05-04-2023, 02:32 PM | #1 |
Generalissimo
664
Rep 1,426
Coding Tailgate Soft Close
Does anyone know if soft closing of the tailgate can be coded on a G05. I know it can be on F15 but I couldn’t find anything about it for G05 online. This coding company claims to be able to code it - https://www.codemybimmer.ca/g-chassis-coding/, so it seems like a possibility.
05-04-2023, 04:04 PM | #2 |
4739
Rep 8,828
Drives: eVeRyOnE mAD!
I first looked into this almost 2y ago. still no joy.
05-04-2023, 04:52 PM | #3 |
Generalissimo
664
Rep 1,426
https://www.codemybimmer.ca/g-chassis-coding/ claim they can do it. I am waiting on them to confirm.
nZtiZia4739.00 |
05-04-2023, 05:02 PM | #4 | |
4739
Rep 8,828
05-04-2023, 10:59 PM | #5 |
408
Rep 629
Wow, if they can, I think a lot of members would be interested.
I have an infant and a toddler who often fall asleep in the back of my car, getting rid of that THUNK would really help! |
05-05-2023, 11:13 AM | #6 | |
Generalissimo
664
Rep 1,426
05-07-2023, 03:08 PM | #8 |
Generalissimo
664
Rep 1,426
05-08-2023, 11:29 PM | #12 |
Generalissimo
664
Rep 1,426
05-08-2023, 11:39 PM | #13 |
25
Rep 99
05-12-2023, 03:33 PM | #16 |
582
Rep 2,047
Here is method for G05
This is how part of the cafd will look like 3011 APPL_PLG_SPEED_PROFILE, 64(Top tailgate) Code:
ProfileCloseStartNode1PosPlg wert0000 ProfileCloseStartNode1PwmPlg wert00FA ProfileCloseStartNode2PosPlg wert003C ProfileCloseStartNode2PwmPlg wert0262 ProfileCloseStartNode3PosPlg wert0000 ProfileCloseStartNode3PwmPlg wert0000 ProfileCloseStartNode4PosPlg wert0000 ProfileCloseStartNode4PwmPlg wert0000 ProfileCloseStartNode5PosPlg wert0000 ProfileCloseStartNode5PwmPlg wert0000 ProfileCloseStartNode6PosPlg wert0000 ProfileClosestartNode6PwmPlg wert0000 ProfileCloseStopNode1PosPlg wert0000 ProfileCloseStopNode1PwmPlg wert0262 ProfileCloseStopNode2PosPlg wert00C8 ProfileCloseStopNode2PwmPlg wert0262 ProfileCloseStopNode3PosPlg wert0000 ProfileCloseStopNode3PwmPlg wert0000 ProfileCloseStopNode4PosPlg wert0000 ProfileCloseStopNode4PwmPlg wert0000 ProfileCloseStopNode5PosPlg wert0000 ProfileCloseStopNode5PwmPlg wert0000 ProfileCloseStopNode6PosPlg wert0000 ProfileCloseStopNode6PwmPlg wert0000 Code:
ProfileCloseStartNode1Pos wert0000 ProfileCloseStartNode2Pos wert0096 ProfileCloseStartNode3Pos wert0000 ProfileCloseStartNode4Pos wert0000 ProfileCloseStartNode5Pos wert0000 ProfileCloseStartNode6Pos wert0000 ProfileCloseStartNode1Pwm wert0096 ProfileCloseStartNode2Pwm wert02EE ProfileCloseStartNode3Pwm wert0000 ProfileCloseStartNode4Pwm wert0000 ProfileCloseStartNode5Pwm wert0000 ProfileCloseStopNode1Pos wert0000 ProfileCloseStopNode2Pos wert015E ProfileCloseStopNode3Pos wert0000 ProfileCloseStopNode4Pos wert0000 ProfileCloseStopNode5Pos wert0000 ProfileCloseStopNode6Pos wert0000 ProfileCloseStopNode1Pwm wert02EE ProfileCloseStopNode2Pwm wert02EE ProfileCloseStopNode3Pwm wert0000 ProfileCloseStopNode4Pwm wert0000 ProfileCloseStopNode5Pwm wert0000 ProfileCloseStopNode6Pwm wert0000 Node1 starts from tailgate lock. Node6 is top most. It moves from bottom to top. This cafd has only two nodes activated. So the whole movement is controlled by two nodes only. Pwm is the power value that corresponds to speed of spindle. If you want to lower the speed of tailgate close, change all pwm entries above. Just change the wert value in hex to a lower number i.e You can change it to decimal and divide by 2. Convert it to hex and write it back. The tailgate should close 2 times slower. If you lower the speed too much it will trigger the maximum time allocated for closing tailgate. You can overwrite it in MaxTimeClose by increasing the the wert value. Also change TimeoutCloseMov to same value. ProfileCloseStartNode_X_PosPlg refers to the position in the top tailgate where a section starts. ProfileCloseStartNode_X_Pos refers to the position in the lower tailgate where a section starts. ProfileCloseStopNode_X_PosPlg refers to the position in the top tailgate where a section ends. ProfileCloseStopNode_X_Pos refers to the position in the lower tailgate where a section ends. To change lower speed only when near tailgate is nearly closed 1.Change the StopNode1PosPlg value to match StartNode2PosPlg so that when tailgate reaches to StartNode2PosPlg it will switch to profile of node1. (Nodes go from bottom to top, StartNode1PosPlg is at tailgate lock StopNode2PosPlg is tailgate fully open) 2.Lower value of ProfileCloseStartNode1PwmPlg and ProfileCloseStopNode1PwmPlg. Using this setup tailgate will go normal speed and only reduce speed when StopNode1PosPlg is reached(It might be somewhere close to the tailgate lock). If the tailgate reduces speed too early, reduce values of StopNode1PosPlg and StartNode2PosPlg. Remember to do for both lower and top tailgate. If you miscalculate, the tailgates might collide if you setup the speed of the top and lower tailgate independently or the top tailgate moves faster than the lower tailgate. Always be there at the back to monitor the movement of the two tailgates. Here is my setup Top tailgate Code:
ProfileCloseStartNode1PwmPlg Werte=00, 3E ProfileCloseStopNode1PwmPlg Werte=00, 98 ProfileCloseStartNode2PosPlg Werte=00, 32 ProfileCloseStopNode1PosPlg Werte=00, 32 Code:
ProfileCloseStartNode1Pwm Werte=00, 25 ProfileCloseStopNode1Pwm Werte=00, BB ProfileCloseStopNode1Pos Werte=00, 96 ProfileCloseStartNode2Pos Werte=00, 96 |
05-12-2023, 05:59 PM | #18 | |
99
Rep 229
Thank you!! This worked perfectly! |
05-12-2023, 07:32 PM | #20 |
99
Rep 229
05-13-2023, 12:38 AM | #21 | |
Rep 23
Thanks for sharing , will give it a try : )
