07-06-2023, 10:22 AM | #1 |
59
Rep 61
Drives: 2024 X6 M60i
Engine Auto-Off
I'm trying to learn and understand exactly how the "Engine Off" programming in my '24 X6 m60i works.
Sometimes, when I put the car in park and open the door, the engine turns off. It doesn't happen all the time though, and I haven't been able to consistently replicate it. It just appears random. For example, I've ran back home to grab something with the plan to run in and back out. I want to leave the car running, but when I put the car in park and open the door, the engine shuts off. It doesn't happen all the time, though either. Yesterday, I returned home from work, put the car in park and opened the door (the exact same way) and the engine continued to run. The only thing I've been able to gather is that if I hold the brake down, the engine will not turn off until I release it (even with the door open), but only on the occasions where the engine turns off. Again, there are times where it will continue to run. I reached out to the dealer and was told that the engine off has to do with the "hybrid system" and something about safety, but with the inconsistencies in application (at least as far as I can tell), I don't see that being a legitimate explanation. Can anyone help me understand this? Thanks! |
07-06-2023, 11:49 AM | #2 |
654
Rep 1,200
Also turns off with non hybrid system. I can stop it on my M50i by turning off the ASS.
2024 M60i Frozen pure grey/Black Merino
2023 M50i Tanzanite / Ivory/Night Blue Merino gone 2022 40i G05 Arctic grey/Ivory Merino gone |
robbin5858.50 |
07-06-2023, 12:03 PM | #3 |
59
Rep 61
That's helpful when I want to open the door and keep the car running.
It also confirms that the dealer gave me a garbage answer. But it's not really satisfying my desire to understand why it's happening (or not happening). |
07-06-2023, 01:00 PM | #5 |
42
Rep 128
My SA told me to switch to Sport mode once in Park. Then rev engine a couple times in Park. I was then able to open the door and go to my PO Box to get my mail with it still on and not turning off. That worked for me so maybe give it a try.
robbin5858.50 |
07-06-2023, 02:56 PM | #6 | |
59
Rep 61
Where is turtleboy when we need him? |
07-06-2023, 03:50 PM | #7 | |
13534
Rep 20,170
I have never taken the time to try and track the different variables but my guess is if that is done we will see that it is operating on a consistent basis just not logically apparent. For example, it may not be turning off at times because of the outside temperature having the HVAC running. The general consensus is that it is doing it for safety reasons however I'm not convinced that is the case. I lean more towards it having to do with ASS.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
robbin5858.50 |
07-06-2023, 05:11 PM | #8 | |
654
Rep 1,200
As a thought try opening door when engine isn't hot and see if it turns off, if the ASS isn't ready to turn off it will prove it is linked to that.
07-06-2023, 06:19 PM | #9 |
573
Rep 1,986
I found auto engine off quite annoying.
For instance, I was at the hotel parking entrance gate where I have to touch key pad area with the card to unlock the gate. I came to stop, put the car to P, open the window, but I could not reach the pad, so I opened the door to reach it. Once gate opened, I closed the car door and try to go forward to just realize that my car was off. But this took few seconds to figure out (it's my new car) so I had to turn on the engine again and change transmission to D to drive forward... I was worried that gate might just come down again while driving forward because my car was not moving for a while after gate opened. |
07-06-2023, 06:30 PM | #10 | |
59
Rep 61
I will try to pay closer attention to the circumstances where it goes off versus on. Also, while the LCI models do not have a button to toggle ASS, it can be disabled by putting the drive selector in “S”. Other engine calibrations are also changed, but the engine will not turn off when coming to a red light. |
07-06-2023, 08:07 PM | #11 |
57
Rep 84
I don't fully get the logic either.
Sometimes the lights stay on. Not for the couple of mins, but for an hour. Radio, cooling, etc. Different depending how I open the car vs lock. Also having issues if I have my cell phone on me AND apple watch (both linked). And I though my Tesla was nuts - glad to have a "simple" BMW motorcycle to clear the mind ;0 |
07-07-2023, 04:40 AM | #12 | |
654
Rep 1,200
07-07-2023, 07:59 AM | #13 | |
981
Rep 1,560
Check you owner's manual. I did and there is nothing in it that says the engine will turn off when you put it in park and open the door (this may be different for different models). The ASS section lists when the engine will and will not shut off the engine, but doesn't mention putting the car in park and leaving the vehicle. I have my ASS coded off and my engine never shuts off when I put it in park and exit.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
