007, 08:18 PM | #21 | |
Future N54 Owner...
Rep 140
The people whom have sat in the 1er coupe said the back seat wasn't too bad... |
