08-06-2023, 10:41 PM | #1 |
272
Rep 294
50e - Travelling - Best way to charging
The plan is to go on lengthy trips and stay at Hotels and Airbnb's (multiple days at the same location). I read through the forum through most of the threads regarding charging the 50e.
I was originally planning to use the regular cable with the Gen 2 adapter for 14-50 (61-44-8-490-525). However it was stated that it shouldn't be used with another adapter from e.g. a 30 amp outlet to the 14-50 amp plug. The advice is to install a proper 50 amp outlet. While I will do this at home, it is not feasible for travel tours. I probably will find all kind of setups along travel trips. I still want to charge and get the benefits. Currently I am considering the following:
Then use a Tesla to J1772, which I need anyway due to the available Tesla charging networks (especially with hotels). Something like this:If I am not mistaken the 40amp should be sufficient, since the car doesn't pull more than 32amp (80% of 40). They are all UL certified and look high quality. I know that I will still have to set the car to the max. charging amp based on what outlet I will find. Anyone with Tesla Mobile Connector experience? Any comments, better options? Someone with experience on long travel trips (in the past with the 45e)? |
08-06-2023, 11:10 PM | #2 |
577
Rep 910
For me I would totally forget about charging on a trip - I would just drive it ICE as finding charging at every stop is a hassle and you only get ~45 miles of range. In California while public charging is expensive, saving would not be significant if there is saving at all, for all the trouble.
Of course there are exception, such as airbnb you mentioned, presumably has a garage and can be used for charging. For me, i’d just pack a “turbo cord” - there are bmw branded ones that was sold with i3. It is 20% faster than OE charger at 110v (12A vs 10A, which takes ~16 to charge the battery from empty to full) and 16A at 220v, which takes roughly 6-7 hours overnight. I would not expect to have a full battery everyday - it would be nice if I can have some saving; otherwise I’ll just use ICE . |
08-06-2023, 11:30 PM | #3 | |
272
Rep 294
I will transition from a working life to life after work and tour the country for weeks/months on a trip. Stay at an Airbnb for a week at a time. We are mainly exploring nature. For the drive from A to B, I am ok with ICE. During the week of the stay, I would prefer a fully charged car. The benefit is that I can control with "battery hold" to use it while I am off the grid and actually approaching wildlife very quietly ... At times we have to take a rest e.g. in AZ with >100F. Sitting in the car without having the ICE on and still having A/C are real benefits. In addition the environmental effect. That's why we switched to the 50e. I didn't switch to save money. I would even recharge in CA knowing if will cost more ... I might be overly optimistic, but I at least want to give it a try. I have seen a growing amount of airbnb, National- and State Parks, Hotels, Camp Grounds and Rest Areas to provide dedicated charging options. So, please don't talk me out of it. Rather help to find a way to make it work to recharge to the 40 miles within 6 to 8 hours ... |
gsquare71.50 |
08-06-2023, 11:37 PM | #4 | |
577
Rep 910
For national parks and hotel, most likely charging is provided as a L2 charger (chargepoint or something similar) - you would most likely not need any cable for these. It is quite rare for them to just provide a electrical outlet (with exception of very few RV camping site, but many RV camping site specifically do not allow you to use their electrical hookup for EV charging). re: Tesla network, their supercharger network is definitely another level (unfortunately 50e cannot accept DC charging); however for tesla destination charger I do not find a very good coverage of these; in my experience there is usually regular L2 charger wherever there is a tesla destination charger; however in your area it might be different. I would not suggest optimize the solution based on Tesla network. Last edited by aaaaaaaaaz; 08-06-2023 at 11:49 PM.. |
08-07-2023, 12:48 AM | #5 |
89
Rep 156
I bought a 12 gauge heavy duty extension cord and use it with the provided L1 charger when on trips. As long as the provided outlet is grounded (or, ideally, GFCI) it seems safe.
08-07-2023, 01:19 AM | #6 |
229
Rep 509
OP I think you’re wildly overestimating the number of places that will have a 240v NEMA outlet available for use, as compared to the number of available destination EVSE or commercial chargers available. I had a Tesla for years and never once encountered a hotel or Airbnb where I could have used a 240 outlet. In comparison tons of those places have free or cheap EVSEs that, at worst, you’d need a Tesla connection adapter to use.
