Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > FRONT STRUT BRACE on a 335xi
      01-07-2009, 04:40 PM   #1
Spydeputy
Spydeputy's Avatar
Germany
205
Drives: 2015 F23 M235i/2008,E90,335xi
i'm sure this one must have been around before. if so, sorry i could not answer my own question.
i am looking to put a strut brace on my 2008 335xi. i saw on a post where the installer used washers under the bolts to clear the engine and such. it also mention that the ends of the strut were doing some ramping where they bolted down. it would seem to me that with the washers, and the ramping that all that would be gained from the strut was lost in the alterations.
is this true?
the head tech at Bel Air, BMW said the BMW strut will not work because of the turbos getting in the way and that the strut towers on the xi's were a little straighter (vertical) than on the non xi's.
and if this is true, anyone know of a strut brace designed for the xi's ?
thanks, dave
      01-08-2009, 01:19 AM   #2
UdubBadger
631
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
i was able to get an mforce design strut tower on my xi by cutting one of the bolt slots open to get to install correctly but I have an NA so our engine bays are a bit different.
      01-08-2009, 07:17 AM   #3
Mill999red
Mill999red's Avatar
7
Drives: 335XI/MV Agusta F4R
I have a AL STRUT TOWER BARS by JIC CROSS from **********s.com Great fit and great price. I have a E90 335XI.
http://www.e90post.com/forums/showthread.php?t=162800
335XI E90 AW/MT/ZCW/ZSP/18" 162
      01-08-2009, 07:28 AM   #4
ToadHollow
Once upon a time ......
ToadHollow's Avatar
Italy
276
Drives: 2008 JB E92 - SOLD 5/2010
2008 E92 335i  [8.00]
I purchased my strut brace from BMW and found that it sets nicely over the DCI but will not fit properly over the stock intake without modification .... AKA removal. No, this isn't an XI model but thought it might give some perspective none the less.
      01-08-2009, 09:09 AM   #5
SGxi
158
Drives: E90 328xi
2007 328xi  [0.00]
Sorry if I may have hi-jacked the thread. Does anyone know the reason why the OEM strut braces (both versions) are not "officially" recommended for the xi?
I have the OEM one on my xi (not 335) but it is a perfect fit.
MY07 A22 E90 N52Nxi
      01-09-2009, 04:33 AM   #6
Spydeputy
Spydeputy's Avatar
Germany
205
TO SGxi
read the last paragraph of the original post, should get your answer there.
hope this helps. the tower are more straight, up and down (vertical).
      01-12-2009, 01:16 PM   #7
SGxi
158
Drives: E90 328xi
2007 328xi  [0.00]
Actually, on the E90 325xi and 328xi, the OEM ones posted in the picture is a direct bolt-on for the car. It doesn't require any modifications on the brace or the car itself.
MY07 A22 E90 N52Nxi
      01-13-2009, 12:44 AM   #8
battlehawk1025
battlehawk1025
battlehawk1025's Avatar
Drives: 2007 335XI 6mt, SL 65 , M6
i have one on my car too and im a e90 335xi. no problems what so ever
      01-13-2009, 12:51 AM   #9
jgalaxy
Gearing
jgalaxy's Avatar
86
Drives: E46 M3, F22 M240
I don't recall the XI having limitations for the front strut brace - It possible certain aftermarket braces have an issue. The air box on the 335 is what is typically in the way. Going to an aftermarket intake usually clears that issue up by freeing some space.
If at first you don't succeed ...
      01-13-2009, 10:52 AM   #10
SGxi
158
Drives: E90 328xi
2007 328xi  [0.00]
BMW's catalogues specifically indicate the OEM strut brace is not suitable for xi models. So I'm just wondering if there's any justification for that.
Though I have to admit, they don't recommend 19s on the xi cars either...
MY07 A22 E90 N52Nxi
      01-13-2009, 01:17 PM   #11
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
Get the M3 front strut brace and call it a day
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      01-21-2009, 04:45 PM   #12
stratplaya06
stratplaya06's Avatar
Drives: 2008 E92 335xi-SOLD 5.0 Miata
Kev, has it been confirmed that the m3 strut brace will fit the xi cars? I have the AFE DCI and I don't want the bar going near there, not to mention I really like how the m3 brace looks.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife |
      01-24-2009, 12:44 AM   #13
flipmde786
Drives: 330xi
My strut bar fit perfectly.
2006 330xi
[TiAg] [Black Leather] [Aluminum] [STEP] [ZPP] [ZSP] [ZCW] [CA] [35% tint] [Blacklines] [OEM Strut Bar] [OEM Spoiler]
      01-24-2009, 09:58 PM   #14
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
fits on stock airbox, not sure about aftermarket ones.
      01-26-2009, 02:51 PM   #15
GmanJeff
Drives: 2021 X3M, 2016 X5
For those of you who have installed a front strut brace, I'd be interested to know what dynamic driving differences you experienced after installation. Do any improvements seem to be material enough to be worthwhile?
      01-26-2009, 03:10 PM   #16
ToadHollow
ToadHollow's Avatar
Italy
276
What I have and continue to experience is the steering/handling seems to be a bit more precise as the car doesn't (in my case) hop so much when taking a curve ......... it isn't anything you're going to really notice riding around town ......... I believe the addition of front/rear sway bars would compliment this well.
      01-27-2009, 05:46 PM   #17
battlehawk1025
battlehawk1025
around town you won't notice anything. when i'm having fun on the enterence and exit ramps. slightly less body roll in front, and the stated above the car doesn't hop over bumps
      01-27-2009, 05:52 PM   #18
battlehawk1025
battlehawk1025
      01-27-2009, 08:45 PM   #19
flipmde786
Drives: 330xi
+1
2006 330xi
      02-10-2009, 07:04 PM   #20
ARA5HE90
ARA5HE90
ARA5HE90's Avatar
124
Drives: a beast!
2007 328XI  [0.00]
i have a dinan strut bar on my car.. and its a perfect fit.. no mod required
2oo7 e90 JB 328xi/// with too many mods!?!?!
check out my ride = http://www.e90post.com/forums/showthread.php?t=246531
2oo8 e90 SSII ///M3 *the silver ghost* = http://www.m3post.com/forums/showthread.php?t=409084
      03-03-2009, 01:46 PM   #21
335xidave
Drives: Dinan3/335xi
Toadhollow, I'm thinking of buying a DCI intake, was it worth the money?,,did you notice any performance gains?
      03-03-2009, 03:55 PM   #22
ToadHollow
ToadHollow's Avatar
Italy
276
I'll answer this question as an opinion ONLY. Lots of different opinions on this forum so..........
Yes, performance gains and yes, IMHO it is worth the money (especially in comparison to some of the new intakes being introduced). I have the Pro-Dry filters as I didn't want to deal with the cleaning/oiling deal (been there, done that with previous intakes).
I dyno'd the car last summer with the DCI and the "swoop scoops" installed. I was able to show a sustained gain of an average 15rwhp over the stock intake. Albeit, this was in 90+ degree heat and 65% humidity. To make things worse, I later found the car had runnability issues and codes. Once the codes were cleared; the car was running like I had just had the Dinan installed all over again. I never got to dyno again though.
So, the DCI has enabled MUCH better throttle response, more hp and better mileage (just over 2 mpg increase to date). The only change since the dyno has been the replacement of the "swoop scoops" with the RPI scoops.
Search this Thread:
Advanced Search
