wiring guide
12-30-2008, 03:14 PM | #1 |
Rep 71
wiring guide
hi all, does anyone have a wiring guide to connect an amp to the wires at the hu not in the trung at the amp ?
i dont have an amp in the trunk , so i need to splice in at the hu ! bummer |
01-04-2009, 05:34 AM | #2 |
259
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
Not exactly what you are after, but if you follow these instructions http://www.e90post.com/forums/attach...1&d=1225484555 you can install a speaker level amp
01-05-2009, 02:44 PM | #3 |
Rep 71
thanx very helpfull!. does anyone know the location of the wires from the headunit to the sides where they split up to into 2 ways , one to the door and one to the subwoofer?
i want to splice in there and run a return wire from the amp to the cut wires for reconnection . wish this kit was available here. i am using a 50watt x4 soundstream amp, am i correct in assuming that the if i just reconnect the wires from the amp to the standard wires at full range with crossover, the frequencies will be split by the in line caps attached to the subwoofers ? Last edited by yunus; 01-05-2009 at 03:11 PM.. Reason: additional related question |
