10-18-2022, 07:53 AM | #1 |
72
Rep 97
Brake squeal - Anything to be done?
So I do NOT have CCB's, but the brake squeal is horrible, only 10k miles. What are my options. I didn't see much when I searched for the non CCBs. BMW claims this is normal on normal brakes as well? I find that hard to believe. I've had a number of M cars and this is the first time i've ever had this issue.
Are there other brakes out there to switch out for that wont do this? |
10-18-2022, 09:06 AM | #2 |
5287
Rep 10,685
You really did not find any other posts on the subject? I read them pretty regularly. You can try different pads but no long term guarantees. Search for the most current recommendation but don’t expect years of use confirming no squeal over time to go along with it.
10-18-2022, 12:48 PM | #3 |
1913
Rep 2,526
To OP:
Here's the answer you have been looking for: https://f90.bimmerpost.com/forums/sh....php?t=1617012
2022 F90 M5 Competition & 2019 M2 Competition
2019 F90 M5 Competition 2017 F80 M3 Competition 2014 F10 M5 Competition 2003 E39 M5 |
10-18-2022, 12:51 PM | #4 | |
4160
Rep 3,706
Drives: 2022 M5C
Here's mine from earlier this year. Pre-LCI to LCI F90 Owners - Brake squeal difference? https://f90.bimmerpost.com/forums/sh....php?t=1910416
Not a BMW guy...but certainly an M5 guy.
10-18-2022, 06:42 PM | #5 | |
776
Rep 569
Drives: 2019 M5 Competition
This has been discussed so many times its comical. There is a handful of aftermarket pad options.However I don't think many have had them long enough to be able to accurately tell if they work or not. Many have had them for 2-5-10K miles and stayed quiet then started back up again. Some have had success but at the detriment of performance in braking. Basically enjoy the school bus sounds coming from your 100K plus car. BMW has zero interest in addressing the issue. And you're basically stuck with it unless you're a lucky one who's don't squeak. Or able to find a good aftermarket option that works long term. The process of getting the car to 60-80MPH and slamming on the brakes 3-4 times to dead stop seems to work. Although it is temporary, seems to last for the duration of that drive. And thats about it. Same with the wheel cleaner method. My F10 was the same annoyance. F90 is just as bad or worse than the F10. So again, good luck. |
ResIpsaLoquitur4160.00 |
10-18-2022, 07:35 PM | #6 |
293
Rep 605
Sell the car and get one with CCBs. All of us CCB owners do not understand the extreme reluctance to buy them when you're in this price bracket and there are unbelievably extensive complaints out there about the steels being crazy loud and produce insane dust. I would only get steels on a track car so that replacing them would be at a reasonable cost. For daily driving, CCBs make more sense because they last a really long time, are quieter, and make very little dust.
jnotrom711776.00 |
10-18-2022, 08:01 PM | #7 |
5287
Rep 10,685
It’s funny how carbon brakes were originally a high performance track item. Now people buy them mainly to keep their wheels clean and use steel brakes at the track.
jnotrom711776.00 |
10-18-2022, 08:29 PM | #8 |
293
Rep 605
I mean if money is no object, they're still the best brakes for the track. But few can stomach the replacement cost.
jnotrom711776.00 |
10-18-2022, 08:33 PM | #9 | |
776
Rep 569
I would prefer to find a used set of CCBs, or even aftermarket CCB rotors, that apparently work with the steel calipers. Racing Brake I think sells replacements in the steel size specs in a CC rotor and pad set. Someone else would need to chime in to see if these are worth a damn, and if its just a straight swap for the steel rotors to the CC from racing brake. If I could have found one with CCB in the color, and options I wanted, I would have picked it up in a heart beat over the steel. I guess the bright side is, for steel brakes they are exceptional as far as performance (in my opinion), of course, minus the school bus, rental Haul truck sound track that accompanies them. The dust and squealing is literally one of the only things I cant stand about the M5, f10, or f90. But with that said, the great things about the M5 highly outweigh the very few negatives. |
10-18-2022, 08:34 PM | #10 |
776
Rep 569
100% agree. My next vehicle will absolutely have CCB, although living in AZ there is a lot of rocks and pebbles on the roads, would be marginally worried about picking up a rock in the caliper, and then? it's over for that rotor. But I would take that gamble over the dust and pig noises.