WagonFan271.50 |
08-07-2023, 05:58 AM | #7 | |
4716
Rep 8,780
Drives: eVeRyOnE mAD!
as for Airbnb properties with NEMA outlets, do you know their configurations (type of plug, amperage, etc.)? there are too many installation variations to be able to recommend a #-## to 14-50 adapter for your travels. TBH, i wouldn't recommend using an adapter on the power outlet end because of the uncertainty. you're better off using the common household outlet for level 1 charging. while you won't get the full charge, that outlet/circuit is more standard (and safer) Last edited by nZtiZia; 08-07-2023 at 06:26 AM.. |
gadgetfreak2024221.50 WagonFan271.50 |
08-07-2023, 06:39 AM | #8 | |
222
Rep 348
The built in navigation helps you find suitable charging locations. I personally see no reason not to use all electric once you are at your destination if you have access to an L2 and you are just driving around in the area. Of course if you are out for 40+ miles at a time you will have to eventually be hybrid in which case you may choose to drive the entire way in that mode. I guess if you know you will not have any L2 access you could acquire something like the EVSE from BMW that you showed (assuming you are leaving the one that came with your car at home?) but I would try to spend less and find one that only does 110/120 since to others’ comments it’s highly unlikely you will find an available 240V plug somewhere (unless you are at a campground I guess — but then that’s probably a different adapter?). |
WagonFan271.50 |
08-07-2023, 07:40 AM | #9 |
769
Rep 554
Basic question from a hybrid newbie: After the battery power runs out and the ICE kicks in, does it recharge the battery to any significant extent? If so, how long does it take for the ICE engine to fully charge the battery? If not, this would mean that one needs to recharge the battery virtually every night to obtain the 30-mile +/- capacity, correct?
- 2024 X6 40i, Carbon Black/Silverstone, M-Sport, Executive, DAPP, Climate, Air Suspension, etc. PCD.
- 2024 iX M60, Blue Ridge Mountain/Oyster, DAPP, Luxury Package. - Retired: Six previous BMWs. - Retired: Three Lexuses. |
08-07-2023, 07:55 AM | #10 | |
4716
Rep 8,780
the battery never "runs out"; only usable capacity is depleted. the vehicle will charge and maintain a minimum amount depending on which drive mode you're in. if Adaptive (45e only) or Hybrid drive modes, then 3-6%. if Sport drive mode, then 16-20%. it's not designed to fully charge the battery in any of these drive modes. if you want the vehicle to fully charge the battery, then you'll need to active Battery Control mode (45e only) and set the target level to 100%. if your use case warrants it, charging every night may be required for best electric utilization. that's the case for me who works M-F and commutes round trip with just electric power. |
redhot47fla769.00 |
08-07-2023, 08:11 AM | #11 | |
769
Rep 554
08-07-2023, 08:28 AM | #12 | |
4716
Rep 8,780
further, the 50e has Battery Hold mode which is different than the 45e's Battery Control mode. BH only holds the current charge at the time of activation. some have reported being able to attain a full charge with it, but it requires constant activation-regeneration-deactivation-reactivation cycles if you or your wife are willing to put in the effort (personally, i wouldn't) |
redhot47fla769.00 WagonFan271.50 |
08-07-2023, 08:49 AM | #13 | |
664
Rep 1,095
In the many years I've lived here, I've seen tourists park illegally on the shoulder of the highway, exit their cars and approach herds of deer, elk, big horn sheep, bison and on one occasion a moose cow and her calf. None of these critters want to be your friend and pose for your camera, which is why there are laws that protect them (and you). Do yourself a favor and buy a tripod and telephoto lens, and keep your distance. Furthermore, even with a quiet electric motor powered vehicle, your tires will be crunching loudly on the gravel roads. Regarding high temperatures, if you plan to spend considerable time in triple digit regions, keep records of your charging and range performance. High temps decrease charging and capacity efficiencies of batteries, and we'd all be interested in learning how Phoenix compromises the specifications. |
08-07-2023, 08:55 AM | #14 |
420
Rep 546
Ditto the comments above. If you're staying at a private residence (airbnb), the listing would likely indicate whether there's a charging station available. Otherwise assume it's a 110 household setup. Plug it in whenever you're not driving. Even if it's only half-charged, that's 20 miles you're not using gas.
