03-04-2023, 11:39 AM | #1 |
682
Rep 527
CSF Charge Coolers - Reviews/comments?
Hi! I am looking to add the CSF Charge Coolers to my 2019 M5 Comp. Does anyone have any experience with them? Pros/Cons? Did it effect anyone's engine in a bad way? Do they throw any code? Would you consider them a safe mod to our engine?
Any input would be great! Thanks! https://csfrace.com/csf_products/dir...oling-systems/ |
03-04-2023, 01:20 PM | #2 |
182
Rep 321
I installed the coolers weeks prior to installing Carbahn stage II. I did not notice any difference. They are much heavier than stock. There are earlier posts on this topic. One comment is that it is great if you are running laps around a race track. Quartermile, not so much. I would put $$ elsewhere
03-04-2023, 01:43 PM | #3 | |
682
Rep 527
03-04-2023, 04:14 PM | #4 |
5263
Rep 10,644
Buy the heat exchangers for the coolant as well and build your motor and run bigger turbos. One person who did all that dropped 3/10th second 60-130 mph time.
03-04-2023, 04:40 PM | #5 |
682
Rep 527
Do you run the CSF Charge Intercoolers? Do you have any issues with them? I am just looking at the charge intercoolers at the moment.
03-04-2023, 07:01 PM | #6 |
5263
Rep 10,644
No. I have just researched and considered them but they add no performance on their own so I see no point other than the meth bung on the cold side. I have been running my meth into the balance tube on the hotside as BMS suggests for the simplest install.
03-05-2023, 10:30 AM | #8 |
Joint Chiefs of Staff
24331
Rep 191,093
We sold 5-10 kits, all good feedback
dcohen13682.00 |
03-05-2023, 06:19 PM | #9 |
682
Rep 527
03-06-2023, 09:22 AM | #11 |
24331
Rep 191,093
06-16-2023, 09:42 AM | #12 |
5263
Rep 10,644
Pain in the rear to remove stock IC because the compressor and throttle body rubber connectors were stuck 360 degrees to the IC. Made me think maybe BMW used sealant on the inside of the connectors.
I am doing this for the meth bungs on the cold side — right now I have my meth plumbed in the balance tube on the hot side using the BMS kit. Later, I will install new front heat exchangers to add capacity to the system and improve the heat exchange. Without that, the research suggests the fancy IC do little to nothing for performance. They definitely add core capacity — they are physically as large as will fit in the available space. Last edited by pbonsalb; 06-16-2023 at 08:39 PM.. |
06-18-2023, 09:31 PM | #13 |
113
Rep 216
