Driveline vibration and noise 328xi
12-08-2022, 09:37 AM | #1 |
171
Rep 339
I recently bought a 2011 328i xdrive. I did all services and fluids. New tires and balanced. I have noticed a slight resonance or vibration in the car at speeds above 50mph. It is more apparent while sitting in the passenger front seat. Searching reveals many posts about various vibrations in the xdrive. But none seem to ever post a fix. Has anyone narrowed it down? I plan to do the 2 flex discs in the driveshaft soon. But I am not expecting it to resolve the issue based on old posts. Vibration is constant whether coasting in drive or neutral and is in the floor/seat of the car. I am tempted to put it on the lift and run up the speed to feel how it is with wheels off the ground.
12-08-2022, 03:41 PM | #2 |
638
Rep 766
Driveline vibration issues have all been solved. Only so many parts that are likely to cause it.
Guibo(s) Rear driveshaft U-joint(s) Carrier bearing Front driveshaft T-case front output yoke If all those things are in order, the driveline will be smooth. Don't forget front strut rods, brakes, and possible shoddy wheel balancing (static only?) Every e90 has bent wheels unless you've gone out of the way to replace or straighten them.
Sometimes a bolt is just a bolt.
Suvorovo254.00 |
12-08-2022, 05:05 PM | #3 |
171
Rep 339
New front driveshaft. Rear driveshaft ujoints are good. Carrier bearing is good. Doing Giubos soon. Rear diff and front diff smooth. New brakes all around. Original rear axles (could be bad but no noise)
02-07-2023, 11:12 AM | #4 |
Engineering dude
Rep 9
I am trying to solve the same issue on my 328xi. Did you ever solve this problem?
2008 328xi - metallic gray 2002 330Ci - steel gray metallic The harder you work, the luckier you get. |
02-07-2023, 11:26 AM | #5 |
171
Rep 339
I replaced the rear driveshaft too.. unfortunately I think it's the transfer case.. not sure I want to mess with it or just deal with the vibration.
It's weird because sometimes it drives smooth. Last edited by jadams161; 02-08-2023 at 06:57 AM.. |
02-07-2023, 12:11 PM | #6 |
Engineering dude
Rep 9
I was afraid to start throwing parts at my car without a better idea of what it might be. I thought it was one of the driveshafts, but they seem good. I guess I may be getting one from a junkyard.
02-09-2023, 06:32 AM | #7 |
171
Rep 339
The new noise my transfer case is making while cold. It goes away after a mile or 2 and only does it between 30-39 mph.
https://www.youtube.com/shorts/OwMd8sgFzxI |
Saico29.50 |
02-17-2023, 03:18 AM | #8 |
30
Rep 85
jadams161, I have exactly the same buzzing noise that you recorded!
And exactly in the same speed, and goes away after 1-2 miles :P This started after my xdrive transfer box was regenerated (new bearings + new clutch kit). While doing this I also replaced the rear guibo and center bearing. First I thought it was a faulty center bearing so I replaced it once again to no avail. Then I thought if might be a little center bushing that is pushed in the driveshaft - no, this was not it. Also replaced the front driveshaft - still not the case. This noise is driving me crazy. Looking for some advice here. PS. In the BMW repair manuals there's an instruction that: To avoid buzzing sound after refitting the propeller shaft: 1. The flexible disc connection (1) on the front and back at the propeller shaft must be marked in one plane with the flexible disc (2) and the three-bolt flange (3) before removal. 2. During installation the three-bolt flange (3) must be forced back together again with the flexible disc (2) in the same position. 3. Replace ZNS bolts and self-locking nuts. Of course I did not mark the connection, also did not replace the bolts/nuts. But I already changed the position of driveshaft vs. output flange two times and it did not help. Could this be the bolts/nuts? Last edited by Saico; 02-17-2023 at 03:27 AM.. |
02-17-2023, 07:53 AM | #9 |
171
Rep 339
Mine started with a completely new rear driveshaft.. the Guibos have an arrow on them for proper installation. The driveshaft I bought has them already installed, I just bolted it up. I've been trying to stop a drive line vibration and thought I had a bad u joint or driveshaft. Still have the vibration and now that noise.
I'm actually picking up a used low mileage transfer case today to install. If that doesn't work then I guess I'll just live with it. |
02-17-2023, 07:55 AM | #10 |
171
Rep 339
The BMW instructions sound like they want the old flex discs marked with flanges if you plan to reuse them , if replacing with new flex disc then marking would be irrelevant
02-17-2023, 08:43 AM | #11 |
30
Rep 85
Ok, please let me know if changing transfer box will help. I am close to that too, even though I refurbished mine already and 4x4 is working fine.
For the bmw instructions I guess they want you to mark the position of flanges in relation to each other. Flex disk position is I guess irrelevant, as you said. Maybe the flanges are balanced or something. |
02-19-2023, 02:49 PM | #12 |
171
Rep 339
Today's update. Took out the old T case and broke it open. No metal or broken parts inside but the bearings are definitely on the way out. The 2 main roller bearings are pretty loose and the the main race is heat scored from when it was low on fluid. I'll rebuild it and keepnas a spare.
02-19-2023, 03:05 PM | #13 |
30
Rep 85
I had my TC out and disassembled a few times. The roller bearings I replaced twice. Before you assemble everything make sure the middle wheel is rotating freely on new bearings - mine was stuck and I had to grind the race a little bit to gain some play.
02-21-2023, 03:24 PM | #14 |
Engineering dude
Rep 9
That transfer case looks very clean! Can you post photos of the parts you said are loose or heat scored?
02-21-2023, 03:36 PM | #15 |
171
Rep 339
I already closed it up to store it.. but it's the raced roller bearing on the center gear, one underneath too. When I rebuild it I will replace all bearings, clutch drum and the clutches. There are a bunch of small bearings that I can't believe are used inside..
02-22-2023, 03:02 PM | #17 |
254
Rep 502
Where'd you go for a transfercase rebuild? I would think parts are hard to come by.
02-23-2023, 05:35 AM | #18 |
30
Rep 85
Not really.. almost all of them you can buy here:
https://awd.tech/ https://maktrans.net/zaptchasti-akpp...Transfer-Boxes The rebuild I did myself. |
02-23-2023, 07:07 PM | #19 |
171
Rep 339
Well I got the new Tcase installed and drive the car. The noise is unfortunately still there. But the vibration is thankfully gone.
So it's either coming from the transmitter or the new china driveshaft I installed.. not how that would make the noise tho. Going to double check the trans fluid levels again.. aside from that I guess I live with it. |
02-24-2023, 10:58 AM | #21 |
171
Rep 339
New shaft comes with flex joints mounted. Reused the bolts to flange as they are steel and replacement isn't required.
I'd put the old driveshaft in but I was a dummy and split the halves without marking them So it's most likely a transmission noise. Happens when cold from 27-32 mph.. under or over that and no noise. I need to check fluid levels and maybe do a quick drain and refill. I did find several old posts from years ago about the same noise . Most referenced transmission... But no one posted a solution |
02-24-2023, 12:50 PM | #22 |
30
Rep 85
It might be the transmission but I am not that sure because:
1. My transmission was rebuilt 80kkm ago and it's been working great ever since 2. I changed transmission fluid AFTER the noise starter appearing and it had no effect on it 3. Both me and you started hearing this noise when the driveshaft was removed/replaced 4. BMW manual explicitly references this kind of noise when describing driveshaft replacement ("to avoid buzzing sound...") |
