02-07-2023, 03:02 AM | #1 |
Rep 6
HELP/m-sport seat swap
Going to start this one off by saying I'm not that great at coding, and probably need this one dumbed down a bit for myself and other amateur coders on here with similar issues. I can't find anything helpful on other forums
My original seats were power, heated, with lumbar. (Luxury line car) I Swapped some seats out of a parts car that has the exact same options just has the more aggressive bolsters on it (I occasionally track my car so it's important to me) Attached I have modules from my donor m-spt seats (1) and my original seats (2) I did not switch the airbags out like I should have before I let the seats go. Passenger seat operates fine(heat, lumbar ect) it just pops up as a restraint malfunction on idrive. However the driver seat does not work at all. The only way I can move it is if I unplug the module and plug it back in and turn on the ignition, I get about 30 seconds before the car senses an issue and it cuts power to it. Note : also has the same malfunction as passenger seat How do I code in the new airbags and seat modules to make my seats function as normal? I have my seat position set where I like it, but I do miss having my heated seats and my wife is shorter than I and can no longer drive the car because she can't move the seat. Could use some help as I have only really done the basics in coding and couldn't find anything in the guide. |