10-18-2022, 08:46 PM | #11 | |
4160
Rep 3,706
Drives: 2022 M5C
Every one of us can feel this.
jnotrom711776.00 |
10-18-2022, 08:47 PM | #12 | |
293
Rep 605
Agree that the steels bite hard and perform great. Last edited by Demon Barber; 10-18-2022 at 08:54 PM.. |
jnotrom711776.00 |
10-18-2022, 09:03 PM | #13 | |
4095
Rep 5,239
jnotrom711776.00 |
10-18-2022, 10:07 PM | #14 | |
776
Rep 569
I briefly looked into it, but didn't spend a lot of time on it. Looks like about 12-13k for 4 rotors and pads. It says "iron upgrade" or CCB replacement. Someone with a lot more knowledge than I have would need to chime in as to if you could literally just swap pads and rotors and still keep the same master cylinder, coding etc. I believe in order to swap to the OEM system there is a bit more involved than just swapping pads and rotors. That would be sweet if its just a matter of pads and rotors and boom you have CCB. Both are expensive. However the Racing Brake option could at least save some time and expense having to change calipers, coding, and other components (if thats the case, I dont know). https://racingbrake.com/f90-2018-1/ |
10-18-2022, 10:10 PM | #15 | |
776
Rep 569
Me outside pulling in to the valet at Mastro's for a nice 100.00 steak.... "Nothing to see here everyone! .... I seem to have driven over a couple of pigs on the way in to dinner, ..... move a long, trust me, its fast, and my BMW service advisor told me this is normal, I swear....go on with the chlorophyll" Last edited by jnotrom711; 10-18-2022 at 10:15 PM.. |
10-18-2022, 10:33 PM | #16 |
4160
Rep 3,706
Drives: 2022 M5C
I got a really good laugh out of this! Thank you! This was so extremely bad on my previous M5, I started the thread higher up in the post. Embarrassing was an under statement. I don't mean to revive the complaints in that thread, but it very nearly prevented me from going with another M5. Have had my new M5 for 3.5K-ish, and I am squeak free 95%+ of the time. That 5% is only if I am really creeping through city traffic at low, single digit speeds, drive through, etc., while holding the brake with light but consistent pressure, and even then, not all the time. A significant portion of the squealing is gone in this car (or perhaps just hasn't started yet). It's such an improvement I don't complain about the remaining squeal any more. No CCBs, just like my last one. There really seems to be no rhyme or reason to it. Started before 1K in my previous car. I'm just hoping it stays like this. One of my other cars was quiet as a mouse until basically the second it hit 20K in the last month. I don't think I could take another one.
10-19-2022, 10:49 PM | #17 |
124
Rep 180
The Steel Brakes were updated for the 2023 M5's. They are supposed to be quiet. We'll see. The updated parts have been available at dealers since June.
10-19-2022, 10:57 PM | #18 |
293
Rep 605
Interesting. Would like to know what they've changed, but it's unlikely the technical details will be shared. If I had to guess, a different pad compound.
10-20-2022, 03:17 PM | #19 |
256
Rep 193
My 2023 M5 has 2.3k miles and have yet to have the break squeal. Maybe BMW has it fixed.
2023 F90
10-21-2022, 06:24 PM | #20 | |
1411
Rep 531
r33_RGSport13113.50 |
10-21-2022, 07:40 PM | #21 | ||
4160
Rep 3,706
Drives: 2022 M5C
Camarejh1410.50 |
10-21-2022, 08:47 PM | #22 | |||
989
Rep 1,807
Camarejh1410.50 |
