08-07-2023, 02:56 AM | #1 |
183
Rep 145
Is it bad to track the car with the valves closed?
So I have fitted a Remus race for more sound. All very nice, but it's a lot louders than I expected.
This could be a problem at the race track. Hence my question: Does tracking the car with valves closed do any harm? A friend of mine said this is bad for the car because the exhaust gasses can not be released soon enough and there is not enough free flow. Anyone with actual knowledge on this? |
08-07-2023, 08:17 AM | #2 |
6867
Rep 6,810
Eh, I doubt it. Plenty of people run some ridiculous setups at tracks around the world that have sound limits, and have no issues.
08-07-2023, 08:39 AM | #3 | |
5521
Rep 5,192
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
Jobe10182.50 |
08-07-2023, 09:27 AM | #4 |
1977
Rep 2,712
Unless you have an aftermarket valve controller, you’ll need to run the car in Efficient mode on the G8x platform. This means the engine won’t be at full power, along with decreased throttle sensitivity.
I got flagged twice at Laguna Seca (92db sound limit), so my only choice was to run in Efficient mode with a full titanium exhaust and stock downpipes. At WOT on a long stretch, the car can still build enough exhaust pressure to partially open the valves against its intended setting — the real concern should be more with the valve assembly breaking over time… |
Jobe10182.50 |
08-07-2023, 09:51 AM | #5 | |
183
Rep 145
08-07-2023, 10:18 AM | #6 | |
1977
Rep 2,712
…but on that note, having the engine in Sport+ would further increase exhaust pressure, thereby also opening the exhaust valves against its intended position. Here’s a quick video of the valves opening in Efficient Mode (Sao Paulo Yellow): |
Jobe10182.50 |
08-07-2023, 10:26 AM | #7 |
BimmerPost Supporting Vendor
2004
Rep 5,063
Shouldn't be an issue with running them closed but, if you have non oem valves/motors it could shorten their lifespan from the heat. You can also lose a few hp depending on the design and diameter of piping used for the diverter pipes.
Jobe10182.50 |
08-07-2023, 10:43 AM | #8 |
24435
Rep 191,342
Im not aware of any issues caused by the valves being closed.
Jobe10182.50 |
08-08-2023, 10:08 PM | #9 |
99
Rep 204
Personal experience while dyno testing, it won’t hurt the car but there will be a difference in power
Info@mad-us.com2004.00 Jobe10182.50 |
08-09-2023, 08:59 AM | #10 |
24435
Rep 191,342
What was the power difference in your experience?
08-09-2023, 12:39 PM | #12 |
Riding the knock sensor
2429
Rep 1,608
Drives: 21 X5MC | 23 M4CSL
Just a thought - the AWRON valve controller has a safety feature that overrides user settings and the panic button feature to ensure valves are open above a certain RPM. There must be some risk under load, perhaps related to backpressure.
08-09-2023, 12:41 PM | #13 |
183
Rep 145
Wouldn’t the stock valves also have that feature where they open up at a certain load? I sure hope so than 🥲
08-09-2023, 01:22 PM | #14 |
8279
Rep 18,861
Drives: BMW
and heat.
Hit_Apex2429.00 |
08-09-2023, 01:55 PM | #15 |
2004
Rep 5,063
I know there is a egt threshold for burbles not so sure about the valves.
08-09-2023, 02:37 PM | #16 | |
162
Rep 151
There are different exhaust backpressure models (offsets) to account for open or closed flaps gas flow to be used for boost control logic.
Kirill @ OdinTuned
Jobe10182.50 |
08-10-2023, 10:47 PM | #17 | |
214
Rep 353
08-11-2023, 09:39 AM | #18 |
24435
Rep 191,342
No issues have ever been reported with either case. You are fine to do what you wish, its only affecting the sound
08-11-2023, 03:29 PM | #19 | |
162
Rep 151
However, If you leave the exhuast flap actuator disconnected DME will trigger “flap open” state regardless of the actual flap position. This case may throw boost control calibration a tiny bit off if you have an aftermarket exhaust flap controller and keep the flap closed “manually”.
Kirill @ OdinTuned
08-11-2023, 03:36 PM | #20 |
397
Rep 295
There was a post I saw with on FB or the forums where a guy with a MK5 Supra had one of his valves get stuck in the closed position at a track day. Melted his bumper in that area. Something to keep in mind.
M3Cx, E92 M3 6MT Previous cars: '21 Supra, '17 GT-R, '15 GT3, '13 GT-R '09 GT-R, '06 Z06, '06 Evo MR, '05 M3, '03 Evo, '00 Miata. |
08-11-2023, 04:07 PM | #21 |
2004
Rep 5,063
Most likely his muffler was not sticking out of the bumper enough. Track days create some serious heat. I've seen license plate frames melting to exhaust fires.
08-11-2023, 04:17 PM | #22 | |
397
Rep 295
I didn't notice in the picture that he had an aftermarket diffuser that may have been redirecting some of that extra heat upwards.
