03-22-2023, 02:48 AM | #1 |
Autobahner
29
Rep 30
Keyfob comfort access signal motion sensor shutoff time ?
I was wondering if anyone knows how long the timeout period is for the BMW keyfobs to realize they've been set down somewhere and should stop sending out the comfort access signal?
Background to the question: One thing people are concerned about regarding comfort access is that criminals using signal boosters can amplify the periodic signal your keyfob sends out trying to reach the car that basically indicates "I'm close enough now so that comfort access should be possible" and the car responds appropriately. I understand that BMW have implemented a motion sensor into their newer keyfobs so that if it senses no movement for a period of time, it stops sending out that signal, thus foiling the criminals strategy. They can't boost a signal that's not being sent. Mercedes did this in a simpler way, you simply double-press the lock button when locking the car and that told the keyfob to not send the signal out. That meant that when you come back to the car you don't have comfort access though. The BMW solution is more expensive but more useful. You don't lose comfort access functionality as long as you're moving around enough to keep the motion sensor convinced it's not inactive. Btw, I wish Bimmerpost had a general BMW section to post questions like this that aren't specific to the model of BMW I have. It's limiting the audience of the question quite a lot.
Current BMW: 2019 X3 30i. Previous BMWs: E34 ///M5, E60 545i, E39 535i, E36 325Ci, E32(750i, 735i, 730i).
Others: 2 S-Class, 5 E-Class, 4 Supras (Mk4,3&2), 1 Celica GT4, 2 300ZX-TT, 1 Boxster, 1 Audi A6, 1 Subaru and others. Pics on Instagram |
03-22-2023, 03:03 AM | #2 | |
140
Rep 88
BMW has not publicly disclosed the exact timeout period for their keyfobs to stop sending the comfort access signal when motion is not detected. However, it is generally believed that the timeout period is somewhere between a few minutes to an hour, depending on the specific model and year of your BMW. The motion sensor feature in the BMW keyfob is designed to prevent relay attacks, which involve criminals using signal boosters to extend the range of the keyfob's signal to unlock and start the car. By stopping the transmission of the comfort access signal when the keyfob is not in motion, the risk of such attacks is significantly reduced. However, if this is a concern for you, then I suggest the following. https://www.autowatch.co.uk/veh-sec/ghost-2-menu Happy Installing! |
03-22-2023, 04:25 AM | #3 | ||
Autobahner
29
Rep 30
03-22-2023, 05:22 AM | #4 | |
2775
Rep 4,342
Long thread from a UK member who had major issues with warranty having installed a Ghost. |
03-22-2023, 06:25 AM | #6 |
89
Rep 241
Drives: X3 xDrive30e M Sport 2020
Agree 2 minutes.
Tested by leaving the key on top of rear offside tyre.
Gone 330e M Sport+ 2020
03-22-2023, 08:09 AM | #7 | |
Autobahner
29
Rep 30
03-22-2023, 08:42 AM | #8 |
1087
Rep 908
Drives: 2022 X3 M40i LCI
Doesn’t matter anymore about sleeping keys. This is no longer the current method. Latest in the UK is to plug into the cars electrical system with a device that overwhelms the electrical system and as everything’s connected via can-bus this gives access to the car etc, deactivates the alarm. Common connection points are via the rear reversing camera or the rear of the headlight via the access panel in the inner wheel arch.
No need for key signals or relays.
2022 X3 M40i LCI. Brooklyn Grey Metallic. Driving Assistant Professional. Black with Blue Stitching Vernasca Leather M Seats. Comfort Pack. Pano Roof. OEM Carbon Fibre Interior Trim. 21” 718 Alloys.
03-22-2023, 09:04 AM | #9 | |
Autobahner
29
Rep 30
I was only a little bit concerned about the relay method and wanted to hear about the motion sensor timeout. Now I know it's 2 minutes I really won't need to be concerned about whether I should use that faraday pouch when I'm parked close to where the key is (like I was at Christmas, parked right outside the cottage I was renting). I had a Mercedes at that time and double-pressed the remote to disable comfort access.
