The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Secondary cat delete pipes for 328xi
      12-27-2022, 08:30 AM   #1
infinitenexus
infinitenexus's Avatar
Drives: BMW 328xi
Supersprint makes pipes that delete the secondary cats, but from what I've read they won't fit the xi models as the transfer case is in the way. Can anyone confirm that?
And if so, is our only option to cut the cats off and weld a pipe in there? If so, I'll be hitting up local junkyards I guess.
2008 328xi
      12-28-2022, 06:37 AM   #2
infinitenexus
Drives: BMW 328xi
I'm going to assume that the lack of responses means I'm correct.
2008 328xi
      12-28-2022, 11:01 PM   #3
whyzee125
1679
Drives: Dinan stage 2 335i
If the cats fit, a straight pipe will fit. I'm not sure about the supersprint test pipes, but you could always cut them off then have a muffler shop weld in a pipe to bridge the gap.
Make sure you remove them yourself, as if they do, they'll want to keep them and scrap them themselves.
      01-18-2023, 08:20 AM   #4
jadams161
jadams161's Avatar
Drives: 2009 E93 335i. 2011 E90 328xi
wrong forum
      01-18-2023, 09:29 AM   #5
infinitenexus
Drives: BMW 328xi
Originally Posted by jadams161 View Post
wrong forum
How is this the wrong forum? I'm asking about cat delete pipes specific to the xi models, since I've seen some people say fitment is different on the xi.
2008 328xi
      01-18-2023, 09:57 AM   #6
jadams161
jadams161's Avatar
The x drive is for the x drive system.. not the whole car. Post or search in the N52 engine/exhaust forum. There is no difference between converters with RWD or AWD.
