bimmerpost/
BMW M2 and 2-Series Coupe
home
BMW 2 Series Technical Topics (G42) Wheels / Tires
      04-19-2023, 08:53 PM   #1
jhall1957
1096
Drives: SE 46
Tire pressure for 4S?
What the best cold pressure and what is optimal pressure when warm(aggressive street) for Michelin Pilot Sport 4S?
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
      04-19-2023, 10:13 PM   #2
ryo-
Drives: '22 MWM M240i
I've always considered 35psi cold to be the standard. or if you wanna be exact, look at the door jamb and follow those guidelines. I have a tire inflator at home so I usually just run that when my tires are cold to 35psi. if you're stopping at a gas station in the middle of a road trip, then I can see it getting tricky. if you go to the tire pressures on your screen, it will tell you the recommended warm tire pressure as well.
jhall19571095.50
      06-01-2023, 09:47 PM   #3
gp_solo2
gp_solo2's Avatar
191
Drives: BMW M235i
According to door sticker it is 38psi cold which will go to about 40-41 when hot.
      08-18-2023, 10:53 PM   #4
pantdino
40
Drives: BMW E36 M3, 2024 M240i RWD
Contrary to the old days when manufacturers recommended low tire pressures (30-32psi) for a soft ride, now they want higher pressures for better fuel economy.
I've always used 36psi cold, but I also find that common dial type gauges can be 1-2 lbs off. So unless you are using a really good gauge, you don't really know what you are setting.
g87
