HID install *edit* help needed :)
01-19-2009, 10:54 AM | #1 |
Rep 3
ok guys, ive had a e30 and now on my second bimmer wit my e36. a buddy of mine just got a e90 2006 325i and he doesnt know to much about cars haha. he got a HID kit from Apexcone and ive given it my best shot already and figured the e90post guys would lead me in the right direction. anyone have a link they can post for a DIY or anything helpful?
thanks guys Last edited by 325i 2 m3; 01-19-2009 at 01:56 PM.. |
01-19-2009, 12:54 PM | #4 | |
122
Rep 2,090
+1 on misleading title its one of those titles that try to get peoples attention haha
01-19-2009, 01:55 PM | #5 | |
Rep 3
to try to make it easier, i was just gonna remove the whole headlight so we could really take a look at things but i couldnt reach the last bolt holding it on near the inside of the car. (i got the 2 on top, and the one right behind the wheel well) correct me if im wrong but i believe you have to take the front bumper off to take the headlight out? thats what i read somewhere. so to try to avoid that, i was gonna just try and remove the stock bulb, drill the hole in the cover and just put the hid in and connect it up without taking the headlight...but... couldnt find where the connector for the headlights is? granted we only had an hour to give it a shot, i told him when we had more time it would be done. help help help |
01-19-2009, 08:52 PM | #7 |
382
Rep 2,926
Drives: Cayman GT4, 135i
What you need to do is get a HID Relay Harness. It plugs into your + terminal in the engine and Ground. Along with that resistors to prevent a bulb out error from coming. You do not wanna drill a hole in your lights....
PM me for details i can help. i've had some experience in HID Retrofits
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
10-21-2009, 03:42 PM | #9 |
Rep 1
Same Problem
I am having the same problem as 325i 2 m3 is talking about. I have a 2006 325i with a DDM tuning HID kit. How do I install an HID kit into this vehicle? I am confused because all the wiring for the headlight is contained inside the headlight assembly, and the connector taht connects to the halogen bulb is totally different from the connections on the hid kit. Please help!
Thanks Terry |
10-25-2009, 09:40 PM | #10 |
thatbimmerguy
143
Rep 1,050
Drives: 95 ///M3, 97 ///M3, 08 2002
hey im local in fayetteville and i do these swaps all the time.. contact me if you need info i can hook you up... Some of the other guys from cary have al ready met me
im around if you need me Damon
1995 ///M3 Coupe - 1997 ///M3 Sedan - 2008 2002 - 79 VW Rabbit - 82 Volvo 244 Turbo 135 For Sale Parts Feeler LET THE EAST COAST PLAY TOO!!! |
10-26-2009, 03:14 PM | #11 |
116
Rep 1,528
You are going to have to drill a one inch hole in the back of the headlight cover. The hid kit should come with a waterproof seal with some holes in it for the wiring to go through. Once you do that you are going to have to find a place to mount your ballast. Pretty simple once you think it out.
Muffler Delete/ Tien S-tech Springs / De-badged /BBS LM Reps 19"/ Nexen tires/DTM M5 Front bumper/ Injen Intake/Blacklines/M-tech Rear/Custom Muffler Tips.... More mods to come
10-26-2009, 06:37 PM | #12 | |
Rep 23
10-27-2009, 07:01 AM | #13 |
55
Rep 591
I have the same kit in 07 328i (09/06 build) and it will not even turn on with the car on. Capacitors will make it work but you will still get a lighting system error which is VERY annoying. Bought cancelers from dsc201knoc, worked but still got lighting system error which pops up every minute! After spending about $30 I got everything I need to make a harness similar to "parachute" to get rid of the error.
10-30-2009, 08:09 PM | #15 |
chief general
72
Rep 1,074
i have a 2006 325xi sedan ...my boy just installed my HID w/ digital ballast..but it woouldn't work ... cuz 2006 bmw 3 series suck ...so he put in a relay harness that came w/ resistors for both my HID fogs and low beam ..and it works .....no error .... u have to place the resistors on a metal cuz that shit gets hot ..i learned my lesson ..lolz let me konw if u got any question ...FYI u dont have to take out ur headlights ..
