Hi Kids! - Grandpa calling with a Flat Towing question
04-14-2023, 08:59 AM | #1 |
Rep 26
Drives: 2008 335Xi; 2007 328xi
Hi Kids, this is grandpa calling. I am in a pickle and would appreciate your help.
I own a 2008 335XI 6 speed Manual Transmission with Sport and Cold Weather package. It is stock and I would not modify it for anything in the world, it is perfect for me as is. Well, I finally got a Motorhome; a Winnebago RV e-450 super duty with the famed Ford Triton V10 engine. My main questions are: Can I Flat Tow my BMW? Would the AWD system suffer? I am thinking it would not because all 4 wheels will be on the ground. I know the manual says no, but it doesn’t make any reference to whether the car is Automatic or manual transmission. I know mechanics, but have never worked on a BMW XI transfer case. My thinking is that it should be fine as all wheels would be on the ground. Thank you for any advice/info you guys can share, I will appreciate it. Grandpa! |
04-14-2023, 09:03 AM | #2 |
858
Rep 1,363
Drives: 09 E90 335i M-Sport 6MT RWD
Its a general rule that if towing the wheels rolling on the ground shouldn't have axles driving them.
IF you are getting it towed a short distance to a shop you might get by but ya longer distances isnt an ideal; The awd system freaks out if the tires are a slightly different diameter even. |
04-14-2023, 10:14 AM | #3 |
17377
Rep 18,772
Flat roll towing with an automatic is not recommended because most automatics are lubed by the ATF fluid pump driven off the input shaft, which is engine driven. So basically the trans is not getting proper lubrication when being rolled-towed. Of course if you disconnect the driveshafts then it's okay. Find a lightweight aluminum trailer. Or get a Jeep or a Bronco, which have flat-tow modes.
04-14-2023, 11:14 AM | #4 |
Rep 26
Thank you both I appreciate your input. I currently don't have enough money to buy another car just for Flat Towing. Even If I had, I don't have the room in my driveway for a 4th car as the RV is already taking half of it.
That's why I am inquiring about Flat Towing my 6MT. Does anyone have technical data so as to the transfer case inner works? I have been searching and can't find anything. Thank you everyone. |
Efthreeoh17376.50 |
04-14-2023, 11:50 AM | #5 |
189
Rep 174
This is no different than putting car in neutral and coasting to an offramp or intersection. Obviously coasting usually lasts couple min at most and towing will be xx hours. But same principle applies. There is no pump to push oil in the gearbox or differentials just "power" input is reversed
This is my 2c so take it at your own risk. |
04-14-2023, 12:10 PM | #6 |
746
Rep 1,102
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
Tough for me to imagine the mods required to install the hardware needed for a flat tow hitch on your BMW. My money instead would go to an auto-specific flatbed trailer. They’re not too expensive, as I have looked into them for towing my Z3M.
04-14-2023, 02:36 PM | #7 |
Rep 26
@NikMN - I am in TC BTW.
I agree with you, Mechanically speaking, with the transmission in neutral, my thinking is that the transfer case should be fine so long no electronics are running and requesting or sending "signals/instructions" from the sensors in the wheels. However, I would like to know if there is anything else I am missing or should be aware off. ppointer - I also agree with you. It would require modifying a front tow plate and bolt it to the front frame. Luckily our cars do have bolt it frame face. That possibility is what makes me inquire about the transfercase, otherwise i would not even research it. getting a Trailer is brings me back to the same reason I can't buy a Tow vehicle. Money and Space to storage it afterwards. |
04-14-2023, 07:26 PM | #10 | |
17377
Rep 18,772
BlackNight287.50 |
04-14-2023, 09:56 PM | #11 |
2740
Rep 4,065
Would you tow a 4,000 lb. Trailer with NO brakes on the trailer?
How far, & at what speeds do you intend to go? Where do you intend to go with the 335xi that you can't go with Winnebago? HOW/WHERE would you attach Tow Bar to 335xi? I'd "pick one" and NOT risk damaging BOTH. (But that's just ME) George |
jsunma653.50 |
04-15-2023, 01:34 PM | #12 |
638
Rep 766
I'm on team 'get a trailer'. Flat towing cars is super sketchy. Put it in a cheap outdoor self-storage spot when not in use.
Note @Efthreeoh above about the steering lock. Take heed. T-case will be fine. It's being rotated by the front axle and lubricated. Default 'car not running' position for the T-case is disengaged. I'm not sure it's safe for the transmission. Maybe somebody that has actually done it can say otherwise. The issue with the transmission is the output shaft is up top and dry, the transfer shaft is on the bottom in the pool of gear oil. Output shaft will be spinning at road speed driven by the rear axle. Transfer shaft will NOT be spinning. No oil is moved from the pool at the bottom to the top to lubricate the bearings on the upper output shaft. If the internal layout of the box has some of the syncho sets on the transfer shaft, then those gears will be spinning on the lower transfer shaft, which will move gear oil up top.... will those gears move enough oil up top to distribute it to all the bearings, I don't really know.
Sometimes a bolt is just a bolt.
04-15-2023, 05:46 PM | #13 | |
654
Rep 815
04-15-2023, 06:01 PM | #14 | |
1437
Rep 2,526
Drives: 2011 328i Wagon
With a manual, I would just do it. In an ideal world, I too would get a trailer, but if you don't have the means, you do what you need to do. I don't think it will hurt a thing.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
e90yyc2426.50 |
04-15-2023, 09:04 PM | #15 | |
Art Collector
2427
Rep 3,450
When I'm dead, just throw me in the trash.
Mike K322.00 |
04-25-2023, 03:07 PM | #16 |
Rep 26
Thank you everyone for your answers and insights. I appreciate them all.
My daughter decided that I can add a tow plate to her car so I take hers when I go camping. Obviously, she will be getting my 335 for that time. I would like to call this a Win-Win, but wonder if I will need new tires when I get my car back. I truly appreciate all your comments. You guys are a great bunch. Grandpa. |
