01-15-2023, 09:15 AM | #1 |
67
Rep 117
M5 F90 - engines/reliability
Hey guys,
I'm not writing to report any issue but to start a discussion. After few years since the model was introduced what do you guys think about its reliability? I have mixed feelings: there are "stock" cars that blow engine after some stupid low mileage and there are also "tuned" cars that run for months/years without any issues. We all know BMW has a bad PR for V8 engines after the F10 model where you had to service it almost always after 100,000 km's but how it is with F90? I personally own F90 for 5 years now with 70,000km's driven (2018 model) and I didn't have any issues except BDC error after badly coded retrofit rearlights. Looking at the used cars market I have found at least few M5 that have engines replaced at similar or higher mileage. So what are your thoughts? |
01-15-2023, 09:21 AM | #2 |
2951
Rep 2,365
I am very interested in this thread. I have an F90 being built as I type this. I don’t plan to tune it and the only engine modification I’m going to do is put Evolve intakes on it. I sold my 992 turbo s to get this one. That was one hell of a reliable engine in that car. I hope we don’t have a legion of people posting here that this engine in the F90 is a lemon. I don’t think that will happen. But let’s see.
01-15-2023, 10:57 AM | #3 | |
1111
Rep 1,940
Patton2502950.50 |
01-15-2023, 12:58 PM | #4 |
6078
Rep 11,593
And the S63 TU4 is a further updated version of the latest F10 engine. Rods were not changed and remain the weak point at higher than stock boost or low octane gas. Evolve has rebuilt a few with essentially no internal improvements other than aftermarket rods and made 1000 hp. Big job to change rods, though.
01-15-2023, 01:58 PM | #5 | |
2951
Rep 2,365
01-24-2023, 11:24 AM | #6 |
134
Rep 182
Reliability side: Anything can happen with any manmade mechanical device. It can fail at 250 miles, 25,000 miles, 250,000 miles etc. There are numerous things that can cause an engine failure. The key for us owners is either trying to minimize the likelihood of failure, or just living with the fact that stuff doesn't last forever and no engine is perfect. It seems like these engines have gotten better over the years. Issues start to arise more frequently when the car is tuned.
Money side of it: Everyone says its a $50k engine. That scared me. But in reality, it is like $5k in labor to remove and reinstall the engine, and probably $10K-15K for a rebuild depending on what needs to be done. So if you tune it, you are risking $20k or so. If you don't tune it, you aren't risking anything for the first 4 years or 50k miles. If you are keeping the car after the 4 years or 50k miles, it would be nice financially to get an extended warranty. I think Fidelity has a good one. Last edited by hunter8793; 01-26-2023 at 08:24 PM.. |
01-24-2023, 01:33 PM | #7 |
14
Rep 31
I think any engine depends on how you take care of it. Yes, there are recalls and design flaws, but if you change the oil regularly and take care of the needed parts and updates I think you can get a good life from these engines.
The only thing I foresee after 50-60K is the heat component. I think the BMW V8 Bi-Turbos give off lots of heat under the hood and the surrounding hoses and plastic parts take a beating. There is no way those cna survive to 100K like the old E30 and E28 hoses and plastic parts did. |
01-25-2023, 01:21 PM | #8 |
4328
Rep 7,460
Drives: F90 M5 / F15 50i
the S/N63TU has come a long way in reliability. Looking at the X5 50i and X5M side of the house the engine has been bullet proof if taken care of. I'm approaching 80k on my 50i with only an oil pan gasket currently needing to be replaced. Not a single other engine issue. Heat is an issue. Change the thermostat, turb blanket, remove primary CAT and change the oil temp sensor to a lower temp version and you will greatly increase the life. However, as stated, the plastics and clamps that coolant traverses will break down over time so keep an eye out for coolant leaks etc.
'07 Yamaha R1 (sold)
01-26-2023, 02:22 PM | #9 | |
1545
Rep 2,111
It's just how things are, it's cost vs performance, if it lasts 50k miles so the warranty is up they're happy. First owner is usually happy after the lease is up and they turn it in for the new toy and the second third 5th owner gets left with the problems. |
styellz0.00 |
