330i Acceleration
05-16-2006, 12:22 PM | #1 |
Rep 34
330i Acceleration
Where is the power distributed on in the 330i?
If I want to go fasted 0-60 do I keep the revs in the 3-4000 rpm range thru the gears or do I keep it 5-6000 rpm or where?
2006 330i Alpine White, SP, CWP, PP, NAV
05-16-2006, 12:26 PM | #3 |
285
Rep 3,924
well, from the specs, you should be getting max torque at 2750 rpm.
2011 E92 M3 - IB/Beige/Sycamore Wood/6MT/EDC/ZPP2/Nav/PDC/Heated Seats/iPod-USB/Enh. Audio
2008 E92 335i - Montego Blue/Black/Gray Poplar/6MT/ZPP/ZSP/Nav/PDC/Heated Seats/HDRadio/iPod-USB - Sold 2006 E90 330i - Mystic Blue/Black/Aluminum/6MT/ZPP/iDrive/PDC/Heated Seats/Sat. Prep - Sold 1994 E36 325i - Boston Green/Beige/Automatic/ZPP/Heated Seats/Premium Sound - Sold |
05-16-2006, 12:30 PM | #4 | |
119
Rep 2,909
05-16-2006, 01:57 PM | #5 |
30
Rep 686
6000-6500 rpm seems to be the sweet spot.
2008 335i | Sport | Premium | USB | SSK | æ | Unsprung Diet
2006 330i | Sport | Premium | Active Steering | M-Sport Aero Kit | Retired |
05-16-2006, 02:02 PM | #6 | |
341
Rep 16,407
Torque gets you off the line, HP gets you to the end. Peak torque is at 2750 but the band is good throughout the full range. Peak HP is at around 6000 so you should be shifting by about 6500 to keep from bloging down. Shifting there should throw it back to the 4K range as you're running through the gears. Last edited by Carnage; 05-16-2006 at 04:08 PM.. |
05-16-2006, 02:35 PM | #7 | |
A ROOM WITH A MOOSE!
24
Rep 420
totally agree but don't let off the gas |
05-16-2006, 03:39 PM | #8 |
22
Rep 490
Wow, i thought this might be a useless thread, but there was some good info given.
Thanks
2008 E93 M3 6MT, White/Bamboo SOLD!!!
2011 F10 550i Sold 2012 750Li Sold 2013 M5 6 speed |
05-16-2006, 04:32 PM | #9 | |
34
Rep 519
'14 535i (ED)
Retired: '08 M5, '08 550i (ED), '06 330i |
05-16-2006, 09:37 PM | #10 | |
Rep 5
All the other shifts at 6000 - 6500 RPM were quite fun |
05-16-2006, 10:30 PM | #11 |
13
Rep 427
assuming you have a manual transmission, I believe maximizing 0-60 acceleration largely involves perfecting your launch technique. This definitely requires some skill and practice. For example, if you launch with too little RPM you will have a higher time. But if you launch at too high an RPM, you may have too much wheelspin. I believe that the fastest times usually involve some wheelspin. The objective is to experiment and find just the right amount that maximizes initial acceleration. After that, I would suppose full throttle acceleration through the gears, shifting as rapidly as you can do so smoothly and with finesse (lift throttle with the clutch fully disengaged). I would try to hit as close to redline as possible.
Obviously, do it in a safe place and warm up the engine first. Alternatively, you can try to maximize your 5-60mph time (from a rolling start). This is still fun and reduces clutch wear and shock to the drivetrain from the rapid starts described above.
2006 330i, SP, PP, fold down rear seats, sparkling graphite, black leather, metallic trim.
05-16-2006, 10:32 PM | #12 |
13
Rep 427
obviously, would want to turn DSC off for the 0-60 times, to allow wheelspin. Might want to turn it back on after getting going, however, to increase stability in case evasive maneuvers must be made or during rapid deceleration from high speeds
05-16-2006, 10:59 PM | #13 |
258
Rep 408
Maximum overall acceleration is achieved when you keep the engine as close to the point of peak power as possible. And the optimum shift points for the car is when the thrust in the next available gear exceeds the thrust available in the current gear, based on the torque curve of the engine and the specific gearing.
Has anybody dynoed a 330i 6MT on a Dynojet 248C? I'd love to see a plot of one. I could easily calculate the shifts points if somebody has one. Somebody posted one for a 325i 6MT over here, and given the power ratings it was pretty impressive. http://www.e90post.com/forums/showthread.php?t=7801 I'm pretty sure a dyno would show the optimal shift points to be all the way up at redline, unless there's some huge drop-off in torque before you get to redline that is.
2022 G05 X5 40i Phytonic Blue / Ivory | 2011 E93 335i Deep Sea Blue / Oyster | 2012 E70 X5d Deep Sea Blue / Sand Beige (ret)
2018 Chevy Suburban Premier 4x4, Pepperdust / Cocoa, Adaptive Cruise, HUD, 3.42 gears (my DD & full circus long-hauler) |
05-17-2006, 01:40 AM | #15 |
S0THPAW
8736
Rep 7,847
Already said I nknow
EU spec says the 330i has 258BHP @ 6600rpm. There(6600) you should shift. ALSO in first gear. And YEP turn the DSC/DTC thing off if you want to go more smoothly(and a bit of wheelspin) At track/ringdays I'm always shifting at redline(7000)Poor engine.LOL |
05-18-2006, 01:04 PM | #16 | |
BMerDRMer 2006 330 Xi Man ZPP ZSP CW NAV CA TiAg BlkLthr Burl 18in 162's
Rep 214
BMerDRMer 2006 330 Xi Man ZPP ZSP CW NAV CA TiAG Blk Lthr Burl 18x162's
05-18-2006, 04:30 PM | #17 | |
BMW, can I have some LSD please?
88
Rep 1,591
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
