BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > aftermarket lowering springs vs warranty
      05-11-2006, 08:11 PM   #1
a_moux
fuck around and get owned!
Drives: Jet Blk 325i
2006 325i  [0.00]
Will BMW void your warranty if you install H&R sports springs on a base model 325i?
      05-11-2006, 09:39 PM   #2
18LLC
148
Drives: e89
the part you change, the warranty will void for that part. including the wheels.
      05-17-2006, 07:21 PM   #3
whitecord
Drives: 500whp 318ti
if you get them paint them black and they may not notice you have them.. most techs dont go around measureing ride height...
      05-19-2006, 02:44 PM   #4
dkizerian
Digital Ruler
Drives: 325i AW/Terra
Adding a part does not void the warranty.
However if you add springs and a shock goes bad on you they could say the springs caused it and not cover it. If you add an intake and something happens to the motor that they can say was caused by poorly filtered air going through the intake they could deny your waranty. But if you add springs and you have an engine problem they cannot deny your waranty because of the springs.
more info at http://www.sema.org/main/semaorghome.aspx?ID=50096
      05-19-2006, 09:05 PM   #5
D-Rock
188
Drives: 325i
Yes it will but only on your suspension. They will try to blame w, e happens to your car cause you put those aftermarket parts on just a word of advice. Tell them to prove it too you
EX: your light burned because you installed these springs
      05-21-2006, 09:48 PM   #6
a_moux
2006 325i  [0.00]
      05-22-2006, 12:02 AM   #7
06alpine325icm
06alpine325icm's Avatar
11
Drives: 2006 alpine white
yess i have had that problem with acura havent had that problem with bmw
      05-22-2006, 05:28 PM   #8
c-lee
Drives: 325i
if you wait for the Dinan suspension, technically you wouldn't have this problem no? I asked my Service Advisor today and he said that the only suspension that will not void the factory warranty are dinan products installed at a dinan authorized dealer -- donno if this is true. Any insight will be greatful.
The folks at Dinan said that they will release a suspension in a few months (currently in testing).
      05-23-2006, 12:17 PM   #9
dkizerian
Digital Ruler
ARGH! Adding suspension WILL NOT void your entire factory warranty. Please read the SEMA link i posted above...