I would never use the ICE to charge the battery fully. It's false economy. I tried almost every strategy I could think of on a cross-country drive before I reminded myself that having the V6 available is the reason I bought the car in the first place. |
redhot47fla769.00 |
08-07-2023, 08:58 AM | #15 |
146
Rep 345
I had several long road trips on my 45e with charging during nighttime, what can pull up to 16 Amp. It happened in cold and very hot climates, so the goal was to have battery charge for proper climatization of the car, and save few pennies on EV mode vs ICE in low speed/stop and go environments.
My setup was: 1 BMW factory charger (110v) and L2 charger (with NEMA 14-50) and an adapter to receptacles used by dryers (up to 30 Amp). I used different options: - L2 charges in the hotel - regular 110v and 220v 30/40 Amp receptacles in the hotels (second are rare, but exist near electrical boxes) - charged from dryer receptacles in AirBNBs homes - charged on campsites with 30 and 40 Amp receptacles If there were no charging options available overnight I used battery hold mode to charge the battery while on the highway. ChargePoint (you need to have an account to use their free chargers), ChargeHub and PlugShare apps are very handy for every EV owner. |
WagonFan271.50 |
08-07-2023, 10:06 AM | #16 | |
272
Rep 294
That's why I considered the Tesla set instead. It even provides 110 Volt adapters as the BMW Turbocharge. |
08-07-2023, 10:10 AM | #17 | |
272
Rep 294
The Tesla connector and adapter set provides to my understanding the same functionality with its own intelligence to adapt the charging rate. |
08-07-2023, 10:17 AM | #18 | ||
272
Rep 294
I use binoculars and a spotting scope. Still like to be quiet in the environment. However, if I see other wildlife, I won't look away ... Quote:
Prime time for Hummingbirds ... |
08-07-2023, 10:28 AM | #19 | |
272
Rep 294
Yes, I ordered the 50e for that combo. If I travel from a state to state, I plan to put battery hold on 20 miles and just use the ICE and forget the rest. It's when I stay a few nights. I searched airbnb for 5 days in Blue Ridge Mountains for after Performance Center Delivery. You can now filter by "EV Charger". I found > 1000 airbnb's available with EV capability in that 5 day timeframe in September. However they seem to be on the higher price range. |
08-07-2023, 10:33 AM | #20 |
2058
Rep 3,708
I don’t know. This whole concept sounds too complicated to me. Besides already mention, free standing 240V outlet availability, also consider they are NOT designed to be unplug and plug regularly, so unplugging dryer for evse and back, a few time a week isn’t the designed usage, especially when you renting other’s house, you further don’t know the condition of that plug.
If AC is what you are after, just use the 110V come from the car, charge it over night. Do the driving in sport mode, save the HVB for AC and precondition. It last a long time for this purpose. But don’t count in this operation being silent. But then let me back up a bit. Isn’t the point of be in nature is to be in nature? Why hide in car with AC and watch. |
WagonFan271.50 |
08-07-2023, 10:42 AM | #21 | ||
272
Rep 294
Perfect. A lot of great information and kind what I am looking for. Airbnb are increasing charging capabilities. I have one coming up in October not with a charger but with 30 Amp RV outlet. Especially the "Dryer" option is something I have been considering. The standard is a 10-30 and I considered this adapter: NEMA 10-30P to 14-50R EV Charger Adapter Many places have 30 Amp Dryer outlet near the outside or Garage. This is one the main items in my consideration. The Tesla kit offers this and the 30 Amp RV outlet as well and some intelligence. Maybe someone lurking around who has used this. I would be curious. Regarding ChargePoint. Will be my at home charger as well. Quote:
Thanks again. Great advice and along the lines what I have in my plans. |
08-07-2023, 10:49 AM | #22 | |
272
Rep 294
Agreed. We hike in Arizona in >100 F for a few hours, but it then would feel good to get into a pre-conditioned car and rest for 30 minutes while the ICE is off ... |
