05-14-2023, 06:00 AM | #1 |
2940
Rep 2,538
Back Panel Above Trunk Rattling
So, just as this description says this part behind the backseats above the trunk is rattling at certain RPMs and also if I go over rough pavement. It’s driving me crazy. Does anyone else have this? What’s the fix. I suspect it’s easy.
05-14-2023, 07:54 AM | #3 |
2940
Rep 2,538
I’m just grateful it was easy to find. With the car parked I climbed back there and started tapping things. When I tapped that panel I could make it do the same noise as when I’m driving. That panel has to be it right?
05-14-2023, 08:51 AM | #4 |
5293
Rep 10,686
If you search for lowering spring install posts, you will find instructions on removing the panel. It is a bit of a pain. If it was removed for some reason and not reinstalled correctly, the rear tabs may be resting on top of receivers rather than securing the panel in the slots. If you have the rear sunshade, the 3 or 4 securing bolts in the trunk roof under it may be loose or missing.
Patton2502939.50 |
05-14-2023, 09:49 AM | #5 |
258
Rep 235
Drives: 2022 M5C /// 2023 XDrive40i
Yep - check on the three 8mm screws underneath the tray from inside the trunk.
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
Patton2502939.50 |
05-17-2023, 08:57 AM | #7 |
317
Rep 516
Be sure it isn't the third brake light up top.
I had a rattle from back there and it turned out to be inside the third brake light. wrap with some velcro tape and all good.
Current: 2021 Oxford Green over Caramel M5C
2022 Ford Mustang Mach 1 : 2021 Yukon Denali : 2011 Ti Silver 128i 6MT, Koral Gone: 2021 Carbon Black X7 M50i : 2018 SG M5 2016 Med Blue 650ix GC : 2008 BSM 535i 6MT 1999 Jet Black 528i |
916_M5366.50 |
05-17-2023, 11:36 AM | #8 |
IG: @M5RCY_
367
Rep 318
sub'ed, im experiencing the same issue. I was going to remove the paneling and install some sound deadening material on the back side
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
05-18-2023, 02:44 PM | #9 |
316
Rep 237
Same here.
I feel like a jackass because I only noticed it after having the H&R lowering springs installed - went back to my friends shop complaining of the sound. Initially sounded like it was coming from the springs/shocks. Was worried something went wrong during the install. Drove me crazy for two weeks wondering if I was safe driving the car. Took the car back in and they basically ripped everything apart to make sure nothing was installed wrong. Of course it was all fine. Still makes the sound. Sounds like something thumping around in the trunk. |
08-18-2023, 05:12 PM | #12 |
519
Rep 389
Mine is doing the same but it’s weird because after 20-30 min it goes away. Next time on cold start it happens again and is very loud and annoying but definitely coming from inside and definitely coming from somewhere behind the back seats.
08-19-2023, 07:19 PM | #13 |
519
Rep 389
I think my rattle is coming from my rear shade block mechanism. When I put the rear windshield shade block up with the button the rattle seems to go away then I put it back down and it comes back at a lower sound. Next day with it still down it’s a very loud rattle again repeat up and down and same thing
08-20-2023, 09:57 PM | #14 | |
113
Rep 219
09-01-2023, 11:35 PM | #15 |
Rep 25
So I figured out the issue. Basically these are a handful of metal retainer clips that need to be expanded to fully grasp the piece and make contact with the trim piece. It wasn’t overly difficult but the seats had to come out along with most of the rear
09-04-2023, 01:45 PM | #16 | |
2284
Rep 3,307
No Photos.... Banned for life. JK. Mike
09-04-2023, 03:36 PM | #17 |
519
Rep 389
clips for which trim pieces exactly? Can you add some pics if you think itll help at all?
