06-10-2023, 07:12 PM | #1 |
Rep 9
Questions on 2024 x5 looking to buy
We went and test drove a xdrive40i but there is no air distribution setting only balanced and dynamic. Is there any way to set only to blow on the floor? Also the driver seat was extremely uncomfortable on the bottom of the seat (caused pain in my thigh on right side) but the passenger seat was ok any suggestions? The seats are multi contour ventilated with sensafin. Also it was a hot day but it seamed like the a/c was struggling to cool, is this a result of the refrigerants or is this normal for BMW? Our saleman was trying to be helpful but not very knowledgeable.
06-10-2023, 07:22 PM | #2 |
659
Rep 1,038
Curious to hear what others who have the LCI say but I had a 2019 x5 with base seats and drove it for 3 years and never thought bottom/thigh areas were uncomfortable. I found the shoulder area to be uncomfortable but with multi contour seats, that problem is addressed
06-10-2023, 08:00 PM | #3 |
13545
Rep 20,183
Welcome to the forum. Hopefully someone with the LCI will chime in but since there is a way to do it in the rear you would think you could in the front.
It takes some time to get the seats adjusted, definitely nothing you could accomplish on a test drive. Once you have done that then you likely will not have a problem. Some have problems with the Pre LCI and others don't would imagine it is the same with the LCI. Many times it seems to boil down to not using the system correctly. Hopefully we hear from some LCI owners.
2021 BMW G20 M340i xDrive - Verde Ermes/Black - 03/2024.40
2019 BMW G05 X5 xDrive40i - Phytonic Blue/Cognac - 11/2023.50 |
06-10-2023, 09:30 PM | #4 |
3209
Rep 6,881
The HVAC system is quite capable, but it takes a little bit of discovery to figure out what works best for you. Note that when in AUTO, the fan speed can still be used, and it's more of an aggressiveness setting.
FWIW, when you need a/c, blowing it all on your feet may not be the best choice! The cold air is heavier, and tends to fill from the bottom up. It often feels cooler if you blow it out higher, and it will fall, producing a more even cabin if you take it out of auto. Personally, AUTO with the fan kicked up a notch seems to work well for me. But, it's not everyone's cup of tea. Depending on the seating options, there can be a huge amount of adjustments you can make to fit most people. Because there's so many things you can adjust, as said, it can take a while to find your best fit. |
06-11-2023, 09:40 PM | #5 | |
568
Rep 839
For the A/C, turn off the rear climate and try it. It is much stronger with the rear turned off and works better. With the new vents in the 2024 (that bar with notches) I find the A/C underperforms with the rear controls turned on. I've been wondering about this problem, my 2022 45e had way better cooling, but the electric powered cooling seemed to be better. Note the stupid start/stop doesn't help things with the A/C. I keep the car in Sport on hot days. For the seats, you will get a million opinions. I had the luxury seats (what your are describing) and hated them. Found them to be too hard. For me, I like the regular multi contour (not massage or ventilation) first and the sport seats second. My guess is as more people get the 2024/LCI there will be more discussions on the A/C including moving the fan control into iDrive 8. I used to fiddle with that all the time, now it is a pain. Something seems off with the A/C when the rear climate is on. |
06-13-2023, 07:53 PM | #6 |
Rep 9
The dealer said they had the seat looked at, so we took another test drive and wasn't much better. I drove for about a half an hour messed with the seat's adjustments a lot with no success still pain in my right thigh. There is no way to set airflow to the floor, I drive 8 not a very good climate system. Played with the a/c but the cabin on a 90 degree day was uncomfortably warm and could never get the cabin cool. The ventilated seats were useless, seemed like the seat got warmer toward the end of the drive. I ordered this car about 2 months ago so i'm going to pass on it, I don't think it is worth 75k. The only enjoyable thing about this car experience was the look on the sales managers face when he was returning our deposit. Time to start looking for something else any suggestions.
01-10-2024, 03:53 PM | #7 |
Rep 3
2024 X5 Seat Issues
Along with the constant software problems I have had since taking delivery in August 23 the drivers seat is very uncomfortable. I have had it in to the dealer 12 times since I got it, mostly to try and correct software problems, but also to try and adjust the seat. I am 6' tall and about 210 pounds and nobody can figure out why the pads that hit your hips are so uncomfortable. Worse on one side than the other, but VERY uncomfortable on anything other than a short drive. This is my 3rd X5 but it will definitely be my last.
01-10-2024, 04:08 PM | #8 | |
1583
Rep 1,190
2024 X5M60i-- Skyscraper/Ivory
2020 Cayenne replaced by ^^ 2017 X5 35d--still in my diesel phase 2015 GL 350--diesel burner/highway queen 2013 Audi S6--a beast in it's day |
WagonFan271.50 |
01-10-2024, 04:09 PM | #9 |
822
Rep 1,795
The ventilated seats have a reputation as being less comfortable. Our heated multicontour non ventilated seats are wonderfully comfortable but ours is a 2019 so maybe they've been redesigned.
LDT1583.00 aussieintexas237.00 |
01-10-2024, 04:33 PM | #10 | |
568
Rep 839
01-10-2024, 09:58 PM | #11 |
85
Rep 81
I have an LCI with the multi-contour seat upgrade. The best compliment is to say I don't notice them at all after the initial adjustment. My wife is very picky about the seats and we ended up with BMW after eliminating half the competition on seats alone. Seats are probably like shoes, dependent on the person.
01-10-2024, 10:28 PM | #12 | |
237
Rep 338
Current - ? 20 X3MC
ED 2016 - F80 M3 - SO/SS CP, LP, EP DAPP, 6 SP :drive: MY ED 2016 WRITEUP 2013 - 2010 E93 M3 DCT, White/ Black - beauty. :Perth, Aust. (sold 2014) 2011 - 2006 E46 M3 Conv SMG Black/black - great (except for SMG) (Perth, Aust). 1st foray into M's -slippery slope (sold 2013) ED 2009 E90 335i - Le Mans, (sold 2010)[URL="http://www.bimmerfest.com/forums/showthread.php?t=365925 |
01-10-2024, 10:42 PM | #13 | |
272
Rep 294
Climate on 8.5. - Airflow distribution can be set to downwards. - I spent a week in the FL Keys with temps in the high 90’s or low 100’s F. I rarely had to adjust or use the highest settings. - However what I knew from day 1, through this forum was, to adjust the individual upper body temperature setting. I lowered it, which made a noticeable difference. If I would have lowered it all the way it would have been too cold. |
LDT1583.00 |
01-11-2024, 08:59 AM | #14 |
198
Rep 230
01-12-2024, 12:08 AM | #16 |
198
Rep 230
